Question about A4tech PK5
Desktop properties (desktop and screensaver tab is missing)
My desktop and screensaver tab is missing in desktop properties due to virus attack. Is there a way to recover those?
  • 3 more comments
  • Anonymous Aug 11, 2008
    Due to some virus attach, i am not able to change my desktop & screensaver settings. Even the same are missing. Please advice what should i do to recover that.
  • Anonymous Aug 20, 2008
    screen saver option gone
  • adeeltariq Aug 21, 2008
    My back ground , screen saver and desktop properties are missing
  • chamacos4 Oct 31, 2008
    I Can't change my Desktop Back ground.
    Please Help with solutions.
  • Anonymous May 21, 2009
    There is no tab in policies like NoDispScrSavPage.Even after i created it and set the value as 0,the effect is the same.The tab is not enabled.
The following is solved me
Well if anyone is interested and for general knowledge these are the 3entries that were killing the Desktop and Screen Saver tabs in XP. Hupigon13 seems to be at the root of it all.
Quote: Microsoft.Windows.System: Settings (Registry change, fixed)
HKEY_USERSS-1-5-21-1343024091-1060284298-1011862931-1004SoftwareMicrosoftWindowsCurrentVersionPoliciesSystemNoDispBackgroundPage!=W=0
Microsoft.Windows.System: User settings (Registry change, fixed)
HKEY_USERSS-1-5-21-1343024091-1060284298-1011862931-1004SoftwareMicrosoftWindowsCurrentVersionPoliciesSystemNoDispScrSavPage!=W=0
Hupigon13: Settings (Registry value, fixed)
HKEY_LOCAL_MACHINESYSTEMControlSet001ServicessrImagePath=...SystemRoot...
Read full story here
http://forum.osnn.net/showthread.php?s=f44e1bb094fbae9305c9f0c9999c52e7&p=841430#post841430
Posted on Aug 25, 2008
Screen Saver Tab Missing - Display Properties Windows XP Screen Saver tab is missing from the Display Properties. The most likely cause of this is malware utilizing Group Policy Objects which enforces policies for system settings and/or user account(s) settings. The Group Policy for Hide Screen Saver tab will cause the Screen Saver tab to be removed from Display Properties when enabled. Group Policies are typically applied at businesses to control access to programs, system properties, and user account settings. For Home users, Screen Saver tab can be removed these Group Policies but usually malware is the culprit. If you are a home user and the Screen Saver tab is missing from the Display Properties and looks like the pictures below then there is a good chance you are infected with malware.
NOTE: Ensure your computer is malware free before applying the following solutions.
CAUTION: Before making any changes to the Windows XP Registry, please backup your Windows XP Registry using the direction from "Using ERUNT to back up the Windows XP Registry". Manual Steps Using Group Policy Editor NOTE: The Group Policy Editor requires Administrative privileges and is only available for Windows XP Professional Edition. Windows XP Home users can use the Windows XP Registry method to remove the Group Policy restriction.
  • Click Start and then Run.
  • Type gpedit.msc in the Run dialog box.
  • Press ENTER on your keyboard. In the Group Policy Editor navigate to: User Configuration > Administrative Templates > Control Panel > Display Double-click Hide Screen Saver tab.
  • Select Not Configured.
NOTE: If the Screen Saver tab is missing on a per User account basis then the above method will not work, you will need to use the Registry Editor to remove the Group Policy.
Manual Steps Using Windows XP Registry
  • Type regedit.exe in the Run dialog box.
  • Navigate to: HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System
  • Right-click NoDispScrSavPage to select Modify.
  • Change the value to 0.
  • Navigate to: HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\System
  • Quit the Registry Editor (Regedit.exe).
NOTE: You may need to log off then log on to your user account or restart your computer for the changes to take affect.
Manual Steps Using REG ADD Open a Command Window.
  • Type: REG ADD "HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System" /v NoDispScrSavPage /t REG_DWORD /d 0
  • Type: REG ADD "HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\System" /v NoDispScrSavPage /t REG_DWORD /d 0
  • Type EXIT and press ENTER on your keyboard.
NOTE: You may need to log off then log on to your user account or restart your computer for the changes to take affect. Automated Fix Using an Registration File Download ScrnSvrTb.Show.reg to a folder on your hard drive. Right-click ScrnSvrTb.Show.reg to select Merge. Now the registration entries are added for you.
