No sound when the speakers are switched on..........kkkkkrrrrrrrrrr sound is coming.........actually i formatted my system a month before..............from tat day my speaker s not working........what to do??
Suspect a broken wire at male DIN plug or something wrong with female end attached to the circuit board
Posted on Apr 08, 2009
  • 120 Answers
This issue could be caused by any of the below reasons.
  1. Sound card does not work
  2. Speakers are not connected properly
  3. No power to the speakers
  4. Volume on speakers turned down
  5. Volume on sound card turned down
  6. Bad hardware
  • make sure the speaker setup is correct. It is possible that during an installation of another program that the speakers software setup was changed causing issues with your sound. To do this follow the below steps.
  1. OpenControl Panel
  2. Open "Sounds and Multimedia Properties" or "Sounds and Audio Devices" in Control Panel.
  3. Click the "Audio" tab
  4. In the Audio tab click the "Advanced" button under "Sound Playback."
  5. In the Advanced Audio Properties window make sure your speaker setup is correct. If you're not sure what to set this setting as, set it to the default "Desktop Stereo Speakers" option.
  6. If you changed this setting click "Apply" and close out of all windows.
  • Ensure that the sound card works properly by connecting either another pair of speakers to the computer, or a pair of headphones.
  • the left speaker will generally have a cable that cannot be removed from it. This cable should be connected to the other speaker (generally this cable has no color or is white / gray). The next cable is the line out cable, it is generally green in color and should go from the right speaker to the line out hole in the back of your sound card.
  • Finally, the power cable generally should be connected to the back of the right speaker, or in some cases, the sub woofer. The power cable can vary; while most speakers are in the above configuration, some speakers may also not utilize a power cable connection but instead have batteries, while other speakers that connect to the side of your monitor may use a portion of the power from the monitor itself (via another type of cable).
  • Most speakers will have a small LED (light) indicating if the speaker is on. Verify that if this light is present that it is illuminated.
If no LED is seen or the speakers don't appear to be getting power, verify the power cable is properly connected to a working outlet or if your speakers use batteries that the batteries are good. Finally, most speakers can be turned on either by using a button or by moving the volume knob from left to right.
  • Verify that the volume knob on the speakers is properly turned up. If you are un-certain what direction to turn the knob, play a long sound file or CD and while the sound is being played, adjust the knob left to right or up to down.
  • The sound is also able to be turned up and down through the software installed on the computer. Verify the sound settings in the software are properly turned up.
  • Finally, if all of the above recommendations do not resolve your issue and connecting another pair of speakers or headphones to the computer does work, it is likely that the speakers are bad. It is recommended that you contact the manufacturer of the speakers or computer for a new replacement.
Posted on Jul 16, 2008
I have polk audio rm 705 purchased from my friend a month ago. these are working fine but one day one speaker just have very low sound coming from tweeter where as the main speaker is silent.
Try switching the speakers left to right. If the same speaker is bad on both channels, the speaker is bad. If the good speaker is now bad, the unit driving the speakers is bad.
May 23, 2015 | Polk Audio Rm705 5.1 Channel Home Theater...
Screeching noise coming from my tv
Is the sound coming from the speakers or from the actual television? If from the speakers, I would check all connections for the sound system. If from the actual television frame and housing, check for a fan ( to cool electronics) canned air or compressed air can work wonders for cleaning out dust which can cause mechanical sounds. If it's coming from the speakers, there is an electronic problem which is usually related to cable connection issues. Have you made any changes recently? If so, check those connections. Unplug them, and make sure they are securely plugged in. I would assume this would fix any problems, if not, there is a problem with one of your devices... I'm convinced you have a bad connection somewhere or a bad audio cable.
Apr 01, 2012 | Cars & Trucks
I have a acer aspire 5742g core i5 model ..... purchased in the first week of February 2011. It's been two months now. All of a sudden on that day, the speakers of the laptop started providing with a...
If the earphones are giving you a good quality of sounds, the problem here could be with the actual built-in speakers itself. since you have purchased it this year, you could contact the laptop's manufacturer or technical support so that you can have it fixed if the computer is still under warranty.
Apr 11, 2011 | Computers & Internet
Speakers not working
Follow this checklist:
1) Make sure they're securely plugged into the wall
2) Make sure that any relevant power switches are in the "on" position. Is there one one the subwoofer?
3) Make sure they're securely plugged into your computer (or other device)
4) Make sure that the source device is actually outputting sound. Try plugging headphones directly into the computer
If these fail, please come back with more details. Are there any indicator lights/LEDs on the speakers? If so, do they light up when plugged in and turned on?
Mar 01, 2011 | Logitech X-540 Multimedia Surround Sound...
TV sound only thru front and sub woofer speakers only
this might be happening because the audio format for surround is not supported by the channel or affiliate of the channel that you are viewing does this happen on all tv channels or is it on just a few? if all sound while playing a dvd is proper and in working order than there must be an issue with the sound and or format of sound from the tv source. maybe more information would help me decipher this
anyways hope it helps
Feb 14, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Speakers through realtek audio
you need to install the sound driver in order to get the sound from your system.....once u format the harddrive, you need to install all the drivers ie in technical terms its called CVAN which is Chipset, Video, Audio & Network drivers.....go install them all from the cds of your hardware and enjoy the difference.....cheers!
Mar 14, 2008 | ViewSonic VG1930WM LCD Monitor
Stereo to 5.1?
When you switch your Sound Field to 2 Channel it should use all the speakers (although you'll notice it doesn't sound as loud as normal coming out of the center speaker). Auto Deco actually sounds good in this mode, in my opinion.
Jan 04, 2008 | Sony DAV-C770 System
Sound not coming out from the center OR the rear speakers
To play soud needs sound driver... which comes in mother board cd..
Sometimes it happens... No sound....then that case, RESTART u'r system... if problem persist then install audio driver once again from u'r mother board cd...
Avoid loose connection..... Power on!!!! Off... of sound system in the middle of use of u'r PC.
Dec 27, 2007 | Logitech X-530 Computer Speakers
Can TV Sound Come thru Sound System Speakers
if you have a digital rec the red and white output goes into the surround sound input, if you have basic cable, then you need to use the red and white output on your vcr to go into the surround sound input. just make sure to note which input you are using on the surround sound and switch it to that.
Nov 17, 2007 | Koss KS4192 System
379 people viewed this question
