Question about Northgate Computers & Internet
My monitor for my Northgate computer died can you tell me what monitor would be compatible with my system?
  • 3,940 Answers
Most any monitor should work on your system. The only real limitations are the display capability of your video card. Most video cards will display up to a 22 inch monitor without any problem. Here are a couple suggestions
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001268&cm_sp=DailyDeal-_-24-001-268-_-Homepage
http://www.newegg.com/Store/Category.aspx?Category=19&name=Monitors
Posted on Jul 16, 2008
Connecting hp photo smart 7350 printer to northgate computer
You need to install the driver of your printer that works with the operating system of your northgate computer. The driver is in the CD/DVD that came with your printer.
After installing everything, you can add RadarSync to your computer to optimize your computer's driver (eg. keeping them updated to avoid from some problems, and running automatic updates so that you can avoid from the headaches of doing the updates manually).
I hope this helps.
If you need more info, please let me know.
Carlo
Jan 23, 2013 | Northgate Computers & Internet
The computer monitor viewing screen continues to flicker and change color tints at random moments. It makes it difficult to view the monitor screen clearly. I would like to know how to solve this problem...
have you made sure the video cable is plugged into the screen and the back of the computer correctly. You could also try a new video cable, because the problem may be that the wires inside the video cable have frayed. If that doesn't fix the problem you could try using a different monitor and see if you can replicate the same problem with a different monitor, if you can, the computer may have a problem with the graphics card. If you can't replicate the problem with a different monitor, it seems as though your northgate innovations monitor has developed an internal fault, if the monitor is within warranty try and get a free repair or get it replaced (if you have the receipt.
May 02, 2011 | Northgate 17" LCD Tilt Screen Innovations...
Ist there a driver that will allow my Northgate 7nss monitor work properly with windows 7?
1.Drivers are usually given by the manufacturer to work with the latest OS (operating Systems).
Sometime Windows 7 will detect the device and input the drivers it has in it "cab files" but if not present it will prompt you to look online to the manufactures website for updates or it will ask you to run the compatibility wizard .
2. Windows 7 has an option also to run the device in another operating system mode such as Windows XP and may have the drivers stored in the "cab files" for Windows XP for example. If not the manufacturers device will not run in the Windows 7 environment.
Apr 21, 2010 | Northgate 15" LCD Tilt screen Innovations...
Northgate vt7v71 monitor power led will come on when i turn it on ,but get nothing on the screen . was wondering if there is a repair manual out for this monitor. have already plugged monitor into...
You have to open uo the set and check for 12vdc feeding the backlight inverter circuits, if you do have 12vdc then the inverter circuits may be bad, also look for bad caps. see example of a couple years old failed monitors: http://s807.photobucket.com/home/budm/allalbums
Jan 07, 2010 | Northgate MONNG7NSS 17" Flat Panel LCD...
How do you fix a 90 degree tilted monitor sreen??
Ctrl-Alt-arrow key....try all arrows, one of them will correct it.
Dec 03, 2009 | Northgate 17" LCD Tilt Screen Innovations...
No sound from northgate ez18a monitor
Have you connected a cable (3.5mm plugs at each end) between the mintor and the sound port on the P.C.?
Oct 24, 2009 | Northgate EZ18A 18" Silver 1280X1024 LCD...
Mo picture on monitor
I had the same problem. power led would flash green for a few minutes then the monitor might come to live. the problem was multiple bad G-LUXON capacitors on the power supply board and inverter. the monitor is full of them. just search online for bad caps and they are near the top of the list. replaced them and it came back to life.
Jan 24, 2008 | Northgate MONNG7NSS 17" Flat Panel LCD...
Computers & Internet Logo
227 people viewed this question
Top Northgate Computers & Internet Experts
Lee Eismann
Abhinandan  Patil
Abhinandan Patil
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
