Question about HTC Touch P3450 Smartphone
My mobile is dead
Dear all,
I have HTC pocket PC. Yestrday i used it after the red light indication i.e. low battery. suddenly my mobile went into stand by like mode with only one green light glowing. now i am unbale to switch on the phone even after recharging it.
Plaese help me
  • jeffshot69 Oct 07, 2008
    my phone went dead tried charge but the lcd light remains red
I have a htc touch 3450 my battery went down totally & after that i tried charging it at home .After hours time my power was 100% but suddenly i made call to a friend after that it started bipping that main battery power low you may loose data.Why is so?
Posted on Jul 22, 2008
I just had this happen to me yesterday. I fought with my phone for about 3 hours removing the battery and trying to restart it. It would take about 5 minutes for it to finally boot and once it did the touch screen would not work. So I did a hard boot and within 5 minutes my phone was back to normal. I lost all my contacts but I just did a restore with the backup software. To do a hard boot hold down the red and green buttons on the front of the phone and push the reset button on the bottom of the phone with the stylus. The reset button is on the right side of the power/usb plug. As I said my phone was back to normal in just a few minutes.
Posted on Jul 21, 2008
Orange light flashing
Battery is dead, plug into the charger, the battery indicator turns orabge when the battery is almost totally dead.
Nov 06, 2013 | HTC Inspire 3G/4G Mobile Smartphone for...
Battery power indicator light has suddenly stopped coming on. Can I still use my laptop?
If it works, yes you can. It maybe that the battery went dead.
Try removing the battery for 10 minutes and put it back and see if the laptop powers on. If it doesn't, connect the power cord and see if it is charging. If not, then most likely battery is dead.
You can buy batteries from stores like ebay.
May 03, 2011 | Medion MD-41017 Notebook
I have dropped my mobile HTC touch P3450 , it got switched off. After while I have put it to charge , the red indicator was on for a while. But it went off after that and i could not switch on my...
Before asking them to touch your phone inside better do this first. Remove the battery and then insert it again. Maybe pins in the battery got jammed when you dropped it. If this doesn't work, while in charge leave it for a minute or so, if the red light is on, feel the back of your phone and feel it again if the red light goes off. If it heats up then it means a circuit is shorted causing your battery to heat up. As of asking service engineers, better ask the one you personally knew or have a second opinion before proceeding to have them repair it.
Apr 05, 2011 | HTC Touch P3450 Smartphone
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Battery Problem and signal problem
You will find that o2(i-mate) is often branded as a HTC. You may wish to try the following links to find your local service agent.
HTC Product Support - Drivers, FAQ etc
HTC Offcial India Website
Best of luck solving your battery/signal issue!
May 21, 2009 | i-mate PDA2k Pocket PC
HTC Touch HD restart problem
Check the battery connection, if the battery is loose/moves around when you touch it with your finger, try putting a piece of paper on top, or the side, or which ever way it moves. So the battery will still touch the battery contacts. If this isn't the case, try doing a hard reset. Go to start>settings>system>clear storage. (It's like this in my htc diamond, not sure about the touch HD, but should be same) which will erase all data/contacts. Make sure you sync your contacts to your pc to save them!
Feb 26, 2009 | HTC Touch HD Smartphone
W850i red light prob
not to worry this is a fixable problem..............take te phone to a mobile shop and have them reflash the firmware n custom pack back into the phone and this will correct the problem....the erom needs to be loaded back on the phone.
Nov 19, 2008 | Sony Ericsson K850i Mobile Phone
Xda iis
It is indeed a dead battery - the red LED means NO BATTERY PRESENT.
Apr 03, 2008 | O2 Xda IIs Pocket PC
MDA problems
Your battery is very very low. The red light is indicating an almost dead battery. In fact, you may have a battery that is too low to charge. Or you may have dead cells in the battery that require you to purchase a replacement. Try my guide to manual battery charging. I have it listed in all of the HTC Wizard (which is actually what type of phone you own) sections.
Oct 04, 2007 | T-Mobile MDA
HTC Touch P3450 Smartphone Logo
414 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
