I recently aquired a IMPERIAL_GV20030812 and i can't figure out where to hook up the on\off switch and reset button PLEASE HELP
    Sergeant:
  • 287 Answers
The board you have is from an eMachines system I cannot locate a manual. However, this board uses the Intel 845GV chipset & I have found an Intel manufactured board which I believe is similar. It not only uses this chipset but also looks the same as the one you have.
JUMPERS
CONNECTORS
Source
Please post back your results good or bad...
Posted on Jul 16, 2008
Where is limit switch reset located
The limit switch is located in the front of the fryer. Depending on the model it can be on the left side or right. There are two types, manual reset and automatic. If you have a manual reset limit, you will see a little red button sticking out.
Jul 10, 2014 | Imperial Kitchen Appliances - Others
Front power switch broken. Bezel won't come off easily. Thought we could just get a switch and install on the back but don't know which of the colored pairs of wires go to the original switch in the...
I would suggest this generic Power On switch,
1) http://www.directron.com/atxswitch.html,
and the Red, and Black twisted pair of wires go to the Power On switch.
Your statement of ,"....don't know which of the colored pairs of wires go.....", leads me to believe you may have all of the Front Panel wires disconnected.
How about information as to where ALL the Front Panel wires go?
(Provided I have correctly interpreted your statement)
Back in the time that the eMachines T2542 was made, TriGem was the motherboard manufacturer.
The Model Name of the motherboard is Imperial, and the Model Number of the motherboard, could have been one of four variations offered.
Model Name: Imperial
Model numbers could be G, GL, GV, or GLVE
(Imperial G, Imperial GL, Imperial GV, or Imperial GLVE)
ALL four variations used the same Front Panel header.
(The connector on the motherboard the Front Panel wires connect to, is named the Front Panel header)
I would like you to view this page,
http://www.e4allupgraders.info/dir1/ecase/support/front_panel_header_support.shtml
Scroll down to the heading -
Trigem Imperial Front Panel Header Pinout.
A) Pins 1, 2, and 3 are for the Power On LED light.
B) Pins 5 and 6 are for the HarDDrive activity LED light.
(Pin 4 is not used. NC. No Connection)
C) Pins 7 and 8 are for the Power On switch
D) I wouldn't connect any wires to Pins 9 and 10, nor Pins 11 and 12
E) Pins 14 and 15 are for the Reset switch. (The button you press to restart your computer.
If the T2542 doesn't have a Reset switch, don't worry about it. There are many other ways to restart your computer)
F) Pins 17 18, and 20 are for an internal speaker.
This speaker is used for BIOS Beep Codes.
In the chart to the right, you will see GRD used many times.
GRD stands for Ground.
ANY Black wire in the twisted pair of wires, is a Ground wire.
Most of the eMachines I have worked on, use a Red, and Black pair of twisted wires for the Power On switch.
I could be mistaken on the T2542.
Best method, is to follow the color code of the wires that come from Pins 7 and 8, and be sure.
Aug 17, 2010 | E-Machines T2542 PC Desktop
Need to know where to connect the reset switch pin.
It may be just a pinhole. Convention puts it right by the power button.
If you can't find it, you can hold the power button down for 3-4 seconds until it shuts off, or simply unplug it and plug it back in. It will have the same effect.
Jan 03, 2010 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Ipod touch needs codes
Connect it to the computer you usually connect it to and use the restore button in iTunes. This will reset the device to manufacture settings and remove any passwords. If you recently aquired this ipod and the previous owner set the password you will need to get it off him/her.
All the best
Sean
Dec 25, 2008 | Apple iPod touch
GAS VALVE TIMING OUT
I had a simular problem. The gas company disassembled the pilot light and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 08, 2008 | Imperial IFS40 Deep Fryer
I need help hooking my mother board up
See here below and let me know if you need more help.
Oct 01, 2008 | Intel Desktop Board D845WN Motherboard
Ipod wont show up in my computer or itunes...
Have you tried resetting either ipod? In order to reset it, you just need to hold down both the menu button and the center button at the same time until the ipod turns off. then the apple will pop up on the screen and it will start up like normal. If this doesn't fix the problem for either ipod, then most likely the problem is with itunes or your computer. I would say that if it doesn't even show up on your computer anywhere, you're probably missing a driver or something.
Jun 30, 2008 | Apple Ipod Nano Second Gen. Green (4 GB)...
EMACHINE T2642 W/ IMPERIAL GV20030812
Can you provide at bit more info?
You say it wont power up, are you getting any power through at all? DO the LEDs light up? Can you hear the noise of the fans etc powering on?
Mar 23, 2008 | Computers & Internet
No Power up on depressing On/Off button.
Sometimes if the CPU is overheatign it will power down to stop the cpu from buring out. A power suppluy just supplies power to the motherboard and that's it. If the CPU gets hot it shuts down and wont start till it cools down again.
Nov 04, 2006 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Open Questions:
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
