Question about Car Audio & Video
Amp if i have ground connected wrong what happens?
    Novelist:
    Champion:
  • 218 Answers
Best case, it won't power on. Other cases, it shuts off then on then off. Could also introduce noise into your audio signal. Another thing it will do pretty often is to seek a ground thru your RCA cables back to the radio and then "fuse" (read fry) your ground circuit in your radio for the RCA outputs. Worst case, it will do something bad to your amp. Most likely thing to happen if there is a bad ground is to zap your RCA grounds in the radio, and then it is time to take the radio to the shop to get some new ground wiring installed. Good luck.
Posted on Jul 17, 2008
Dayton (3E133) hooked up wont work at all
The 3E133 (or similar) Infra-Red Heater with correct voltage to the circuit board should produce a spark at the spark ignitor rod within a few seconds of having power applied. If it doesn't, one of the following could be the problem: (1. circuit board (ignition controller) is bad. (2. The gap between the spark ignitor rod and the middle rod (ground) is incorrect. It should be between 1/8" & 3/16". (3. There is not a good ground. This could be due to rust or a loose connection at any point between the equipment ground and the spark ignitor rod, including the ignitor mounting screws. (4. The spark ignitor rod or its orange wire is grounded, such as touching metal and thus "short circuiting" rather than allowing the spark ignitor rod to be 1/8" from "ground".
That's all I can think of that would cause NOTHING to happen.
Dec 12, 2011 | Dayton (3E133) InfraRed Heater
I have a sony 1000w zr1852. The power and ground cables touched at the amp. I fixed the connection but now the power save light is on. what could be wrong? thanks
Sounds like there's either some fuses blown, or a short circuit happened inside the amp. However usually they're pretty good about not shorting out. Check your connection at the battery, In-line Fuse, Cap, Distro, and Amp and make sure everything is connected fine. Check the Alternator in your car to make sure it's outputting the right voltages, and the battery to make sure it's between 12V - 14V. I've had some weird things happen over the years with my Car Audio, and it always ends up being wires or fuses.
Jul 04, 2011 | Car Audio & Video
I get power to my amp with the 12 volt and the remote plugged in. once i hook up the ground the amp well turn off. how do i fix this?
Something is seriously wrong! The amp should not even go on without the ground connected! If it is going on without a ground cable connected then there is an internal short allowing the amp to receive a ground signal. Once you actually connect ground, the amp is protecting itself from the dead short you have now applied to it.
Dec 23, 2010 | Car Audio & Video
My jl audio amp 500/1 keeps losing power or something because the bass goes on and off after i turn up the volume what is it ?
Sounds as if you might have a bad ground or other poorly connected power wires. When you turn it up the amp is looking for more power but it can't get it hence the amp shutting down. You need to go over your positive cable connection from battery to amp and also make sure you have a good ground. Also it depends on where you bolted your ground too. Did the amp not do this before and now it does or did you just get it and put it in and it's doing it. Try another amp if possible. Your subs might be bad also or running at the wrong ohms. This amp puts out the same wattage at 1.5 to 4 ohms. I think personaly you got a bad power connection cause the amp is starving for power when you turn it up. It depends on a few different reasons why this is happening. Last thing would be the power supply in the amp itself. I just need to know if it recently started doing this or is this a new install amp for you. Let me know so I ca further assist you.
Nov 16, 2010 | Jl Audio 500/1 Car Audio Amplifier
When I turn the car on the amp goes into protect mode
A few things can be happening, the amp has a short somewhere, the amp is defective, or it may have a connection problem, wires connected the wrong way, but it is most likely a short somewhere, trace the power wire from the battery to the amp 12V+ connector and see if there is a short or if the wire is pinched, another way to find out is to get a test light, find a power source somehwere ( 12V+ ) and place the test light tip on the amps 12V+ connecter, thats the easier way if you are too lazy to trace,lol. If the test light lights up then you have the power wire grounded and you need to find out where and correct it., Also check the amp turn on wire it may be grounded or shorted as well. If this your solution please remember to vote and rate me.
Good luck my friend.
Lex..
May 21, 2010 | Insignia 600W Bridgeable Amplifier with...
Soon as i try to connect the power and ground starts sparking and my fuse blows by the battery. I changed the ground cause i thought that could be it plus i tryed installing it in another car that had an...
your inline fuse wouldn't blow if there was just something wrong with the amp. the amp fuse would blow if that was the case. something is faulty with your wiring. you probably have the wires touching somewhere or are in the wrong terminals at the amp or on the wrong battery terminal. or your power wire is grounding out somewhere. its not the amp. its your wiring
Mar 16, 2010 | Car Audio & Video
Thermal light goes away when ground added
Doesn't sound like anything is wrong. If the thermal light is on before you have the ground hooked up then the amp is probably getting a small amount of electrical ground from the shielding on the RCAs or its mounting to the chassis of the vehicle allowing the amp to "barely turn on" (not enough ground). I can imagine this would make the amp think something is wrong (ie: thermal light) . May I suggest that you do not try to turn any amplifier on without ALL appropriate wires connected correctly.
Mar 01, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Kenwood kac-5201 amp
12 VOLT FROM THE BATTERY SOURCE GOES TO 12VOLT BATT CONNECTION.12 VOLT GROUND RETURN MUST BE FIXED TO THE FRAME OF THE VEHICLE.SOME VEHICLES HAVE FACTORY GROUNDS UP HIGH ON THE SIDES OF MOST VEHICLES, U CAN USE THIS GROUND LOCATION. IF CONNECT REMOTE WIRE FROM THE RADIOS REMOTE TURN ON LEAD WHICH IS A BLUE/WHITE WIRE OR A STANDARD BLUE IF ITS JUST ONE BLUE WIRE. CONNECT THIS LEAD TO THE REMOTE TURN ON CONNECTION ON THE AMP , SOME KENWOODS HAVE TWO ,INPUT AND OUTPUT LEADS.U ALSO NEED A TEST LIGHT, OR U CAN USE A SPEAKER TO TEST FOR POWER AT UR CONNECTION.IF U USE A TEST LIGHT , CLAMP THE END U WOULD GROUND TO THE VEHICLE, TO THE AMPS GROUND, THEN TOUCH THE PROBE END OF THE TEST LIGHT TO UR WIRED CONNECTION TO VERIFY U HAVE POWER AND GROUND TO YOUR CONNECTION.IF TEST LIGHT DOESN'T WORK ,CHECK UR FUSE AND REMOTE TURN OR LEADS.
Sep 02, 2008 | Kenwood KAC-5201 Car Audio Amplifier
Rockford Amp - When grounded, both power and thermal lights go off
You shouldn't have the power wire connected to the amp without having the amp's ground terminal connected to a good ground. With some amps, it will damage the head unit.
Does the amp power up normally if you connect power and ground and then apply remote voltage (turn the head unit on)?
Dec 18, 2007 | Rockford Fosgate Punch P5002 Car Audio...
Is it my amp or sub
try another sub if possible to see whats happening...You might want to check to see if you have a good ground to amp .make sure ground connector is not on top of paint..if it is scrape paint off from body and polish to bare metal.Then reattach ground wire..then retry..
Dec 15, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Car Audio & Video Logo
132 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
