Pilot will only stay lit if I hold the button in. It worked prior to that and all I did was put the insert back into the mantel and tried to relite it and it wont stay lit. I checked everything outside the tank is full there are no leaks at any of the fittings and all the valves are on. I was told that the thermal coupler has to be a sixteenth away from the pilot and I checked that and still no response. Thanks Dave
  • 1,420 Answers
Make sure the flame hits the thermocouple and the connection at the gas valve is tight.
Posted on Jul 17, 2008
  • 828 Answers
Replace the thermocouple.
Why doesn't the pilot stay lit?
Why Does My Gas Furnace Pilot Light Keep Going Out?
santafeair.com/blog/.../why-does-my-gas-furnace-pilot-light-keep-going-...
Jan 10, 2014 - The thermocouple is the copper rod you see the pilot flame hitting. It's a safety device that controls a small valve to shut off gas going to the pilot ...
Aug 11, 2015 | Kitchen Ranges
My Kozy World nat gas wall heater has worked beautifully for the past three winters. I cleaned it this morning with canned air, got all the dust off the ceramic plates, blew out the burner inlets, blew out...
Does the pilot light stay lit if you continually depress the control valve?
If the pilot light stays lit as long as you keep the valve depressed, then the problem is the thermocouple is bad. The pilot light makes enough electricity via the thermocouple to hold open the gas valve that feeds the burners. If the thermocouple fails to produce that electricity, the gas valve will shut down and switch off the gas flow to the whole unit.
Mar 05, 2015 | World Heating & Cooling
I stopped the device. I don't know how to restart it.
Hold in your pilot button, then push the spark button repeatedly to light your pilot. Once its lit, hold that pilot button in for 30 seconds to heat your thermocouple. once its heated, release the button, and slide the slider to burner position. Turn on hot water fixtures to get the unit to light
Dec 31, 2013 | Bosch AquaStar Indoor Natural Gas Tankless...
I bought from a private party a used Wolf range Challenger Model CHR-4-29-HB11, oven worked fine. First I was baking and heard stove making a phfttt, phftt, noise. Then took food out and noticed oven...
Pilot lights go out because the Thermocoupler is either bad or not getting hot enough. It will be a copper tube that should touch the pilot light flame. these are replaceable and usually any appliance repair supplier can get you one. Some units reuire changing out the entire gas control
Oct 17, 2013 | Wolf Range CHR-10-229-FT11 Kitchen Range
The lit was out, without a manual on hand, how do I re-lit it/ Thanks.
If you're talking about a heater, you have to push, usually a red button, in, and then light the pilot gas light. Keep the red button pushed in for about a minute, until the thermocouple gets hot and turns on the gas valve, then release the rebutton, and it should stay lit. If you're having problems, you maybe have to try it two or three times, and, as soon as you can, replace the thermocouple (the long rod that gets heated by the pilot flame).
If you have a different system, such as an electric igniter, you'll have to push a button to engage it, and it should ignite. If it doesn't, it could be defective, or your valve could be going bad.
Hopefully, you will get it relit. They do blow out with random drafts, occasionally.
Dec 23, 2010 | Heating & Cooling
Pilot light wont stay onfor outside pool heater. gas co made a service call & relit the pilot light, it went out again 4 days later.
Thank you for posting your question here on Fixya.com.
Has anyone replaced the pilot generator yet? A millivolt heater (one with a pilot light) requires about .75 volts from the generator to operate. As the generator ages it puts out less and less voltage and eventually gets to weak to even hold the pilot gas valve open. Replacing it with a new generator will usually fix the problem you describe.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 17, 2010 | Pool & Spa
My universal lp forced air heater model 30 fsa wont stay lit
if its lit by a pilot your thermocouple is bad the purpose of the thermocouple it to keep the gas valve open
Oct 24, 2009 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Pilot wont light
If the pilot light goes out when you release the primer,then the thermocouple is bad.You can try to adjust the thermocouple,if it can be.It needs to be in the pilot flame.If the thermocouple is not in the flame,it will not stay lit.If you can not get the pilot to light at all,with the primer pushed down,then replace the regulator.To light the pilot light,you need to turn the dial to pilot.Then press the primer button down and hold it.The primer is either built into the turn knob,or it is a res button.Hold the primer down,and light the pilot,continue holding the primer down for at least 40 seconds.Then release the primer slowly,and if the pilot light starts to get weak,and try to go out,then push back down,and hold 30 seconds more.After the pilot stays lit,turn the knob to furnace or low,or whatever the directions say.
Oct 19, 2009 | Heating & Cooling
My hot water tanks pilot light turns off after I have relit it. It stayed on while heating the water in the tank and once it stopped heating the pilot light went out again. What would be causing my...
are you holding button down long enough for thermal coupler to warm up? after pilot lights up, don't immediately let go of button for about 15 to 20 seconds then let go and pilot should stay on. If not, you may need a new thermal coupler for that water heater
Jul 03, 2009 | Water Heaters
Pilot light won't stay lit on convection heater.
replace the therocouple. next year do not turn the pilot off
Nov 24, 2008 | Clairion Convection Heater - HC-1500
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
