Question about Microwave Ovens
Asking something on your answer
What do u mean wiht continuity...if it works continuously?
it hears like stop and go when use a programm but this doesn't happen when use it manually...all others as grill, turntable etc. seems to work good
  • arthurskg Jul 16, 2008
    the most helpful..thank u
  • Microwave Ovens Master
  • 19,396 Answers
Well, testing for continuity means testing an electronic part with a Multimeter, to check that the component is not burnt.
If you do not know what this is, do not attempt repairing the microwave by yourself, there are too many hazards involved, it is an operation for an experienced electronic repairman.
Posted on Jul 16, 2008
  • Ginko
    Ginko Jul 16, 2008
    about the fault, generally, if your microwave never heats it is the magnetron.
    In your case, as it seems to work on certain programs, the repairman need to test the power diode, and check that the program control is working, testing the timer contacts. also burnt capacitor may cause heating problems.
    The whole thing should be around $60.
    Check if your microwave is under guaranty cover and if it is worth repairing.
  • Ginko
    Ginko Jul 16, 2008
    Thanks, if the solution was helpful you should vote the thread in the main problem here on my solution:
    http://www.fixya.com/support/t790815-no_...
    As it is now you are rewording a different expert.
    Regards
Microwave noise
<- With a full model number from the tag on or in the oven, I may have been able to give you specific help.
Without that essential information, I can only give more general advice.
I would ask for additional information, but FixYa no longer notifies us experts when such inquiries have been answered.
If it's a GE with a model number something like JVM1861BW001, etc., I repair those boards for such problems.
Jan 18, 2014 | Frigidaire Over-the-Range Microwave
I have a kitchen aid khms 1850 microwave. When setting idle it continues to make a small rumbling sound and after 30 minutes it smells like something is overheated. I'll unplug it after a day and will...
That is the sound of the magnetron failing. The large capacitor inside may also be drying up and causing the sound. When the capacitor dries up further it will start blowing fuses.
Nov 24, 2013 | Microwave Ovens
My lg fridge is giving me an error code of FF what is this mean
Your LG refrig is in Demo Mode.
1.- disconnect power supply and reconnect
If the error continue
1.- Open the door of refrig.
2.- Press button "Refrigerat" while press "Ice P" button 15 seconds
If the error continue try again
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | LG Microwave Ovens
Fan continues after microwave has stopped. Is this correct
I think this is rather like a normal oven and iscooling it. My oven is a combination oven and new to me I haven't read all the instructions yet but it seems to make sense. I should really look and see if this is on a combination programme though.
Dec 29, 2010 | Microwave Ovens
Well i will try again as it says ask a question get a free answer and then i see you want me to pay one time fee. whats that about.if i ask a question about my microwave do i have to pay.I have a galanz...
Try re-programming from the menu: things like time/temp since these typically let you know something changed in how the unit was put into service. Maybe an electrical shortage or power outage caused the unit to trip. Re-set functions.
Nov 05, 2009 | Microwave Ovens
New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes Failure
Code
Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
Feb 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Buttons dont work on danby microwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
If it still isn;t working I would contact Danby Customer Service US / Canada.
Jan 08, 2009 | Danby DMW1146SS Microwave Oven
Goldstar
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 27, 2008 | Microwave Ovens
Shuts off but everything else works
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Nov 08, 2008 | Panasonic NN-S542 Microwave Oven
Micro wave operates for a few seconds then shuts down, light goes out, but fan continues to work
The oven will also strop after 22 seconds if there are certain problems with the inverter or magnetron.
In most cases, this is a problem with the inverter or a bad magnetron.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 13, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
29 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
