Question about Microsoft Xbox 360 Console
Two red rings
Right when i turn on the x 360 it starts withe 2-3 green lights than goes to red and makes a weird sound, what can i do? i did open it, is there something i can fix.
  • 29 Answers
I suggest you to try DIY Guide that wil explain solving the 2 flashing red lights along with some other common problems of Xbox like Disc Read Error, No Video Problem and most famous RROD. Even a novice can solve the problem with the help of step by step process given at the guide. I think it's worth trying. If you try this method, you won't have to wait for 3-4 weeks and you can enjoy your gaming experience within 2 hours, once you try this guide.
Posted on Mar 14, 2009
This mean the hardrive is over heated or someone hited it. so u have to get it repaired u have to pay $100 to fix
Posted on Jul 18, 2008
  • 116 Answers
That meas your xbox is broken
When i turn my xbox 360 on, i have 3 red lights,i know this is the ring of death but when the power brick is on it should be a green light but turns orange after about 2 seconds, the three red lights are...
Hi honyimhome,
there is only one way i know of correcting this situation.
as weird as it sounds
you need to overheat the xbox 360 in order to get it working correctly again. i know this as i have one myself and been in the same situation.
you need to switch the console on then wrap a towel around it and leave it for approx 30mins.
this should return it to its correct working order.
Hope this has helped :)
Sep 26, 2009 | Microsoft Premium System for Xbox 360
2 red lights on the ring of light
your xbox 360 is overheating its called the red ring of death look it up on google you can have microsoft fix it if you still have a warranty on it, it shuts down so none of the components in the xbox 360 get damaged
May 30, 2009 | Microsoft Xbox 360 Console
Three red lights on the ring of light is an indication of a hardware failure
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Check the light on the power supply ( The big brick that goes to your wall )
If the light is green that means the power supply is OK
If the light is Red that means the power supply needs to be replaced
3. If above steps doesn't work, you need to contact xbox customer support to get your xbox repaired
and shipping and handling will be covered.
Apr 14, 2009 | Microsoft Xbox 360 Console
My xbox 360 has no picture but sound only no red lights green ok
First take off my hard drive on the 360. Then plug it to the tv not with HDTV (use the red, yellow and white make sure it is on tv not HDTV) because it will not work for HDTV setting . then plugit into the wall with the 360 laying down not up and down and turned it on. (no picture but sound) with the 360 on take 1 towel fold it long ways and wraped it around 360 from back to front (make sure you cover the fans in the back to make it over heat.) leave your 360 on until it red rings (you can hear the 360 quit down. it takes about 15-30 mins depending on how fast it over heats. once this happens unwrap the 360 and turn it off wait 5 secs and power it back on and there you go you should have picture and sound again. if you still have problem you can now can send it to get repaired since there is a 3 year warrenty for red ringed 360's.
Feb 15, 2009 | Microsoft Xbox 360 Console
2 red lights w/green light
The problem is the black screws on the bottom of the frame that screw into the X-Clamps. Most of the time, you usually don't have to even put the black screws back in. However their can be exscruciating headache inducing problems with fine tuning the black screws. If you do end up needing to put the black screws back in, I suggest to start with one @ a time, starting with the bottom right screw. ( thats with the 360 standing vertical with the dvd drive faced toward U.) The tightness can range from almost as tight as you can possibly get to soooo!!!!!! loose u can't possibly imagine how its doing anything at all. The best way to do this is, with the 360 hooked up, (and the case left off) take the small white plastic frame off that covers the power button, start with the screw loosened and then proceed to turn slightly like an 1/8th of a turn, then power on and then turn off if 2 red or 3 red ring proceeds and then repeat. You shouldn't have to put all the black screws back in, mine only has bottom right bottom left and top left, and are incredibly loose. My friend however has bottom right only and is tightened only about 1/2 way.
Sep 21, 2008 | Microsoft Xbox 360 Console
Xbox 360 problem
If you can still HEAR sound, but can't see. Check your Audio Video Cable.
It's the colorful one (red, white, yellow) (red, blue green, white, red)
Make sure the connections are secure into the back of the TV as well as the connection to the back of the Xbox 360.
Jul 18, 2008 | Microsoft Xbox 360 Console
How so you fix the red light ring?
it the red light os death and ill tell u how to fix it .........unplug everything but the power cord....turn it on and rap it up in 3 or 4 towles yes i no it sound weird but do it anyway make sure its raped up all around with 3 or 4 towels and leave it for 25min no longer.......after 25min is up unrap it shut it of and let it cool for 15min....what u just did is over heat the chips in your 360 and it reset after 15min turn it on and there u go it works post me back when u do it tks
Jun 06, 2008 | Microsoft Xbox 360 Console
360 issues
Two Red Lights
The two left quadrants of the Ring of Light flash red on the front of the Xbox 360 console
This behavior occurs when the internal temperature of the console exceeds the acceptable limits. You may think of this as too hot, overheating, and so on. Make sure the fans are operating and the system has adequate ventilation.
Since you've been inside it's possible that a heatsink or some other part of the cooling system is not working properly or is loose. Check all these!
Good Luck!
Nov 17, 2007 | Microsoft Xbox 360 Console
Xbox 360 red lights
2 red lights flashing is'nt too bad of a deal. just reposition your xbox 360 to a place where more airflow can get to it. plus, dont have anything that gives off heat near the xbox 360, thats vary important to give it room for cool air. it worked for me
Nov 15, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
35 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
