Question about Britax Eclipse Si - Paris Convertible Car Seat
Britax eclipse Have just been given britax eclipse car seat from a friend who took it apart to wash cover. I have no idea how to put straps back in. is it possible to explain? Or can you tell me where i can get a manual?
  • 3 more comments
  • Anonymous Aug 01, 2008
    i have been givena Britax Eclipse Vogue car seat - EXPO25413.
    i had to take it to bits to wash and scrubb it. it's great now but I have no idea how to put the straps back on. I'm scared that it will be unsafe if I don't do it as per britax's instructions - can anyone help please
  • Anonymous Nov 10, 2008
    how to assemble chair straps
  • gaylelsmith Jan 01, 2009
    Hi there, I too have the same problem - I cannot see anyones solution on this site or am I looking in the wrong place? can someone please advise me how I fit the straps back together after washing.
    Many Thanks
  • steven_patto Jan 28, 2009
    i have done the same thing, any solutions as of yet?
  • Anonymous May 06, 2009
    I also have the same problem where I have been given a britax eclipse car seat and I took it apart to wash and clean and now cannot remember how to put it back together safely, can anyone help please. Trish
Try Britax.co.uk, they have all the user guides and instructions available for free download. i had the same problem as i washed the seat covers and then couldn't remember how to put the harness back. Hope that Helps.
Posted on Feb 09, 2009
I have the same problems, i've removed mine to wash and adjust the straps, but have no idea how to remove them, need help ASAP
Many Thanks
Posted on Nov 12, 2008
  • jan_jones62
    jan_jones62 Jul 23, 2012
    go to helpmothercare.com there are instructions and diagrams how to put the harness back after washing the cover
Need to remove the cover from a britax eclipse si..how
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
Feb 24, 2011 | Britax Eclipse Si - Chantilly
Need help reassembling the straps after washing the seat cover
First turn seat upside down. There should be a slot on each side under the seat, run strap through each slot and turn back over. Pull strap up evenly, put on clasp part on each side, then put chest clasps on, run your straps through back and secure to strap comes between legs.
May 08, 2009 | Century Encore 5-point Harness
How do I put back together the straps on my car seat
would assume you're talking like a booster seat with the back just no 5pt harness. You just buckle them up like you do. If they have those arm rest looking things, the part where it buckels goes under that one arm rest and the shoulder strap should go resting over his shoulder like yours. Some of them have a loop up top for the shoulder strap to go through. Just make sure that the toddler does NOT put their arm over the shoulder part of the belt. If you get into an accident this could break his/her ribs.
Apr 20, 2009 | Britax Eclipse Si - Paris Convertible Car...
Car seat adjustment for britax eclipse
Tilt seat back and slacken straps fully. Follow each shoulder strap through back of seat and down towards lower back of seat. There you will find (maybe hiding under a plastic cover) a metal bracket that retains the straps. You can slide the straps out of this, pull out and thread back through at a higher point.
The actual tension adjust ment is usually a metal clip that you push or pull which is located in the centre/ front are of the seat, or front/centre, underneath where the child's feet hang.
Apr 05, 2009 | Britax Eclipse Si - Paris Convertible Car...
Harness straps off cosco car seat to wash cover, help reattaching
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
Mar 08, 2009 | Century Encore 5-point Harness
A manual for britax freeeway wanted
Not really a solution, as I can't help with putting it back together, BUT the Freeway was retired in 2001. That means that any of them still out there are now well past the 6 year expiration date, and therefore, no longer safe to use. I know car seats are not cheap, but please destroy these out of date seats and put your little sweethearts in non-expired, safer seats.
Car seats expire not only because the technology changes, but also because after a few years, the plastic, like any other material, begins to degrade and weaken even if it looks fine. There's a great video here to help show this.
Jan 07, 2009 | Britax Eclipse Si - Paris Convertible Car...
Harness on seat
I DID THE SAME THING. BUT DO NOT FEAR I FOUND A LINK YOU COULD USE. IT TAKES YOU TO THE WHOLE MANUAL. I HOPE THIS HELPED.
Dec 17, 2008 | Britax Eclipse Si - Paris Convertible Car...
Britax Car Seat First Class SI
i took the cover off the car seat and straps to wash the cover but have no clue how to put them back on.
Sep 03, 2008 | Britax Eclipse Si - Paris Convertible Car...
Britax Eclipse Si - Paris Convertible Car Seat Logo
1,198 people viewed this question
Top Britax Baby Gear Experts
thegtw
Jennifer Rock
Jennifer Rock
Dorel UK
Dorel UK
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
