Question about Mitsubishi WT-42413 42" Rear Projection HDTV-Ready Television
Power on
When i power up my tv the green light goes on for a few seconds, and then it goes off again. Is there a reset or a fuse line on my tv.
  • 1 more comment
  • jrhawleyman Jul 16, 2008
    eagle 338 thank you for the advice. where is the thermal fuse located, and is it something I could do without calling in a service man?
  • historyquest Aug 31, 2008
    I have the same problem the television light comes on and then two seconds later it turns off. Is this expensive to fix and can I do it without paying for a costly repair man.
    Any help will be appreciated
  • Anonymous Apr 19, 2009
    power light comes on for a second, and then goes off.
  • 4,889 Answers
From what you have said it seems like the thermal fuse of the set is down... You will have to replace it and then check if it works..Post back if you need more help..
Good Luck!
Posted on Jul 16, 2008
65 inch mitsubishi model# 65736 green light blinking
If the TV does not stay on, press the POWER button on the control panel for at least eight seconds to perform System Reset. The TV will turn off. Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost. If this happens frequently, obtain an AC line power conditioner/surge protector.
An unusual digital signal may have been received, triggering a protection circuit. Wait for the light to stop flashing and turn TV on.
Momentary power fluctuation caused the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again
Sep 29, 2016 | Mitsubishi Televison & Video
Mitsubishi hdtv
NOT A GOOD IDEA AT ALL!
You likely now have one of two things happening:
1. Green power light constantly blinks and will not stop(should blink for 70 seconds and go out).
2. Green power light comes on and a few seconds later goes off.
Which do you have?
May 17, 2012 | Mitsubishi Televison & Video
How much should I pay to have someone come out and change the fuse in my TV? When I turn the TV on the power button lights up green for a few seconds, turns itself off for a few seconds and it does this...
this is not a fuse. the fact that you have a green light means its not a fuse. this is more likely a capacitor or a shorted transistor as far as price that is all dependent of what a tech find our shop general charges 80 to 100 to come to your house + any parts that are required
Oct 17, 2010 | RCA HD52W56 52" Rear Projection HDTV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
When tv is turned on green light comes on then goes to standby
had the same problem on mine.
Found loose solder terminals on the main power transformer, resoldered fixed it up about 5 min.
Nov 01, 2008 | Pioneer SD-532HD5 53" Rear Projection...
JVC tv i'art blinking timer
It is protecting you and itself with high probability.
Power supplies in modern electronic devices are designed to cycle if there is a fault in circuitry they are servicing and because of the design, also will not turn on completely if they are failing.
The older style of power supply was 'dumb' and unable to do this so could cause fires if the failure wasn't teh 'right' kind to blow the main fuse.
I agree with the manual; this is a job for a tech.
Aug 23, 2008 | JVC AV-32260 32" TV
Sony Trinitron 36" TV
Try a "hard reset"===unplug AC for a long time, like overnight.Let me know if there is any change.
Mar 07, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Push Power button, green light goes on for a few seconds then nothing....
I would suggest taking a look at the power module if that can be replaced. The Fuse blowing may have only been the beginning of the problem. Any recent issues with under or over voltage in your home?
Jan 20, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi WT-42413 42" Rear Projection HDTV-Ready Television Logo
387 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
