Question about Sony KDS-60A2020 60" HDTV
Tv dimming when i turn on my tv it is really dim, and if i turn it off then on again the picture is brighter. i believe the problem is with my lamp, and probably needs to be replaced, i've had the tv for 1.5 yrs with it on 10 hrs a day. What do you think?
  • 320 Answers
It is probably time to replace the lamp. Be sure to buy an original Sony lamp, as the aftermarket replacement lamps are known to have issues. If you liked this answer be sure to rate it. Thanks!
Posted on Nov 02, 2008
Dim picture tv
Could be a power supply problem
Feb 16, 2018 | Televison & Video
Turn set on picture is dark.. if I leave the TV on.. in several hours it's viewable.
I have seen several Samsung's including 3 that were only a few months old at the time where it was the lamp---one was so dim it was very hard to even see the picture or that the screen was lit.
Two suggestions here: One of course would be to buy and gamble and replace the lamp.
What I found in two of the three cases was when I removed the lamp the glass pillar inside it was "bent" at a angle from heat or a natural defect--in both those cases a new lamp cured this dim picture issue.
Set will monitor the lamp and if too dim may shut set off or even blink for a prolonged period of time.
If the lamp is over 2 years or age (average life) or was replaced with a non-Samsung lamp you are going to have to take the gamble to try another one.
Inspect the lamp---that pillar supports the filament and if bent the lamp is suspect at best.
May 20, 2012 | Televison & Video
How do I fix My 50 inch Hitachi Ultravision TV?
Likely the lamp in the set has failed here which does make sense if the picture was dim before---a lot of lamps just before failing all the way dim down.
Apr 25, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
My dlp tv seems to be dimming.. Is that the lamp
it does sound like your lamp is going out. this happens after 2.5-5 years depending on the tv and amount of use. You can find cheap replacments and sometimes can get them a discount if you buy 2.
comment if you need sites or info on replaments
Mar 17, 2010 | Samsung HLR5688W 56" Rear Projection HDTV
HL-S5087W has become dim in picture
if the colors look good and its just dim its the lamp. usually the lamp will show signs of being bad by looking at the base of the shaft in the middle if its discolored or warped the lamp is bad
Jan 30, 2010 | Samsung HL-S5087W DLP TV
I have a Sony kf-50we620 Grand Wega LCD projection tv that we replaced the lamp on and the screen still remains dim, is there any way to fix this?
hello if you go into menu in picture adjustments half way down there should be a reset option this should make the picture brighter
shaun
Nov 13, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Kdf-50we655 dim picture and turns off and then back on
Symptoms shows that Tv requires new Lamp.
Lamp replacement procedure is written in user manual. Let me know if you need further info about Lamp purchase or need user manual.
Please buy original Sony lamp for replacement.
Jan 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
WD-52525 Lamp failed 2x in 4 months..is it the Lamp?
do you get an error code? hold the MENU and DEVICE buttons when turning on the TV and get error code
Oct 20, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Sony KDS-60A2020 60" HDTV Logo
218 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
