Question about Canon Office Equipment & Supplies
Canon i560 printer will not turn on, despite power. Is there a reset bntton or combination that may make it possible or is it a short life product?
  • Canon Master
  • 691 Answers
Have you checked the fuse on the power cable? Have you tried another power outlet and changed the power cable?
If you have the chances are the power supply unit in the printer is faulty. It may have an onboard fuse that has blown or maybe the PSU is fried.
Posted on Jul 16, 2008
Canon i560 yellow light blinks 5 times. How do I clear it and have good printer again?
This is a printhead/cartridge error.
First try to reset the computer:
Resetting the PrinterBy resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur.Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
If that doesn't work try to reseat the printhead.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/i_series/i560_series#ServiceAndSupport
Feb 20, 2011 | Canon BubbleJet i560 InkJet Printer
Canon s9000 blinking 7 times. Tried the on and resume button sequence without success. Rob
HI,
Please do a hard reset.Unplug all the cords of your printer for 20min. and then plug it back in.
Let me know the result.
I will be waiting for your reply.
Oct 06, 2008 | Canon Office Equipment & Supplies
I560 will not power up
The Canon printer has a power supply problem, I have found that when the fuse goes, it usually indicates shorted diodes and a filter capacitor, It will need to be dis-assembled for service.
Jan 19, 2011 | Canon BubbleJet i560 InkJet Printer
I have got Canon i560 printer but not recieving print order the software is loaded what is the solution ?
Try i560 Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Pl let me know if this works
Nov 12, 2010 | Office Equipment & Supplies
I can't turn my canon i560 on. It is about 4
Try different outlets and if you still don't get power then for sure the printer is bad at that point.
May 11, 2010 | Canon BubbleJet i560 InkJet Printer
The waste ink well is full
Reset Procedures for Canon i560 Printers
  1. Turn off i560 Printers
  9. Please remember at some time of other you will need to clean out the ink pads that are inside the printer.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 22, 2010 | Canon BubbleJet i560 InkJet Printer
Printer quit printer will not come on
Jan 28, 2010 | Canon BubbleJet i560 InkJet Printer
The orange error light is flashing 5 times in between the green light.
Jan 27, 2010 | Canon BubbleJet i560 InkJet Printer
The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i560 printer
I have similar problem. I found this solution that may help you. My problem insists tho.
>>> 5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
8. Your printer should respond as normal.
May 28, 2008 | Canon BubbleJet i560 InkJet Printer
134 people viewed this question
old marine
old marine
