I am getting ghost images, the clor balance is off, and the picture looks like it is collapsed in on my HDTV. I have digital cable hooked up to my set. I think it is the tv and not the cable box.
  • Anonymous Apr 05, 2009
    my tv is getting a blue ghost i tried to adjust it but it dosnt work it is in the bottom half of the tv
Try updating the firm ware
Posted on Aug 03, 2008
I bought a Sanyo 26 in lcd hdtv 7 months ago. No
Try explaining the problem to the manufacturer. They will help. They may change the software if needed. After the guarantee it will become a payable service.
May 24, 2010 | Sanyo DP46849 46 in. HDTV
Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from www.tvrepairworld.com will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Dec 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Ghost images & curved picture
ghosting is usually caused by ingress, or unwanted signal getting into the cable. check all connections and make sure they are tight. if this doesnt help, contact your cable provider as the ingress may be coming in on the outside. i have ran into a few models of this tv that go bad and also causes this type of problem, so be prepared.
Oct 19, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Poor picture (fuzzy ghost image/aura)
well you should check the settings and read menual
Jul 22, 2009 | Panasonic TC-P50G10 Plasma TV
The picture goes in and out it pause for a then show picture
You didn't say if you were on cable or air? This problem usually occurs with the over the air signal not being strong enough for the digital tuner to stay locked in and that's the symptoms you get. Older sets just had a snowy picture, ghosting..ect. Digital sets are not so forgiving. If your on cable, have your cable company come out and check the signal level, if it's ok then I would have it looked at be a qualified service company.
Jun 07, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Ghosting problems with a Samsung-LN32B360
I think your cable box is old version together with weak signal caused this problem. I guess you are using coaxial cable hooked up to the TV at TV cable input jack.
At the TV there are some better quality inputs which are real digital transmission (audio and video) HDMI and components (digital video and analog audio).
The most simple and best quality is HDMI provided the box has HDMI output.
Secondly is component inputs. There are 5 cable trends in which 3 of them (red, blue, green) for video and the rest 2 are for audio (red , white). The cable box should have same color accordingly as ouput. Please note that the color must be matched otherwise you will see the screen has one color only.
Playing a DVD player to see picture good or not. If picture is good, TV has no problem at all.
May 25, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Sony 52 Bravia XBR4-14months old,picture very white, ghosting
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary
Jun 24, 2017 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Ghosts on my tv
if you can, try hooking up the tv to a different cable line in the house or bring a different tv into the room where the bad picture is [ you may have a bad connection or wire ] if this doesn't help, try rabbit ear antennas just to get a picture. if you still have ghosts on your tv, the problem is with your tv.if the picture is fine, there maybe a problem with your cable service.
hope this helps
wg
Feb 10, 2008 | JVC AV-56WP74 56" Rear Projection...
Ghost images
Sounds like a light engine issue to me. Is there anyway you can post a picture of the issue itself?
Mar 28, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
Electro Med Services...
