Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Hitachi T.V. My T.V.'s picture went out and it has three ligths on the front of the T.V. and they say Power, Temp., and Lamp. Every time u turn it on three ligths flash until the one beside lamp ligths up and it doesnt show picture or nothing it stays dark.
  • 1 more comment
  • Anonymous Oct 16, 2008
    same problem i guess i need a lamp
  • vicspier Nov 09, 2008
    i have the same problem. can you buy a lamp at HH gregg
  • joellen4law May 11, 2010
    Where do I get the bulb or lamp replacement for my Hitachi TV?
Help..... i need help....
Posted on Nov 23, 2008
  • 927 Answers
Good Day, halobeast044;
Replaced the LAMP. Good Luck big IRISH.
Posted on Sep 06, 2008
My tv went out the other day completely but when i turn it on there is no picture but there is a flash on the lamp light and temp.
Most likely bad lamp . Listen for a very slight buzz from the rear of tv at power up. IT will buzz several times before lamp light begins to blink. IF it does and pix does not light suspect lamp .. Part number Ux21513
Feb 16, 2011 | Hitachi 60V710 60" Rear Projection HDTV
Hitachi 50V715 power on/off problem
I would check to see if any of the fans stop turning or don't turn when set turns on. They do have sensors monitoring them and the set will shut down if they are not turning. I believe there are three fans around the chassis.
Hope this helps,
Skyassoc
Oct 23, 2009 | Hitachi 50V715 50" Rear Projection...
TV went off, and three lights come on (green "power", red "temp", and red "lamp")for just a second, in succession from left to right.
My television had two red lights flashing, one for Temp and the other for the lamp. I removed mythe lamp assembly and the bulb filament was burnt out. I order a new lamp and housing unit UX21517 and replaced it and now I have the red light flashing which is calling out the lamp again.
Oct 10, 2009 | Hitachi 50V720 Television
Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Jun 13, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
TV Won't Come On...
My Hitachi Model 50V500 led's ligths temperature and lamp blink when power is turn on.Have no picture or sound, followed the reconmended procedure disconnected power
for 30 seconds and reconnected.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
My Hitachi 50V500 does not turn on
Most likely...Just remove cover on left side and take a look at the lamp and go from there. I may have one in stock if you need it. You will also need a philips screwdriver.. Happy repairing. Guru Jay
Feb 05, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi model # 50V720
I have the same model and had the same problem after replacing the lamp. Turns out if the cover plate is not put back on properly, tv will not power on and lamp ligth comes on. To solve the problem all I had to do is tighten the cover plate screw. Hope this helps.
Nov 17, 2007 | Hitachi 50V720 Television
Need answers
The fan may have went bad. If it's out of warranty you may open it up and try and blow some dust out of the fan to see it that may do the trick if not it may need to be replaced. Westexaudioelectronics.com
Oct 04, 2007 | Televison & Video
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
167 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
