Question about Whirlpool LSB6200KQ Top Load Washer
Washer isn't spinning at all
The washer sounds like it is trying to spin, but no motion--
  • 4,889 Answers
There are several things you can try. First of all try to spin the tub manually. If it spins then its probably a clutch problem otherwise there may be a nut, bolt etc., that might be preventing the tub from spinning. If none of this works then check the belt it is most likely to be the culprit..
Posted on Jul 16, 2008
  • 327 Answers
Welcome to fixya
Belt could be slipping or the motor could of went
could be also your filling the washer to full of clothes
check the belt and the motor first
hope this helps out have a good day :)
Washer will not go threw all cycles and leaves clothes wet
Sounds like a broken motor coupler if it's a whirlpool made direct drive washer.
Aug 29, 2017 | Washing Machines
I own a Whirpool Washer machine model LSC6244AW0. I noticed that when the machine is on, the washer agitator spins while the Agitator Auger does not spin. It usually sits in place and sometimes, when
jason,it sounds like your agitator dogs are worn can try just the dogs,part#80040 for about 3 bucks or do the cam kit part#285811 for about20.appliance parts has a video to help you find the right part for you.hope this helps.
Nov 20, 2014 | Washing Machines
My amana washer barely spins but makes a jackhammer sound in spin cycle
The "jackhammer" sound is that the load (and hence, the "basket" it's in) is out of balance, causing the basket to spin in an eliptical motion.
Some washer (like mine) will momentarily shut off when it senses this, and restart when the basket slows down enough to make the out of balance condition go away, unless it starts in again, then it'll shut down again and restart.
If this is what is happening, the washer keeps shutting off and restarting, making it appear that the basket is spinning slowly, as it never gets up to full speed.
Try redistributing the load when this happens.
Also, the usually is a spring arm with a rubber "snubber" on the end that presses against the top of the basket, to help dampen an out of balance condition.
The spring over time weakens, and the dampening action is lessened.
Sep 08, 2013 | Amana Washing Machines
Loud clunking, banging sound during the spin/drain cycle.
the make , model and year are missing but if it is a top loader unit , it indicates that the tub suspension bar motion absorbers have broken and need replacing
Sep 06, 2017 | Whirlpool Duet GHW9150P Front Load Washer
My samsung WA10R3 won't spin - it making a noise as if its trying to spin but the drum isn't turning and the water isn't coming out Thanks
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Aug 11, 2011 | Samsung Washing Machines
I have a Whirlpool WFC7500V Front Load Washer and after the load is done the clothes are still soaking wet, is there a step i am missing why are the clothes still really wet. Do i need to drain or is the...
What spin cycle are you using? Try a faster spin option. (The wrinkle release setting uses more water and a lower spin speed.)
Try putting fewer items in a load in the futute and make sure it isn't unbalanced. (One really heavy item could imbalance the load and shift the spin efficiency.) Redistribute the clothes and run a Drain/Spin cycle.
Make sure to use HE detergent (don't use more than the recommended amount of detergent).
The other issue to check is if the machine is draining properly. Check that the drain hose isn't clogged. Also check the voltage at the washer - low voltage will result in a slower spin cycle. To correct this, you probably will want to call an electrician.
I hope this helps.
May 05, 2011 | Whirlpool Washing Machines
There is a knocking sound on the left side of the washer when it goes to spin cycle.
Sounds like the tub is hitting the wall of the washer. One thing to check is if the cloths are evenly distributed in the washer. If to many are on one side then it will spin out and bang. Also make sure the washer is level. If it is leaning one way to far it will also spin in that direction. You might want to check the belt as well. If that belt is severely worn and has stretched out then it will spin in a wider motion and bang the wall of the washer. These are the thing to check that would cause the problem described.
Regards, Tony
Apr 07, 2011 | Washing Machines
When the washer spins with a heavier load like towels or jeans, it makes a horrible sound off and on. It sounds like something rough scraping against another rough surface. Is this something my HVAC...
Sounds like the bearings may be going out. Quick check for bad bearings: Open door, grab spin basket lip, yank on it; up and down works best. If you can get your fingers on the white plastic outer tub lip try to determine if the metal spin basket is moving independently from the outer tub in any motion other than round and round. If so you're rear bearings are becoming worn and will be especially noisy under a heavy load.
Jan 06, 2011 | Whirlpool GHW9100L Front Load Washer
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Whirlpool LSB6200KQ Top Load Washer Logo
141 people viewed this question
Dan Webster
Dan Webster
Sal De
