Question about Electronics - Others
I recorded a DVD on dual layer DVD
I recorded a 105 minutes long movie on a dual-layer DVD. Now it only plays up to 54 minutes then the playback freezes. I tested it on various DVD players and computers and everytime it freezes at almost the same spot.
I also tried to copy the DVD but I get the same errors.
  • Anonymous Jul 16, 2008
    The size of the movie is 6.8GB
  • 3 Answers
The size of the movie in terms of gb?
may be after writing first layer of the dvd, while going to 2nd layer problem starts
Posted on Jul 16, 2008
Whats a dual layer disc mean then?
A dual layer disc is a DVD which is able to hold double the info.( http://en.wikipedia.org/wiki/DVD#Dual-layer_recording )
Dual-layer recording (sometimes also known as double-layer recording) allows DVD-R and DVD+R discs to store significantly more data-up to 8.54 gigabytes per disc, compared with 4.7 gigabytes for single-layer discs. Along with this, DVD-DLs have slower write speeds as compared to ordinary DVDs and when played on a DVD player a slight transition can sometimes be seen between the layers. DVD-R DL was developed for the DVD Forum by Pioneer Corporation; DVD+R DL was developed for the DVD+RW Alliance by Philips and Mitsubishi Kagaku Media (MKM).[23]
A dual-layer disc differs from its usual DVD counterpart by employing a second physical layer within the disc itself. The drive with dual-layer capability accesses the second layer by shining the laser through the first semitransparent layer. In some DVD players, the layer change can exhibit a noticeable pause, up to several seconds.[24] This caused some viewers to worry that their dual-layer discs were damaged or defective, with the end result that studios began listing a standard message explaining the dual-layer pausing effect on all dual-layer disc packaging.
DVD recordable discs supporting this technology are backward-compatible with some existing DVD players and DVD-ROM drives.[23] Many current DVD recorders support dual-layer technology, and the price is now comparable to that of single-layer drives, although the blank media remain more expensive. The recording speeds reached by dual-layer media are still well below those of single-layer media.
There are two modes for dual-layer orientation. With Parallel Track Path (PTP), used on DVD-ROM, both layers start at the inside diameter (ID) and end at the outside diameter (OD) with the lead-out. With Opposite Track Path (OTP), used on many Digital Video Discs, the lower layer starts at the ID and the upper layer starts at the OD, where the other layer ends; they share one lead-in and one lead-out.
Jun 16, 2011 | Nintendo Wii Console
What does memorex dual layer dvd+r mean? How do you record a movie that is over 130 min. We purchased 240 min just for this reason and we can not get it to record over 120. How do you finish recording the...
Well all DVD+R mean that when you finish copying files to the disk, the disk will lock itself and not allow any more files to be burned onto that DVD. The reason why you can'f fit your movie onto the disk is because the movie file may be bigger than the amount the DVD disk can hold. Just because the time of the movie is less than what the DVD can hold, doesn't mean its going to fit. Take for example a Blue ray movie, it may only be 120 minutes long but the file of the movie can be over 2 GB of space.
May 12, 2011 | Memorex Products - Memorex - Dual-Layer...
I recorded video from my Sony Handycam to the RH387H HDD and then wrote the video onto a DVD-R disc using the XP setting (instead of SP, LP.....). The disc can only playback now on the LG387H, but cannot...
make sure the disk is finalised after recording, if this does not help then the bit-rate it uses for xp may not be compatable with other dvd players, in which case stick to sp,lp or dual-layer sp is best if ou can.
Jan 25, 2011 | LG RH1999H DVD Recorder/HDD Recorder
How to burn dual layer dvd with windows dvd maker only 150 minutes pie showing
Everything is the same except you have to choose "DVD-R 9.0G" at the bottom of the DVD maker window. R4.5G is single layer and 9.0G is dual layer.
Let me know if you need more help,
Sai.
Apr 02, 2009 | ASUS P5GZ-MX Motherboard
Dvd player only plays some movies
it might be sevral reasons:
1. Check if region code is the same for movies you playing and DVD player
2. If you using video CDs or copyed DVDs, player might be preventing to playback those kind of discs, due to copyright laws or due to different speed settings for DVD player and discks you using (for intsrance you player can playback DVD/CD+R, and you using DVD/CD-R, or mximum allowed playback speed is 16 you using disk recorded at 24, but this is in case you using burned/copied CD/DVDs)
3. Check it lens is durty. For that use CD/DVD lens cleaning disk
($6 in Walmart, if you are in US)
4. Check if movies you are have the same coloring system, i.e NTSC for US
5. Check CD/DVD for scratches, some DVD players can not playback scratched disks
Please kindly let me know if my information was helpfull for you or you need more info
Good Luck
Feb 01, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Player freezes on Dual-Layer DVD+R's... any ideas?
Its probably compabitilities issues. Try -rs. There a lot better since they are more known type and technology. the difference is +r have more editing features but in your case it doesn't matter because your just copying.
Dec 31, 2007 | Philips Magnavox MWR10D6 DVD Recorder
DVD Freezes during playback
it might be that you are playing a dual layer dvd in the player. The player needs to focus on the second layer of the movie, and that might be why the dvd freezes. Leave it there for a while and the dvd should continue if it is this situation.
Dec 08, 2007 | Sony AVD-C70ES DVD Player
Record on DC210 and playback on home DVD
You should absolutely be able to play the recorded DVDs from your camcorder in your DVD player, as long as you remember to finalize the disc and the disc is compatible with the player. If your DVD player is less than five years old or so, you should be fine, provided you're not using dual-layer discs.
Dec 02, 2007 | Canon DC210 DVD Camcorder
Electronics - Others Logo
46 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
