Question about Nokia 6600
General Sysytem Error
On main screen , a message occurs "General System Error"
i cant do anything xcept disconnet the battery
CODE : 0516518
IMEI : 353766/00/013842/9
IC : 661AE-NHL10
FCC ID :QVVNHL-10
Posted on Jul 16, 2008
  • KHAIRUL_85 Jul 16, 2008
    CODE : 0516518
    IC : 661AE-NHL10
    FCC ID :QVVNHL-10
Ipod froze
A white screen on an iPod Touch is the sign of a generic error, meaning you won't get a specific error message. Usually when this happens the white screen won't change and the iPod is frozen on that screen. Apple Support outlines a specific series of steps to take to deal with this problem, from turning the iPod Touch off to completely reinstalling the operating system if necessary.
What the White Screen Means The white screen is a sign that a software error has occurred in the iPod Touch. Unless you received an error message first, it's usually something near the root level of the iPod's operating system that caused the iPod to cease functioning normally. Rather than shut off completely, it goes to this white screen to let you know there's been an error. Unfortunately you usually lose unsaved information when this occurs. b> Resetting b> Try turning the iPod Touch off, then on again. This is the simplest way to reset your iPod Touch. If it remains stuck on the white screen, force a reset by holding down the Sleep button (top right corner) for about 10 seconds. The screen will go dark, then the Apple logo will appear. If it turns off and doesn't turn on again, the battery may be too low. b> Restore b> If a manual reset doesn't work and the screen remains stuck on a white screen, you'll need to restore the iPod to reinstall its operating system. Plug your iPod, via its charger cable, into your computer. Open iTunes and click on your iPod, then the "Restore" button on the main screen. b> Problematic Apps b> If you consistently receive a white screen while using a particular app, the app may be faulty or installed incorrectly. Try re-syncing the app to your iPod Touch and see if that solves the problem. Otherwise, you may need to delete the app to avoid the white screen problem.
b>
Jan 27, 2013 | Apple iPod touch
System settings were lost
System settings were lost:
You need to reset the time and date from the Nintendo GameCube Main Menu. To access the Main Menu, turn the power ON while holding down the A button on the controller. Follow these steps to reset the time and date:
From the Main Menu Screen, go to the Calendar Screen by pushing RIGHT on the Control Stick.
Press the A Button to display Calendar Menu choices of Date or Time.
Use the Control Stick (UP or DOWN) to highlight your menu item and press the A Button to select your choice.
Use the Control Stick (LEFT or RIGHT) to highlight the number you want to change, then (UP or DOWN) to adjust the value.
Press the A Button to accept your choice.
Press the B Button to return to the Calendar Menu or the Main Menu.
Pressing the B Button before accepting your choice with the A Button will return you to the Calendar Menu without changing the settings.
If the same error continues to happen, you will need to have your system repaired as it is likely you have an internal battery malfunction. Please use our convenient repair options.
Wrong Game Disc:
This message happens when a Game Disc has been removed while the system is on, and a different Game Disc is inserted. Re-insert the original Game Disc.
No Game Disc:
This error can occur when the Game Disc has been removed while the system is on and then the Disc Cover is closed. Follow these troubleshooting steps:
Ensure the game is inserted correctly. With the power turned off on the system, replace the Game Disc in the system, printed side up. Press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
Determine if this happens with more than one game by inserting a different game into the system.
If the error occurs with all games, follow the Multiple Game Disc troubleshooting.
If the error occurs with only one game, follow the individual game disc troubleshooting.
Nov 17, 2012 | Nintendo Wii Console
I see dark, black and blue stripes when start my hp iq775 desktop
Memory problem. A page fault occurs when you don't have enough memory so it writes a page fault to disk. It could be bad RAM or driver could need an update.
Oct 20, 2017 | HP iQ775 19" TouchSmart Desktop PC
I got message "system error
Having a "System Error" message display on the camera's LCD display generally indicates a problem where the camera will need to come to Nikon for repair. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
  1. Use the memory card that originally came with the camera (or a Nikon approved card) [/*]
  2. Remove and replace the battery [/*]
Mar 05, 2011 | Nikon Coolpix 8800 Digital Camera
Screen is just lit up blank cant turn off or get
were you trying to unlock or jailbreak it ? be that as it may remove the battery for about 10 minutes and then try and turn on the phone again. should work unless the error occured while you were doing either of those two things
Oct 21, 2009 | Apple iPod touch
Nintendo game cube says an error has occurred,said to turn it off and check the instruction booklet
Is it the game or the game cube that is doing that. If it is the game then it is probably scratched. Try using toothpaste to clean. If it is the game cube that is broken then open it up and see if anything looks broken
Jul 14, 2009 | Nintendo GameCube Console
Multiple Blackberry problems on the same phone! Please help!
I think the easiest way to resolve as many of these issues is by resetting your blackberry.
Hold down ALT+RIGHT SHIFT(CAP)+DELETE keys - I'm not 100% sure this works on your model but it is soft reset.
Go into Options, then select Security Options, then select General Settings, then activate the BlackBerry menu and select the option to wipe the device - Will reset all your personalised settings to default
Jun 01, 2009 | RIM BlackBerry Pearl 8100
Sager laptop won't start up
ok, after reading i noticed that the computer cant find anything, not even the keyboard which is why f1 doesnt do anything, none of the controllers are registering, im beginng to think the mainboard in the laptop is dead. the main thing is the cmos error, usually when that happens the battery for the cmos has died, but even if we put a new battery in there is the possibility the keyboard wont work......so the first thing is to replace the battery, not the laptop battery but a small watch battery inside the laptop, are you able to do this yourself? if not can you take it to someone who can? The CMOS checksum error is the first problem thats on my mind.
Dec 11, 2008 | Sager NP9890 Notebook
Sytem error 10
Hi - I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Sort of like a Windows Restart to reset the memory.
Hope this helps.
May 09, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon coolpix 4600.
Hi I found this info on the Nikon Australia website:
Seems you may just have to remove and replace the battery - sort of like a Windows Restart to fix a computer problem! - this would reset your camera's memory.
Hope this helps.
Apr 29, 2008 | Nikon Coolpix 4600 Digital Camera
Nokia 6600 Logo
181 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
