Question about HP LaserJet 2200dn Printer
Printer has fatal error
Hi, I have a 2200 DTN and it recently ate and spat out a cockraoch, Since then it won't print. When you turn it on the normal light show happens, and it ends green and middle light steady. When you press the "Go" button, all three lights illuminate steady (FATAL ERROR) according to the website.
When you press the "GO" and "RESET" buttons at the same time you get flashing front and back lights (is that General I/O?).
WHen you press the engine test button all is well.
I have removed the EIO card altogether, and I have removed the DIMM as well.
Any suggestions?
  • 233 Answers
Check the sensors
Posted on Jul 16, 2008
The paper stopped and the printer ate the paper then the sound is like making me panic! what to do?
Hi, first thing to do is turn off your printer. Please remove all jammed papers, and turn it back on. Everything should be back to normal when you print another document.
Aug 07, 2011 | Epson Stylus Multifunction Inkjet Printer/...
HP Color LaserJet 3800 dtn printer. Error message says 49.4C06 Service Error
49.XXXXX ERROR A critical firmware error has occurred.
If the message persists with different programs and print jobs, turn the printer off.
Remove all memory DIMMs or thirdparty DIMMs from the printer. (Do not remove the firmware DIMM in the lower slot J1).
Remove the printer EIO card.
Turn the printer on.
If the error does not persist, install each DIMM and EIO device one at a time.
Turn the printer off and then on again after installing each device.
Replace DIMMs and EIO devices as necessary.
If the error persists, replace the firmware DIMM.
If the error persists, replace the formatter and calibrate the printer.
Jun 16, 2011 | Office Equipment & Supplies
HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Jan 05, 2010 | HP LaserJet 4350dtn Printer
Epson stylus 2100 not running on Mac: all the lights flashing, printing will not work?
epson does not make a 2100 model, please recheck,
but accoding to a 2200 model,
if all blink but the power, its a cutter position sensor
if all blink at high speed except power, its a fatal error
if paper blinks and then the inks blink, alternately, then its a maintenance error, and the pads need replacing as printer needs to be reset.
Jun 11, 2009 | Epson Stylus Photo 2100 InkJet Printer
All Lights Blinking Fast
You can try add that printer again.... from Printers and Faxes!!!!
Mar 25, 2009 | OKI C3400n Laser Printer
Adding IP addresses to a HP 5550 DTN printer
ok then install that printer as a network printer to one pc share ti and ad to as much pc you need after that without ip adress
Dec 10, 2008 | HP 5500 Color Laser Printer With Internal...
Fatal error 002
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
Take the printer off the network. (Remove the network cable) Then enter the menu and select network menu. You want to change the settings as described below:
Change the Hublink Setting to "100 base tx full"
Change the FTP Setting to "Disable"
Once done and machine says online, shut it off, reattach the network cable and restart the printer.
You may also want to change the printer's IP address.
If this does not help, or you cannot get past the 002 fatal error then the machine will require service.
Aug 08, 2008 | OKI C5200n Laser Printer
HP Laser Jet 2200 dtn - Print Quality
For troubleshooting "ghost printing" use "LaserJet 2200 repetitive defect ruler". Measure the distance of 'ghost' figure from the 'original'
Try this link:
Jan 05, 2008 | HP LaserJet P2015dn Printer
Printer problem
I would like to help, but what do you mean by "lean on"? I'm sure it's probably a typo, but I can't figure out what it's supposed to be, my neural connections aren't working I guess ;] Please post a comment with an explanation, and we'll all do our best to help.
May 16, 2006 | HP LaserJet 2200dn Printer
HP LaserJet 2200dn Printer Logo
194 people viewed this question
Ben Johnson
