Question about Whirlpool Washing Machines
Whirlpool Two Speed Automatic Top Load Washer. Problem:Won`t drain or spin. Will go thru the wash cycle, and then stops with no thurver sounds from motor.The lid switch seems OK with clicking sound when opening or closing the lid. This happens on the 3 different wash cycles [ regular, casual permanent press and hand washables ]. Is the control timer at fault?
  • sandy Aug 02, 2008
    water will not drain as machine is spinning on 2 cycles. The third cycle won't start spin cycle unless you jiggle on /off knob. 1 out of 30 times, it might connect, and will then drain and spin as normal. Help!
Thought the timer was at fault,however wasn`t fully convinced is was as the problem happened on all the other wash cycles.
This led me to checking the lid switch.Metering the wiring to it indicated the switch was not working.
After removing this lid switch, I noticed the plastic casing was coming slightly apart.So do not rely on `` the clicking sound``[ when opening and closing the lid] to indicate the switck is OK.
This casing is bound to fail with time and lid use and abuse [ held together at 3 points with very small plastic clipping points which fail, resulting with an internal spring pushing the casing apart so that you still get the ``clicking sound`` but the contacts not working] .
My solution was to use a plastic cable tie to pull the switch casing together and ``bing``the switch is working and the washer is back in service [ No need to buy a new switch ].
Posted on Jul 18, 2008
    Novelist:
  • 177 Answers
I would start with a timer replacement, since the motor circuit works for fill and agitate.
Question if you want to repair or replace washer, cost vs age, useage, etc. etc.
Posted on Jul 16, 2008
Stops during rinse cycle and won't pump the water out
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer model LSR5232LQ0 won't drain. just stops. is there way to cause drain?
heatman101
Aug 22, 2011 | Whirlpool Washing Machines
Hi I have a 5 cycle 2 speed top load whirpool washer and it all of a sudden will not go to the Spin Cycle and drain out the water. It stops in the rinse cycle. I need help!
heatman101
Jun 25, 2011 | Washing Machines
Water is not draining out when thru with cycle?
heatman101
Oct 11, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Will not spin clothes
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washing Machine that doesn't complete the cycles
I too have a whirlpool top load and it did the same thing. I would put a load in and go back and the clothes were sitting in water. I found that if you close the lid and press gently til you hear a click, it will finish the cycle. So now when I load the washer, I press the lid like that and I have not had the problem since. I hope this helps.
Jan 20, 2009 | Whirlpool GR399LXHS Electric Kitchen Range
Washer will not drain after wash cycle or the spin cycle
check to see if your pump is slightly plugged with a sock or ?
Your top loader should pump out in about a minute and a half when totally full of water.
Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
Washing Machines Logo
180 people viewed this question
Dan Webster
Dan Webster
Sal De
