Question about Microwave Ovens
No temperature increasement
Although everything seems to work good there is no temperature increasement in the ovev. Does it mean that there is no micorwave "broadcasting"? Is this a magnetron problem?
thank u in advance
  • arthurskg Jul 16, 2008
    i didn't find a solution
  • 2,071 Answers
WHAT IS WRONG WITH YOUR RANGE / STOVE / OVEN?
no temperature increasement - small_13_33.jpg For a detailed Range/Stove/Oven illustration, click below.
redarrow.gif Gas Free Standing
Electno temperature increasement - redarrow.gifnding
redarrow.gif Gas Cooktop
redarrow.gif Electric Cooktop
redarrow.gifGas Walloven
redarrow.gif Electric Walloven
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It's stopped completely
It won't bake
It bakes poorly
It won't broil
A burner doesn't work
A burner works only intermittently
I can't adjust the burner temperature
It won't bake or broil
The clock stopped
The temperature is wrong
The oven light doesn't work
There's a self-cleaning problem
The oven door won't close
An indicator light doesn't work correctly
The oven is hot on the outside
I see sparks!
The drip pans need replacing
Posted on Jul 16, 2008
  • Microwave Ovens Master
  • 19,396 Answers
Test the oven heater for continuity first, check also oven controls.
  • 1 more comment
  • Ginko
    Ginko Jul 16, 2008
    Sorry , it is a Microwave. In the microwave there is no heating element, there is a magnetron tube that creates the microwaves. This is probably faulty.
    Here is explained how to test the magnetron
    Remember , working on microwaves is very dangerous, exposure to microwaves radiation can cause cancer and leukemia.
    Contact an expert repairman to service your appliance.
  • Ginko
    Ginko Jul 16, 2008
    Here you can order a replacement magnetron, just input your model details.
  • Ginko
    Ginko Jul 16, 2008
    Generally, if your microwave never heats it is the magnetron.
    In your case, as it seems to work on certain programs, the repairman
    need to test the power diode, and check that the program control is
    working, testing the timer contacts. also burnt capacitor may cause
    heating problems.
    The whole thing should be around $60.
    Check if your microwave is under guaranty cover and if it is worth repairing.
Not Heating
if ventelation fan lts work ok thats mean the problem in hv circuts
you must be have an ohm meter to test
http://031d26d.namesecurehost.com/mwd/kot-150_kot-151_kot-152_kot-155_sm.pdf
read this servis manual its good :)
Nov 25, 2013 | Hamilton Beach Microwave Ovens
My kenmore microwave will not heat, everything seem to be functioning but the food does not heat.
Assuming all lights are functioning, etc. Is there anyway that it has been set in the timer only mode? Usually a microwave ( their little computer operating system)can be reset, by unplugging and leaving unplugged for a few minutes then replugging. Depening on the age of the micorwave, it may be simply worn out. the newer ones do not lst anywhere as long as the older ones did..but then they cost a lot less as well.
Dec 16, 2010 | Microwave Ovens
What does the F5 code mean?
F5 error message most often indicates a failed electronic control (although it can sometimes be caused by a failed oven temperature sensor. The sensor should be checked before replacing the control. It should read about 1100 ohms when at room temperature.
May 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave wont heat food. Everything else works.
Micorwave doesn't work when the megatron tube is out. That's probably why it won't heat up. Either replace microwave or the tube. You can get the number from Sears for the megatron tube by calling customer support.
Nov 09, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Have a whirlpool mh7130xez over range micorwave, everything works great but the suface light? beeps when i push the button? tried 3 new bulbs---please help
The relay for the lights is not working. No board level repairs. You will have to replace the control board to get this feature back.
Eric
Sep 01, 2009 | Microwave Ovens
Panasonic microwave oven NN-S235WF modle
just replace micorwave power out let.
Dec 30, 2008 | Microwave Ovens
Emerson Micorwave oven MW8108P
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part such as high-voltage rectifier diode
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and
replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 30, 2007 | Emerson MW8108P Microwave Oven
Microwave Ovens Logo
126 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