NOTES: The ScrnSvrTb.Show.reg file is from my web server (http://www.lprf.ca). You also can view the contents of the ScrnSvrTb.Show.reg file by right-clicking the file and selecting Edit. You may need to log off then log on to your user account or restart your computer for the changes to take affect. Platforms Tested Microsoft Windows XP Editions Related Articles Desktop Tab Missing - Display Properties Appearance and Themes Tab Missing - Display Properties Settings Tab Missing - Display Properties Theme Tab Missing - Display Properties Password to Protect Restricted (Greyed) - Display Properties Screen Saver Restricted (Greyed) Part 1 - Display Properties Screen Saver Restricted (Greyed) Part 2 - Display Properties Screen Saver Timeout Restriction (Greyed) - Display Properties
Posted on Oct 31, 2008
    Scholar:
  • 82 Answers
Friend it will depend upon the extent of the virus attact, if the extent is much the there is the possibility that you won't anymore those. The best solution for your problem is to clean your computer with an updated antivirus program. If in case your virus attact is severe and you cannot recover it anymore, you must reformat your OS.
P.S. please don't forget to rate.
Posted on Jul 17, 2008
I run a emachines EL 1200-05W and ever since I re-installed windows(due to a virus attack) I have had no sound. I tried downloading and installing Realtek software, yet no success. Please help.
you can download it from here
http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=1254
If you find this info useful please vote for me
Mar 29, 2011 | eMachines EL1200 PC Desktop
Computer screen is distorted due to changing background, desktop and screensavers. how can I clean it up?
right click on the desktop => properties => settings tab then select the screen resolution. adjust it. find the proper screen resolution for your desktop
Apr 05, 2010 | Computers & Internet
How to set screensaver?
hi
first of all u need to right click on empty space on desktop and then select properties,once u have done that u will get a screen named display property ,,,,,,on the top u will find the tab screen saver.....click on to that and then select the desire screensaver and click apply and close ..........
Aug 31, 2009 | Computers & Internet
My computer running Windows XP goes into Power Saving Mode without notice and I loose control over it. How can I get rid of this problem? I ran anti-virus, cleaned up the computer, pulled out the video...
Right on the desktop and choose Properties. Find the Power opiions in there and turn them off completely. It should be under the Screensaver tab.
Hope this helps
Chris (ziraffa)
Dec 31, 2008 | HP Pavilion a810n (PP164AA) PC Desktop
Screensaver problem
Umm... Screensaver issues can be related to many things. If you want to investigate this further, right click on the desktop and choose "Properties" from the menu that appears. Go to the Screensaver tab and check your settings. Aslo, make sure you have updated antivirus software and perform a complete system scan. This is a good start.
Oct 30, 2008 | Computers & Internet
Help me bout my xp
hi ,
firstly have u updated the anti virus.
please up date it.. and go to the control panel> add& remove program > microsoft office > change> repair >
i think it will fix it..
Sep 02, 2008 | Microsoft Windows XP Home Edition
Display Property For Windows XP
I just cleaned up a similar situation this weekend. Try this. Go into the control panel and create a new user id. Log off of your current user id and use the new one you created. See if the tabs are still there. If they are the virus trashed your desktop and you should create a new one.
Before you do that try scanning for viruses with the new desktop you just created. It might be that the virus exists on your old desktop and it won't go away because it is running. Checking for viruses using the new desktop can get rid of the problem.
Aug 25, 2008 | Microsoft Windows XP Professional With...
How to change background
These tabs are the only way to change the background or screen saver. The display properties are integrated into the operating system, so, if the tabs are missing, this is an error with the operating system. Start with a system restore. Keep going back until they show on the display properties. If a restore doesn't work, then you will need to do an operating system repair with your recovery or operating system disc.
Jul 22, 2008 | Acer Aspire 3003LCi Notebook
I can't get my screen saver to apply
easiest would be to right click on the desktop and goto properties and then screensaver tab...by default the apply tab is grayed out. You need to select a screen saver from the dropdown and your apply button will become active
Mar 05, 2008 | Acer Aspire™ T180 PC Desktop
XP Pro Display Properties Desktop
check Display Properties, Screensaver tab, see if the "on resume, password protect" is checked. You've probably already checked on this, but...
Sep 12, 2007 | Computers & Internet
A4tech PK5 Logo
3,386 people viewed this question
Top A4tech Computers & Internet Experts
micky dee
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
