Question about Kodak I620 SHTFEDSCAN Path-Through Scanner
I620-auto feeding multiple sheet
Recently my scanner will auto feed the last 10 or so sheets all at once. I auto feed about 60-100 sheets at a time, but the last ten pages have recently gone thru together all at once. I replaced the auto feed tires in hopes this would correct the issue, but it persists. I clean it often with staticide wipes and the compressed air containers. Any further suggestions to correct this?
  • Andre Velez
    Andre Velez Mar 12, 2012
    We buy, sell and trade; new, used and refurbished scanners. Call me about the Kodak i620. Andre 855-420-8273 ThirdWindTechnologies.com
  • 3 Answers
You have to change the lower Sep. Roller Assy.
Posted on Feb 04, 2009
    Problem Solver:
  • 14 Answers
Please check the separation pad.
If it is worn you should also exchange it.
Posted on Jul 18, 2008
I opened the hood on the machine, and between the first two intake rollers on the bottom, there is a small rubber strip. This strip comes packaged with a sticky yellow tape to protect the rubber. When it was installed, no one removed this tape. After doing so, the machine feeds great. Hope this helps someone else who may be experiencing a similar feed issue.
Posted on Jul 17, 2008
Riso V800
Riso's are famous for this, i will scrub the rubber timing roll with rubber rejuvenator and clean the steel roll with alcohol.The riso paper feed clutches are weak compared to what they were in this series you may have to replace the clutch. Bud, after doing some research you need to clean the oneway bearings on the pickup and feed rolls, adjust feed table hieght and lastly check/adjust timing in drive and feed roller-you will need a manual for this.
Hope this may help;
Regards,
VOTIT
Jul 25, 2008 | Riso RZ220 Duplicator
Hello can you assist I can not figure out why the CX8310 Epson printer won't allow me to feed paper into it.
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right edge, behind the tabs, then slide the left edge guide against the paper. Make sure the paper is not in front of the feeder guard.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • Don't load too many sheets at once (up to 20 sheets of photo paper, 80 sheets of Premium Bright White paper, or 100 sheets of plain paper).
    Sep 11, 2010 | Epson Stylus CX3810 All-In-One InkJet...
    The scanner takes 2 sheets of paper at a time instead of 1 so only 1 is being scanned. I've tried a different paper that is thicker than regular printer paper and it's still doing it.
    There is a pad below the feed roller that wears out. It is called a ****** pad, it retards the feeding of extra sheets of paper. That pad will need to be replaced. Once it is it will stop multisheet feeding.
    Apr 01, 2010 | Xerox DocuMate 152 Pass-Through Scanner
    Miss feeds when print multilpe pages
    The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
    Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
    I620 scanner
    Is the scanner scanning normally otherwise? Try scanning a printed matter with white background and if it is okay, then the streaking may be because of excess brightness chosen. Check if the paper movement is at constant speed. If it is smooth paper, it may slip and the same area may scanned again, appearing like a streak.
    S. Moha, Chennai
    Nov 07, 2008 | Kodak I620 SHTFEDSCAN Path-Through Scanner
    HP paper jam
    That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
    Please remember to rate all users who assist you for free :)
    Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
    Double feed detection
    though it has a flexible papr handling capabilities you might want to consider the ff:
    Stacker Capacity: 100 Sheets Document Feed: Automatic or Manual Document Size: Width: 2.2" - 10.1"
    Length: 2.8" - 14.3" Thickness: Automatic: 0.06 - 0.15mm
    Manual: 0.06mm - 0.20mm Feed Capacity: 100 Sheets
    all scanner are equipped with double feed prevention, however it still the user responsibility to ensure that you follow manufacturer's advice, to prevent double feeding:
    1- do not feed dog eared paper
    2- moistured paper or with strong humid
    3- concave paper
    4- convex paper
    cheers!
    Aug 28, 2008 | Canon DR-3080CII Path-Through Flatbed...
    Multiple sheets
    You can try to clean the retard pad under the feed roll, but for best results you should replace it. Parts are readily available on the web. You should spend around $20 for the pad, and $50 for the feed roll. You may not need the roll. Examine it and see how the tread looks. These parts are easy to replace.
    Feb 29, 2008 | Fujitsu fi-5530C Scanner
    Automatic Paper feed
    Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
    Sep 06, 2007 | Samsung ML 1210 Laser Printer
    Kodak I620 SHTFEDSCAN Path-Through Scanner Logo
    175 people viewed this question
    Top Kodak Office Equipment & Supplies Experts
    Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
