Error code E000001-0003 on Canon CLC 3200
I saw that you are an expert, you can solve lots of problems with copiers and printers and others things. In fact I have a problem with my printer Canon CLC 3200. The error code is E000001-0003. I don't know what I can do to solve this problem, so I hope so much that we would answer me.
Thanks you very much.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
E001 on a canon is a fuser problem. check to see if the fuseer lamps come on, if yes then the problem is a Thermistor (controls the temperature of the rollers) change.
Posted on Jul 18, 2008
To Clear the error do the following
hit *
Then hold 2 and 8 together
hit * again.
Then go to Copier--> Function --> Error --> Clear --> OK
Please Note: this just clears the error message and gets you going temporarily, it doesn't "FIX" the problem and as mentioned above, it is related to the fuser. You SHOULD get a service tech to look at your machine.
For more tech tips check out - http://www.techtip.ca
Posted on Aug 29, 2012
  • nexusit
    nexusit Aug 29, 2012
    by the way * is not the one on the Numeric Keyboard - but the Additional Functions one ( with the sort of Face on it )
Canon iR-2016 System erro E007
The fusing unit needs to be replaced or repaired. Contact your dealer or service person
Nov 20, 2011 | Canon CLC 1140 Copier
Pls Solve my problem : Canon CLC 1180 Copier error Switch power Off and On again. E020 0481 Mr. Santosh Kolte. Pune.
The probable causes for error :
The developer has deteriorated.
• The developing cylinder fails to
rotate.
• The developing assembly is not
locked.
• The toner concentration (patch
detection) sensor is faulty.
• The developer inside the
developing assembly is faulty.
• The toner level sensor is faulty.
• The concentration sensor is
subjected to stray light (no cover,
front cover open).
• The photosensitive drum has
deteriorated.
In error code E020-0481, means that the problem is in black developer. So I would first try to replace Bk developer, check the developer station for malfunctions ( broken gears, broken developing roller bushings,... ).
Hope that helps!
Jun 20, 2011 | Canon CLC 1180 Copier
Canon ClC 3200 , ERROR CODE E-000602-FF13 , HOW CAN I FIX IT ?
program u r hdd or go to service moode press copier , function . system and press hdd check select this one & press ok it is starting from 100% & it will be cuming to be 0% or ok.
May 04, 2011 | Canon CLC 1120 Color Copier
Canon CLC 3200 error 000002-0102
This is mainly caused by Power Problem in cannon 3200, Change the complete fuser assembly as one of the thermistors has gone open circuit, just by ordering up the single parts costs the same as buying the complete thing. Also, if required, reset the code *28* function.
good luck, feel free to get more assistance, do rate the solution if got help.
Dec 09, 2010 | Office Equipment & Supplies
Error code E350-0000 on canon clc 1000
the connection between eco-id pcb and reader controller is faulty, canon do not make reader controller anymore
Sep 03, 2008 | Canon CLC 1000 Color Copier
hi how do solve this problem system error E007
Dec 04, 2007 | Canon CLC 1140 Copier
Clc 1150 error 350
Normally only the canon service center will tel you what the error codes means. Suggest you call them .
May 18, 2007 | Canon CLC 1150 Color Copier
1,966 people viewed this question
k24674
jasbo
jasbo
