Question about Dual XINBP-210 Car Subwoofer
The lights are off
The subwoofer works good, but i can't get the blue lights on.
  • elivirt Jul 17, 2008
    I have a pair of wires coming from my amp (Boss Riot 975r).
    One is red (connected to the positive outlet) and the other one has no color (just the clear wire connected to the other outlet).
    Any suggestion?
  • Billy Joel Apr 26, 2009
    I would like to kno if anyone knows were to get new of the light up faceplace, incase the bulbs are broken or there is a defect in them
  • 109 Answers
Do you have a 12 volt power running to the lighting plug? That enclosure requires a seperate 12 volt power line in order to make the lights come on.
Posted on Jul 17, 2008
  • InVision_A_V Jul 17, 2008
    You need to connect one power and one ground (+ and -) to the appropriate slots on the enclosure. If you don't know what you're doing I recommend that you take it to a professional shop and ask them to do it or show you how.
Hooked my subs up to speaker wires and the subs play but the lights do not play what do i do
Posted on Apr 16, 2010
Make sure both wires are both connected and not frayed or touching and if that doesent work then there may be a problem with the light
Onkyo skw 591 subwoofer...blue light is on and no sound? any thoughts?
Hello, To test the subwoofer when the blue light is on if you apply your thumb to the end of the subwoofer cable (the end that you would plug into the receiver) there should be feedback from the sub. If there is no feedback then the sub is not working correctly. Thanks, FJD
Apr 27, 2016 | Onkyo Audio Players & Recorders
Subwoofer deconnects
I have no experience of wireless speakers but I think you should contact the seller, if the unit is still under warranty or perhaps the support section of the manufacturer's website.
Certainly do read the instrucion manual.
I am guessing but either the wireless signal is being lost (depends on the function of the blue light) or the subwoofer is malfunctioning after a few minutes and the built-in thermal or overload protection is switching it off. The thump sound could be it trying to switch on again and finding the fault is still present.
Just my thoughts...
Apr 02, 2016 | JBL Cinema SB350 Home Cinema 2.1 Soundbar...
HTS14 subwoofer (Harmon Kardon)powers off after 10-15 minutes
Yeah, it sounds like it's over heating. Are you driving it way loud?
May 23, 2014 | Audio Players & Recorders
I have a blue pyle 12 inch 800 watt tube for my car. I've wired everything perfectly, yet when I go to turn on my radio, it doesn't work. The blue lights cut on, but the speaker itself puts out...
it could be few things one the light might come on but the preamp could be bad two could be a loose wire to sub three sub could be bad four make sure rca cables are good i hop this helps
Feb 21, 2013 | Car Audio & Video
Klipsch Synergy Sub12 Subwoofer Speaker
If it's a new model you should send it back.
If it's not then it sounds like the thing that does all the work has gone. It will be found on a heat sink. Try replacing that.
Jan 25, 2013 | Klipsch Synergy Sub12 Subwoofer Speaker
I'm having trouble connecting my alpine cde-9852 to my 96 jeep cherokee. is there a wiring diagram online for this? thanks
Constant 12V+ Pink Switched 12V+ Purple/White Ground Black Illumination Light Blue/Red Dimmer Orange Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Dark Blue/Red Rear Speakers 5 1/4" Rear Deck Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Dark Blue/White Right Rear (-) Dark Blue/Orange
Jul 11, 2009 | Alpine CDE-9852 CD Player
Why are my brake lights not working on my 1997 chrsler concorde? The fuse and light bulbs are good. I've heard this may be the brake light switch. If so, where is this located?
switch is at top of brake pedal. wire colors are PINK/DK BLUE and WHT/TAN. check to see it is actually contacting when pedal is depressed.
Jul 09, 2008 | Car Audio & Video
Energy S8.3 Subwoofer
I have the exact same problem with my S8.3 that I purchased a few months ago. It's just the blue LED that doesn't light up, otherwise it seems to output bass and the volume control works. Any suggestions?
Jan 16, 2008 | Energry Speakers Energy Speakers S8.3...
Rear speaker install
the brown wire is the LR+,yellowLR-. The drk blue is the RR+,lt blue is the RR-.If this dose not work test speakers.IF speakers work make sure you have a good output from stereo with the old speakers.Are you using the factory deck?
Dec 29, 2007 | Pioneer TS-A6962R Car Speaker
Dual XINBP-210 Car Subwoofer Logo
157 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
