HOW TO HOOK UP A VCR - Televison & Video
    Master:
  • 726 Answers
What Nickstar19 Said
Posted on Jul 17, 2008
    Sergeant:
    Champion:
  • 417 Answers
Yellow cord from vcr plug in the yellow input and then the yellow input on the tv
red cord from vcr plug in the red input and then the red input on the tv
white cord from vcr plug in the white input and then the white input on the tv
Posted on Jul 16, 2008
How to hook up to a vcr to ikonvert to hd tv
you cant make a video from a vcr change into high definition,you can only hook up to tv,no up convert for vcr
Mar 10, 2015 | Supersonic Ikonvert Sc55 Digital Converter...
How to hook up vcr and tv using digital adapter
You can hook up the VCR directly to the TV; you don't need to hook up the VCR to the adapter. If you already had the VCR hooked up to the TV, you don't need to change those connections.
Jan 29, 2015 | Televison & Video
How to set up tv to vcr
Hook cable or antenna to in on vcr, hook either with cable from out on vcr to tv. Have tv on 3 or 4---most sets have slide switch on back of vcr.
turn both on and use vcr to change channels if you want or to play or record a movie. If not using vcr turn it off and change channels in regular fashion on the tv.
Mar 18, 2012 | Philips Televison & Video
I have purchased Samsung 550 - series L5 - I don't seem to be able to hook up the VCR to it to record. I have cable on it and I would like to be enable to record programs. Television ask if I want to...
You don't record from TV, you record from cable so cable needs to be hooked up to input on VCR.
If you don't use cable box you would hook cable to VCR then out of VCR to TV. If you use cable box then you need to connect Video and Audio outputs on cable box to Video and Audio inputs on VCR and switch input of VCR to Line input.
Feb 28, 2011 | Samsung Televison & Video
Adding vcr & rec to a '93
Please hook up VCR with TV through RF cable and check picture of VCR playback in TV.
Now you can hook DVD player video-audio out in VCR input and can have dvd playback picture in TV via VCR modulator.
If you want to listen sound via receiver then hook audio red-white cable between VCR audio out and receiver audio in terminals.
Let me know exact model numbers of units to help you out more.
Thank you.
Jan 13, 2009 | Televison & Video
Converter box hook-up
Just had someone to hook it up for me-Thanks for replying-Beckie
Jan 04, 2009 | Philips Magnavox DVD/VCR Dual Player
How to hook up my vcr to my admiral tv.
look to see if there is a place to put a cable cord if there is you need to hook a cable cord from the tv to the vcr and from the vcr to the tv. so you need to small cords.
May 03, 2008 | Televison & Video
Hook up vcr
Unhook the dvd cables from the AV1 ports on the tv. Then hook these DVD outputs to the inputs on the vcr. Then hook the vcr outputs to the tv inputs (AV1). The tv and the vcr must then be set to channel 3 in order to watch the dvd (and possibly also some menu settings such as setting everything to "component video" and/or setting the tv/vcr button to "vcr. Also set all "3 or 4" switches on the back of all equipment to channel 3. Also, don't forget to go into your tv menu and choose AV1 when you want to watch the dvd and/or the vcr.
You can also try connecting your dish to the vcr and then the vcr to the input on the tv where you HAD the dish connected. There are several combinations you can try, but just remember to always put output cables to the INPUTS of the next piece of equipment in line, and set your menu settings appropriately on all equipment whenever you change from one machine to the next.
If all this fails, then here is a 100% positive solution. Buy an "A/B" switch. It has two inputs and only one output. You could leave the dvd connected as is and connect the dish and the vcr to the two inputs on the A/B switch. Then hook the one output of the A/B switch to the tv. When you change the position of the A/B switch back and forth, you will be changing over back and forth from dvd to vcr. You can move the A/B input selection switch manually or you can buy a remote controlled A/B switch and do your switching with the remote that comes with the switch.
Keever
Mar 04, 2008 | LG 42LC2D 42 in. LCD HDTV
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Hooking tv up to my vcr/dvd combo
hook the antenna to the VCR rf conecter IN. buy some RCA jacks and a three way deal and hook the red to sound red out ,white to sound output white, and yellow is always video hookit to yellow vido out on the vcr/dvd. The other ends go to the inputs on the TV....same color code. or you can just hook a cable to rf connector OUT on the vcr and other end to( it with problably just same antenna in) to TV.
Aug 29, 2007 | Sanyo DS31520 31" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
