Taking dash apart to install aftermarket stero in 2007 serria
I almost have it apart, but in the middle by the factory unit also wood grain, i cant do anything with it can you help?
  • 2,071 Answers
You must clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. DVD chassis, you can plug in the unit and check if this helped the player to "see" again. Most of the time you can check as is, though on the combo units you're going to have to slide the chassis assembly all the way back into the cabinet to get it to work because the cables are often too short. If this didn’t fix the problem, please read on.
Other things to check
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc.
f the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit.
Also, in a DVD/CD player there are many complaints where the disc gets stuck inside of the unit. This could be as described earlier, but there’s also what’s called a drawer/disc tray opener and closer mechanism to contend with. On many models, old and new alike, there’s a small belt that goes bad and wont let the tray open. You can usually put your ear very close to the front of the unit and, if this is happening, hear the motor spinning when you press the eject button. Another cause is the nylon gears, which can get jammed up with dirt and dust. Also, in other cases, you could have a motor problem, or the driver IC could be at fault. If you suspect that the motor is at fault, simply measure the voltage on the tray motor while pressing on the eject button. If the voltage comes up between 6 to 12 volts, depending on the manufacturer, then the motor needs to be replaced.
Alignments
If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Posted on Jul 16, 2008
Does any radio work for a 1986 camry?
As in aftermarket like a Sony or Kenwood or..???? Yes.
The easiest way to install one is to get an installation kit. One that has a bracket/face that fills the hole in the dash and the new radio sits in and a wire harness. The harness makes things so simple. You don't need to know what wire color is what. The cars factory harness plugs right in and the new radio wires will be the same color on the harness.
Sep 06, 2011 | 1986 Toyota Camry
Hi I am trying to install my new amplifier and sub into my 2007 Pontiac Wave 4 Door Sedan but I am having troubles accessing the back of the head unit so I can plug in the necessary wires. How do I...
You need to remove the plastic peice above the glove box use a screwdriver and a rag so you dont scratch it its kinda tuff to pry off but it does come off next remove the small plastic trim next to the steering wheel on the right then you can remove the plastic around the radio itself then their is 4 bolts undo them pops right out fyi: if putting a aftermarket stero you will have to buy the 80 dash kit with chymes and a special antenna adapter hope this helps
Feb 10, 2011 | 2007 Pontiac G5 Gt Coupe
How to remove 1990 xj6 radio
You must open the center console lid and remove the 2 Phillips head screws above the fuse station to expose the ashtray Phillips head screws.Remove the ashtray screws and carefully pull he ashtray back towards the center console. After the ashtray is removed take your hand an feel under the wood grain unit for the 2 plastic wing nuts holding the wood grain in place. Remove them and gently lift the wood grain up and out of the way. Remove the 4 Phillips head screws holding the AC controls and Radio bracket. Place the gear shifter in drive to pull the whole unit out. Sounds like a lot but takes about 10-15 mins to complete.
Aug 29, 2009 | 1990 Jaguar XJ6
Im trying to remove the factory radio and install a new one
First you need to gently pry off the wood grain cover around the gear shift. Then you'll see the the two screws on either side at the bottom holding the faceplate around the radio. These should be the only two screws. Before I discovered this, I had tried to pry it off starting at the top. I found it was held on by plastic clips until I got to the very bottom, and said WTF? Then I found a picture, and said Oh duh :)
Apr 09, 2009 | 1998 Nissan Altima
I need to take out the factory stereo in my 207 Jeep wrangler X
dvd is suks must change in garanty or buy a real dvd from your car i have same problem wuiz 3 dvd same problem f...k dvd
Apr 06, 2009 | Jeep AM/FM Cassette with CD Changer...
Chanmge the factory stero
There is  a strip of wood trim that needs to be removed so that you can get to the screws that attach the black dashboard plastic to the back of the dashboard.  You will need a hex head screwdriver.  There are also screws inside the air vents.  Once you have removed all the screws the black dash panel will slip off easily.  If it does not slip off easy, then you missed a screw.  Now that your radio is now exposed, use a socket wrench to undo the three mounting bolts, they are on the face of the radio.  Then after you have that out, install a radio mounting plate that you will have to buy extra with your aftermarket stereo.  Ten slip in your new radio and re-attach all of the bits you took off in reverse order.
Feb 12, 2009 | 1997 Buick LeSabre
Can not get power to radio
Have you got an Aftermarket Harness to Connect to the Factory Harness that is inside the Dash for this Install????
Jan 30, 2009 | Pioneer DEH-1400 CD Player
93 BUICK LESABRE CUSTOM dashboard dissassembly
turn air vents to one side once all the way pull on the part sticking out the most they all come out like that.There will be a screw on the top inside of the vent remove these from each vent.On the bottom were your ac control panel is there is plastic wood grain piece that goes across the dash.Get a flat head screwdriver stick in top of wood grain pry out and work your way down.theres also a small piece on the driver side same senerio.theres a couple screws above the gauges also two in top on inside glove box.
Jan 27, 2009 | 1993 Buick LeSabre
Take dash apart 2007 serria
Hi
What can i do for you?
Thanks!
Jul 16, 2008 | Televison & Video
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
