To find a bluetooth passcode click tis link bp to change passcode click tis cp to reset rp
Step 1
Look on the back of your headset or speakerphone for the
Bluetooth passcode for the device. Typically the pairing code for
headsets is printed on a sticker that is then placed on the underside of
the accessory.
Step 2
Go into the Bluetooth menu on your cell phone to find the
passcode for your cellphone. The Bluetooth menu for your phone is
typically located under the "Settings" menu. In the Settings menu there
should be an option to "Get code" or something comparable, which would
allow you to find the code for your phone.
Step 3
Go into the Settings menu for your computer to find its
Bluetooth passcode. Some laptops will randomly generate a new Bluetooth
passcode for you each time you want to pair them with a new device. In
that case the menu setting you're looking for is something like
"Generate new pairing code."
Step 4
Look in the instruction book for your Bluetooth accessory if
you cannot find the passcode attached to the device or in its menu. Many
manufacturers will print the passcode for devices in their instruction
book. If you still can't find the passcode, try using all zeros.
Step 1
the accessory.
Step 2
Step 3
Step 4
Step 1
the accessory.
Step 2
Step 3
Step 4
Your "Passcode" is setup when you "Pair" with another Bluetooth appliance.
e.g If you want to connect to your friends phone via bluetooth to send a picture you would send via bluetooth and search for bluetooth device. When you select the one you wish to connect to it will attempt to "Pair" with it. At this point a "Passcode" maybe asked for if the bluetooth device you are pairing with has one set. If it does then you need to ask the person who owns the device for the "Passcode" before your picture can be sent/recieved.
Normally if you wish to set a passcode for your device it will either be in your bluetooth settings. Possibly even in "Security" in the bluetooth settings or it may just be in your "Security" settings.
base on my experience on using the bluetooth on any mobile phone.. there is no permanent passcode in it.. you can set any passcode everytime you make a connection to another phone.. if someone you know sent you a file thru bluetooth the connection will ask a passcode from then you type any passcode then make sure you tell the sender what password you set on your bluetooth to make the connection..
