Horizontal Lines on LCD
Hi i have Advent 7109A Laptop.There are horizontal lines on LCD.Sometimes these lines become bold.Area under these lines seems magnified.Can u plz propose a solution.Thanx
  • aman_81 Jul 16, 2008
    No these lines are not continuous.And magnifier is also turned off.It seems that there is some LCD cable problem.Anyways thanx for ur assistance.
  • 3,940 Answers
Make sure that you don't have windows Magnifier activated by mistake
http://www.microsoft.com/windowsxp/using/accessibility/magnifierturnon.mspx
Posted on Jul 16, 2008
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
How do I fix my Sharp tv model LC-42D62U? On the tv screen now shows horizontal lines with repeating ghost images.
Hi Paul,
The horizontal lines on the screen are virtually NEVER caused by a bad T-con board. These horizontal lines indicate a defective LCD panel (screen). The Screen has small ICs that become defective overtime and that it isn't fixable unless replacing the entire screen.
Sep 13, 2015 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Horizontal lines samsung lcd tv, then more horizontal lines, then complete static out, TV restartes itself. after a 5 minutes or so, it seems fine.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 04, 2015 | Samsung Televison & Video
Horizontal Lines Across LCD of Acer Advent 5431
sounds like a poor connection if computer is still under warranty send back to the manufacturer ... that should be covered as a defect...
Nov 19, 2012 | Acer Aspire 4720 Notebook
Compaq C700 laptop screen shows horizontal lines and the screen seems to be split into several sections
The LCD screen is faulty and will need to be replaced, go to www.ebay.com Type: make and model refine search to screen, first! hook a spare monitor to the video output usually on the back, if picture okay! the above mentioned needs to be changed, but! if both show the same symptom it is the video graphics card that is part of the motherboard.
Apr 19, 2012 | Computers & Internet
Inspiron 1525 horizontal lines missing
You can try to uninstall and reinstall the video driver in dev manager. try to check if this happens in bios aswell if it does then it may be the lcd itself.You can contact the manufacturer to have the lcd replaced if your computer is still under warranty.hope this helps...
May 23, 2010 | Dell Inspiron 1525 Laptop Midnight Blue
Black and white horizontal lines in my asus a3000N laptop
Sound like the cable was lose between LCD panel and Motherboard. You can't do by yourself. Hope the laptop is still under warranty repair.
Nov 11, 2008 | Computers & Internet
Black screen with horizontal green lines
Hello yoyoxide.
from my experience can be something related with the video card. I recommend you the followig (Hardware diagnostics):
-Look for one of the discs that came with your computer, it should say (Drivers & utilities).
-Boot from the CD. If you don't know how to do it do the following:
1.Insert the Drivers&Utilities Disk.
2.Restart teh computer.
3. When you get the Dell logo, press F12
4.Select Boot from CD/CDRW-DVD (something like that).
-You will get a prompt to run the diagnosics.
-Just follow the wizard
-I recommend you to run diagnostics for everything.
-You will see if you have any problems with your hardware.
It seems that you have a pretty new laptop, so probably it's under warranty.
Jun 28, 2008 | Dell XPS M1330 Laptop
SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
Mar 21, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
After a household power blips during bad weather, we have horizontal lines ....
Unfortunately there isn't any way to repair your tv as the magnet has distorted the tube that is in the tv and with CRT becoming obsolete the repair is likely to be very costly so probably your chaepest option is to buy a new tv .
Mar 13, 2008 | Televison & Video
Computers & Internet Logo
186 people viewed this question
David Payne
David Payne
