Question about HP iPAQ H5550 Pocket PC
HP H5550 keeps going blank and wont restart
From time to time my ipaq will not restart it has been in twice now and the engineer has stated that it is a build up of static and all it needs is a reset how do i do this as i have taken the battery out and tried what i believe is a hard reset can you help me?
  • wak68 Nov 26, 2008
    HOLA QUE TAL, MI EQUIPO SE QUEDO EN BLANCO Y APARECE UN CUADRO DE DIALOGO QUE DICE "Please do a FULL RESET. Refer to User Manual if necessary" ya presione el boton de reset de la parte inferior y sigue apareciendo ese cuadro.. ¿COMO HAGO UN FULL RESET?
  • 36 Answers
See manual for 5550 from hp.com for description of how to do hard reset. You can download it.
Posted on Oct 07, 2008
My IPAQ h5550 wont charge when plugged in there are no indications on the device this applies to all methods of charging.
I have had this problem before and found that if I put it on the charger for 20 minutes or so, (no lights), then did a hard reset (press the button on the bottom with a paperclip and hold the power button for 7 seconds) the lights would come on to indicate charging. If not, by now it is old and just may not work anymore. Good luck.
Sep 16, 2011 | HP iPAQ H5550 Pocket PC
What is the diff between hp h5550 and thwe compaq
Both are good the hp is more expensive than the 3955 if you are not the type that will use all available facilities , just go for the less expensive.
Nov 18, 2009 | Compaq iPAQ H3955 Pocket PC
HP Ipaq h5550 does not connect through cradle
First sorry for my bad english.I have a same PDA (acually its dead :-( ) And me too had this problem.Try moving a little bit your pda on cardle, or (this looks like crazy but actually worked for me) do not fully put in the cardle into pda.I mean dont stick in into cardle, just a little bit.
Jun 30, 2008 | HP iPAQ H5550 Pocket PC
HP iPAQ 5555
after full reset I am unable to access online capabilities
May 06, 2008 | HP iPAQ H5550 Pocket PC
Lying ipaq H5550!
It's a problem with either the memory board or the button board. With my h5550, the bottom buttons started to stop working and eventualy the PPC stoped charging all together. You can find parts for it online. If all the buttons are working fine, then it's most likely the motherboard. Otherwise it should be the button board.
Dec 29, 2007 | HP iPAQ H5550 Pocket PC
IPAQ h5550
I had to install several updates on my H5550 to get the wireless to work. You need firmware 1.10.10 to start with (the latest version), then there are several wireless firmware updates, and a wireless driver you need to install. I can´t remember what these were off the top of my head, but it might help point you in the right direction.
Oct 30, 2007 | HP iPAQ H5550 Pocket PC
Turn Portrait Display to Landscape on h5550
It can't be done with the standard softwrae, but here's a utility that will do it.... http://www.nyditot.com/Home.asp
Sep 11, 2005 | HP iPAQ H5550 Pocket PC
Battery
If you take a look on the back of your battery, it will give you a mAh value ie 1550mAh, the higher the number, the longer it will last.. most replacement batteries are 1550mAh, and very cheap, but you can get 3000mAh batteries, which should last twice the time, but they´re as much as 5 times as expensive... they obviously take longer to charge too..
Sep 08, 2005 | HP iPAQ H5550 Pocket PC
HP iPAQ H5550 Pocket PC Logo
165 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
