Question about Maytag 24 in. MDB8751AWS Stainless Steel Built-in Dishwasher
Not able to select/change electronic operating buttons (cleaning options)
Hello, bought this model maytag dishwasher used from a reliable source. after installing, the electronic (digital?) operating buttons to choose cleaning options (heavy, normal, light wash options, etc, etc) are not allowing me to change options; the unit is already set on certain options (light wash - I want normal or heavy wash & sanitizing option & scrub option). any help will be greatly appreciated. thanks so much!
  • kpeckett Jan 29, 2009
    I have the same problem. I can select between heavy or light wash and cannot change anything else. Delay will work, but screen does not show anything, so I guess.
5 Suggested Answers
  • 70 Answers
SOURCE: Maytag Quiet Series 300 Dishwasher not working (Model MDB5601AWS)
in such cases it is always the control panel(touch panel) that needs to be replaced.it is very simple 2 chg and u could save lot of money.to chge cntrl panel ,open the door and remove all the screws around the white plastic part of door.then pull apart the inner part from outside part.the cntrol panel is held to outer panel with 4 screws.b4 that remove 2 screws holding the control board to panel.do not forget 2 unplug the unit from power b4 doing anything.
Posted on Aug 22, 2009
SOURCE: My Maytag steam dishwasher # MDBH980AWS won't do
My Maytag dishwasher # MDBH950AWW wont turn on no light but it has power in the outlet no power to the control board
Posted on Jan 21, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Maytag dishwasher
It is best to try a few different ones... different detergents work differently with the different dishwasher/water combo's... ya can never tell what the best soap will be till ya try them in your DW with your water...
Also get some TSP and add that it will help the soap work better...
DishwasherResidue and Film on Dishes
heatman101
Posted on May 04, 2011
  • 842 Answers
SOURCE: washer operates and displayes on insta wash but dose not on other options
First off, thank you for selecting Fixya as your goto place for answers. I am going to assume a few thing like the electrical cord is properly hooked up and the polarity in not reversed. Because if it is you will continue to have issues with the control board even after you replace it. Control board will be the problem here but can be caused by the polarity being reversed, but before you replace it you might want to check. I have found more board failure due to the polarity being reversed you would be shock. This is why, when reversed the power side will work for a while, but when the current changes direction or something else causes this to happen the board takes a hit, it will react confused and erratic. But yes, you will need to replace the control board to correct the problem you have today.Good Luck
Posted on Oct 22, 2011
How to change the view source without remote?
You can change it by pressing input selection button on the Front panel of the tv. Or there will be option in the menu to change the input .
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 14, 2016 | Televison & Video
Reset button maytag dishwasher
  • 1 Open and close the dooricon1.png of your Maytag dishwasher.
  • 2 Locate the "Rinse" button on the dishwasher control panel. Press and release the button five times in quickicon1.png succession.
  • 3 Press and release the adjacent "Drain/Off" button on the control panel two times; this will deactivate the dishwasher's demo mode and reset your dishwasher.
  • If you need to restart your dishwasher or forgot some dishes and want to open it during a cycle and restart it
  • 1 Press the "Cancel Drain" button on the display. Allow about 2 minutes for the dishwasher to completely drain.
  • 2 Choose a cycle under "Cycles" on the panel.
  • 3 Select an option or options under "Options" on the panel.
  • 4 Push the "Start Resume" button.
  • Oct 24, 2013 | Dishwashers
    The normal wash and cancel options keep flashing and no other options can be selected, dishwasher doesnt run
    What this need to be able to operate it self again is to put off the power for some time from the main power supply(wall) allow the washer for some time clean every part that can be expose to water carefully with a dry cloth . then connect the washer back to power supply carefully then operate it as it's expected to be operated.
    Thanks for using fixya.
    Jul 31, 2011 | Dishwashers
    How can i set my dishwasher to just rinse and heated dry?
    Hello, Thank You for using FixYa. I will be helping you today.Some models do not allow you to use heated dry for rinse. If you cant select the option after pressing rinse then it will not work on your unit.
    Thank You and please rate my answer if it was helpful..
    Jun 22, 2011 | Maytag Dishwasher
    Water is not coming into my Maytag dishwasher.
    Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
    Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
    Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
    Is the control lock option activated?
    The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
    Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
    Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
    Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
    Error msg: Paper tray empty or jam, when there is not
    Clean The Paper Feed Rollers Using The Unit's Operation Panel Ifthe paper feed roller is dirty, paper is not fed properly because thepaper feed roller slips. Cleaning the paper feed roller could resolvethe paper feeding problem. Please follow the instructions below toclean the Paper Feed Rollers directly from the unit. Caution:Since the cleaning process wears down the paper feed roller, performthis procedure only when necessary and no more than three (3) times.
    1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
    2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for additional information.
    3. Press the <Menu> button.
    4. Use the right / left cursor button to select [Maintenance/settings] press the <OK> button.
      Note: This procedure is skipped if your machine is in Scan mode. Proceed to step 5.
    5. Use the right / left cursor button to select [Maintenance] and the press the <OK> button.
    6. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
    1. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
    2. Tocheck if the rollers are clean, load a sheet of Letter-sized plainpaper in the same paper source you selected in step 2, and press the<Open> button.
    3. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
    Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
    Paper Source
    Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
    Cassette
    Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Sourcesetting in the printer driver. If the option is not set to 'Paper FeedSwitch', paper will feed from the source selected in the driver.
    Nov 27, 2008 | Canon PIXMA MP830 All-In-One InkJet...
    Canon PIXMA MP600 printer - paper feed
    Issue: Paper feeds skewed
    Solution: Clean The Paper Feed Rollers Using The Operation Panel - MP600
    Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary.
    2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for here additional information.
    3. Press the <HOME> (A) button.
    4. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Settings], then press the <OK> button.
    5. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Maintenance], then press <OK>.
    6. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
    7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
    8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2.
    9. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
    10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Paper Source
    ASF
    The above illustration shows a PIXMA MP500
    Cassette
    Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
    Click here to return to step 2
    May 31, 2008 | Canon PIXMA MP600 all-In-One InkJet...
    Electronics problem with Maytag Dishwasher
    the outlet pump may have become clogged, try removing and cleaning it.
    Mar 26, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
    MAYTAG DISHWASHER MODEL MDB7100AWQ
    My MDB7100AWQ has suddenly stopped working. It will fill but then stops and will not move into wash. When I press the drain/off button the lights work but it does not drain. I do hear a switch in the door operate when I press the drain/off.
    Jan 21, 2008 | Maytag 24 in. MDBH950AWS Built-in...
    Maytag 24 in. MDB8751AWS Stainless Steel Built-in Dishwasher Logo
    32 people viewed this question
    Top Maytag Dishwashers Experts
    Charles T Nevin
    Charles T Nevin
    Mike
    Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
