Question about Gaggia Titanium Espresso Machine
Weak coffee and pale crema.
The crema is very pale, and has lots of bubbles which breakes down after just a few seconds leaving only the pale crema left. The coffee tastes weak,watery and bitter.
I have tried with different types of fresh espresso blends and different grinders.
I have tried with a KitchenAid pro line burr grinder, the built in gaggia titanium grinder, and the professional grinder at my local café. Both my grinders with finest grind give me only 15 seconds of extraction time and produce the same weak, watery coffee. How long should a extraction take with this machine?
The coffee grinded at the café give me a little better result, a little darker crema and some more taste in my shot, but not good enough. Maybe a second longer extraction.
The dispensed pucks produced is dry, compact and holds together.
This is a very well used machine, it has been used at a company before and has run 27000 brew cycles. Anyone has any advice how to improve the performance? Is this machine done?
  • denne2 Jul 17, 2008
    is this just what to expect from a super auto machine? how close to a real espresso machine should this machine perform?
  • Gaggia Master
  • 19,396 Answers
If you get weak coffee from espresso machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on Apr 05, 2009
I have turned the grind knob all the way down, below 1.
Sounds like there is not enough coffee to make a solid puck. If you get crema, grind coarseness sounds ok. A finer grind will produce less coffee grounds for the puck and increases chance of clogging.
You may have to balance grind size with amount of crema to get solid puck.
Big problem with these is you want dark roast for espresso, but oil on beans clogs grinder. Are you using a dark roast? A medium roast works better in these. Or, can you increase the grind time? My Super-auto had a program option to increase time. But not in reg instructions. Got it from authorized repair facility.
May 04, 2016 | Saeco Vienna SuperAutomatica Coffee...
Dispenses very little CREMA. Is there something to adjust?
Rule of thumb - espresso machines deliver a shot of coffee in 25 to 35 seconds.
If there is no crema and the coffee comes faster:
  1. There is not enough coffee in the portafilter (7 grams per shot).
  2. The coffee is not tamped enough (about 30 lb pressure on the tanmper handle).
  3. The grind is too coarse.
If the above does not "fix" the crema problem, post again and include make and model of the machine and type of portafilter.
Good luck.
Apr 27, 2015 | Coffee Makers & Espresso Machines
I am not getting crema with my new machine. What do I need to know?
Either your coffee grind is too coarse, or the coffee is not fresh, or your tamp is incorrect. Those are the 3 basic thing that affect your crema. Try this get a handful of coffee and squeeze it tightly, it should clamp and then break apart when you open your hand, you should also be able to see your finger marks in the coffee.
Jan 04, 2011 | Rancilio Silvia Espresso Machine
No 'real' coffee taste or crema - despite following instructions
Set the machine for the finest coffee and the least water.
You should get a decent espresso.
For a regular cuppa, keep the settings the same and make either a medium coffee combined with a small coffee (jolt) or
make two small coffees.
I have this machine and the crema is nice at this setting.
Aug 01, 2010 | Miele CVA615 Espresso Machine
Virtually no crema :-((
If you have tried different coffees and grinds then i would try different packing methods using a tamper to do so. Try packing very firmly to not so firmly and see if that works. Also you might find that you need a new double filter basket. I have seen this in quite a few machines where the holes in the basket can become very slighty enlarged from what they were originally and what this does is allows the coffee to flow through the basket too quickly and therefore leaving you with poor crema by not getting a good extract from the coffee. I hope this helps.
All the best
Mr La Pavoni
Apr 23, 2010 | La Pavoni Europiccola EPC-8 Espresso...
GAGGIA TITANIUM........WEAK COFFEE
Try adjusting the grind finer, if that does not help then go to menu and make sure pre infusion is enabled.
Jan 19, 2010 | Gaggia Titanium Espresso Machine
No Crema
Hi
If your talking about the tube on the brew unit, you are probably missing the spring or if you have the spring its upside down. Again if this is what you are taking about is the check ball at the bottom of the spring(ball in first, small end of the spring on the ball, O-ring, then the manifold)These things are important for creama.
Nov 08, 2009 | Saeco Magic De Luxe Espresso Machine
Crema light in color
Grinding coffee at a finer setting (stronger coffee) only speeds up the clogging effect it has on machinery. The finer it is the more it acts like mud. The oils in this mud cake dry up right after the water dries up (over night) and presto you have concrete! This concrete becomes to thick to clean, so cleaning with tablets has to increase dramatically if you increase the strength of the coffee. If you leave it strong clean it weekly.
Normally you clean the brew unit with cleaning tablets every time you finish descaling. That's about once every 200-250 coffees based on the water hardness you set in the electronics. If you notice changes in the coffee waterflow speed it's usually from clogging.
If you're handy get your camera. Take pictures of every step you do. Remove the brew unit. Disassemble the left top section (2 screws holding the long pipe). It compresses a 1/2" long spring. It may get away from you so be ready for it. The spring attached to a half round plastic button (valve) that looks like a rivet. Clean all brown gunk from this valve and the housing and you're creme will return. While your in the cleaning mode remove the filter and clean inside under the filter. The filter is that round stainless steel screen disc with the phillips head screw in the center.
All this is evedence that cleaning needs to be stepped up, good luck!
Oct 11, 2009 | Miele CVA615 Espresso Machine
Krups FNC3 Espresso Machine
If it's only 18 months old surely it will still be under some sort of manufacturers guarantee, you don't bin 18 month old coffeemakers nor should you be paying to fix them. Put the problem back in their lap.
Aug 01, 2017 | Krups Novo 3000 /FNC3 Espresso Machine
Inconsistent quality of crema and coffee
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Sep 19, 2008 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
931 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
