Question about Intel 845GE Motherboard
Motherboard i loosed my motherboard cd
I lost mi cd intel 845G
Posted on Jul 25, 2008
  • 4,889 Answers
Here you go.. Click here to download
Posted on Jul 16, 2008
Some time unable to get the display and some times unable to detect the hard disk and cd drives
First check the connection whether it is loose or not? If not Better change your Motherboard.
Nov 30, 2010 | Mercury P4VM800M7 Motherboard
AOpen AX45F-4DN Motherboard On Boot, System does not detect any IDE devices. halts at 'Detecting IDE Devices' Cannot go into SETUP
Some connections inside the computer is loose.
It is probably the hard disks or CD drives. Just open CPU, disconnect those devices and then reconnect.
Aug 12, 2010 | AOpen AX45F-4DN (91.8A410.201) Motherboard
Can get my Samsung SW-252 to open and close but my computer isn't showing that i have a cd drive at all, not sure what to do...and my normal tech is on vacation...
The drive has power but either a dead data cable (IDE), a loose data cable (on one side or the other) or a bad connector (either on the motherboard or the drive).
The most common is the loose cable. Open the case and make sure it is firmly connected to the motherboard and the drive. This can be a pain since the motherboard IDE connector could be hard to reach due to other components. Also, you may need to slide the drive forward in the cage to be able to reach - depending on your case this could involve removing the screws and then replacing them after sliding the drive back.)
If that doesn't work, then try a new cable. One IDE cable can connect to two different devices; most computer builds have only one drive on a cable. Make sure to match the colors or labels so that you maintain the correct master/slave/motherboard connections. The last option is to replace the drive with a new one.
I hope this helps.
Jan 23, 2010 | Samsung SW-252 CD-RW Burner
Same problem for me.CD-Rom doesn't work either
There could be a number of problems such as:
Your PSU is toasted. (Power supply unit)
Your Motherboard is fried.
Your Ram is fried.
Your power button is loose from the contacts (or the wire is loose).
Your Motherboard, Your Drives, and/or Devices are unplugged in one way or another.
And/or more
Sep 27, 2009 | HP Compaq Presario SR2011WM PC Desktop
CD ROM DOES NOT APPEARS ON MY DESKTOP. WHEN I OPENS MY COMPUTER THERE`S DOES NOT APPEARS THE CD-ROM`S ICON.
1.check your connections of CD Rom inside the Cpu box, if any loose contacts there, then your cd rom wont appears on the computer,
2. change the data cable
3. connect different power socket to the cd rom
4. goto Bios setup, press Del key or F2 key to enter the Bios setup
5. check your cd to detect
6. save it and restart your computer
Jun 22, 2009 | Intel D101GGC Motherboard
D845GVSR motherboard replaced but PC won't boot
please check your RAM if it is compatible in your new motherboard.. go check the manual of the board you buy.. or visit the website of your new motherboard.. cheer. ^^
Feb 16, 2009 | Intel D845GVSR Motherboard
I loose mymother bord cd..how to get 865g intel audio drivers..
download them here:
http://www.intel.com/support/chipsets/sb/CS-009241.htm
Dec 27, 2008 | Intel 865G Motherboard
Loose wire
Delva,
This is the cd audio cable most people currently do not need this cable. It connects on your motherboard to the back of your Optical drive (CD or DVD).
The purpose of this cable is for play CD's in you optical drive and it sends the audio DIRECT to the sound card rather than piping it through the data cable and then redirected to the audio sub system. Its kind of like having a short cut to the sound card but is only used if you play CD audio disc in your CD/DVD. MP3's and other data are still sent through the data cable.
Hopefully you found this useful
Dave
Nov 18, 2008 | Intel Motherboard
Please Tell me, ASUS P4S8X-MX Problemn
First of all, try to reseat all the cables inside your computer just make sure there aren't any loose connections.
If that doesn't work you will have to reset your BIOS. (Follow the instructions in your motherboard manual.)
If even after resetting the BIOS the problem is not solved, you may have to replace your CMOS Battery.
Oct 18, 2007 | ASUS P4S8X-MX Motherboard
Intel 845GE Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
