Question about Sharp AR 163 Copier
AR-163 COPIER THE SERVICE INDICATOR IS FLASHING AND ALSO THE INDICATOR SUGGESTING THAT DEVELOPER IS REQUIRED HOW DO I CHANE THE DEVELOPER???? brianenglish
  • Rashid Hakim Nov 12, 2008
    A flower simbol is always lit. If I need to change the developer, then I do I go about doing it? Do I need to carry out some programing to reset the warning
    info? how?
Is giving error found
Posted on Oct 10, 2008
HOW TO CONNECT PRINTER TO COMPUTER
This can be connected via a USB cable in standard configuration. If you want to attach to a network you will require a network interface option to be fitted.
Jan 27, 2014 | Sharp Copier Developer AR-201 202...
The error message is a symbol for of human being and a circle and dots around it.
A circle with dots around it indicates that the machine requires a developer change.
This should only be carried out by an engineer but you can still use the machine whilst this status light is up.
A red man indicates that a routine service is required.
hope this helps
Feb 10, 2011 | Sharp AR 163 Copier
A brod white patch on centre con copy Sharp AR 163
check the developer in the developing unit maybe the developer is empty,then also check the charging assembly maybe its pour of toner just try to clean
Sep 03, 2010 | Sharp AR 201 Copier
My sharp-Ar 163 is showing developer sign
enter simulation... c-auto-c-auto.... enter 42-1; dev icon disappears; for every 50K, use 42-1
Jul 07, 2010 | Sharp AR 163 Copier
My machine is sharp AR-163 and is showing developer sign and ch sign
developer probably needs changed. CH means you have a cover open
Dec 08, 2009 | Sharp AR 163 Copier
Indicating U 2
there will b something else in front of u2 press start to see
Sep 11, 2009 | Sharp AR 163 Copier
Sharp AR-287 HR-00 error code
I'm sorry for not getting back to you sooner - I lost track of this question. If you still need this info here it is :
H3-00 indicates a temperature problem in the fuser unit. not reaching a certain temperature within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Mar 30, 2009 | Sharp AR 163 Copier
Sharp AR-163 Copier
replaced your toner cartridge with a new one, if you install a new one and it didn't work and still F2 flashes, the cartridge that you buy is not suitable for your country, always ask for a genuine toner, do not use compatible toners for your copier.
May 01, 2008 | Sharp AR-163 All-In-One Laser Printer
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
118 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
