Question about Tomtom ONE GPS Receiver
Tomtom battery not charging
I my tomtom one is not charging and the charger is working can I change the battery myself. I have had the unit for 2+ years
MIne had the same problem. Seems that there is a pin inside the machine that fits on the inside of the connector that goes in bottom of machine. That piun was broken off inside the charging end and only made intermittant contact causing machine to go flat.
Contacted TomTom and since it is over 2 years old and I cannot find my original receipt they will not fix it. They agreed when I suggested that should I throw it in the trash?
What about that for customer service No More TOmTOm products for me.
Also the power switch was so diffcult to turn on or off, often needed a coin to get it to switch.
Also my street not on their maps and its been here for 15 years!
If you can find a Torx security screwdriver of the right size you can get to the inside. Since they will not even repair mine for a charge I have no other choice.
Posted on Jul 19, 2008
Tomtom white screen
Your battery is faulty, probably caused by the non tomtom charger.
Ring tomtom on 08451610009 as the unit is 6 months old and they will repair it free of charge. DON'T tell them about the other charger.
White lined screen is a battery problem
Feb 17, 2014 | GPS
TomTom Rider unit wont charge. Tried mains charger, USB connector and bike charger. Swapped out the battery and the unit boots up but that is just the charge in the new battery. Any help appreciated.
Power board is faulty, repair or replace. Workshop repair required. Oh, stop plugging a charger into the USB socket. It doesn'tlike it, thats for data transfer only. The round pin socket is the charger port
Oct 30, 2013 | Tomtom RIDER GPS Devices
My Tomtom 300 Go won't charge?
It appears that the battery will not hold a (good) charge anymore. If it is still under warranty, contact TomTom to address that problem. They may replace the unit for you.
It is not unusual for (rechargeable) batteries to loose it's capability to hold a good charge if it is plugged in (to a power source) all the time, even while it is not in use.
May 06, 2012 | Tomtom GO 300 GPS Receiver
Tomtom 720GO wont turn on
The problem was solved as described in my posting of Aug.15,2009
Aug 15, 2009 | Tomtom GO 720 GPS Receiver
I have a question concerning the tomtom 910. When plugged into the car, the tomtom goes off and on and the battery is constantly low. However,when I charge it at home, it stays on for about 4 hours. What...
Connect your TomTom to the car charger and turn it on. Tap the lower right hand cornor where the sat. signal graph is. On the screen that comes up check to see if it is chargeing while connected to the car charger. It should say charging in the upper right hand cornor where it shows the battery status. If it isn't charging then you have either a bad pin on your windsheild mount or your charger is not working. If the charger is not working it may be as simple as replacing the fuse in the charger.
Jul 19, 2009 | Tomtom GO 910 GPS Receiver
Broken mini USB port on TomTom One
It can be done with difficulty. I change them on a regular basis though as i run a repair business.
If you want me to change it I can do it for a small fee.
paul@cosmicstudios.co.uk
Dec 19, 2008 | Tomtom ONE GPS Receiver
Tom tom will not charge using 12 volt charger
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
Nov 17, 2008 | Tomtom ONE GPS Receiver
My tomtom 910 will not charge
Might be the contact of the charger. That's my fault after years of usage
Jul 27, 2008 | Tomtom GO 910 GPS Receiver
Charging the Tom Tom - unit shuts off with car charger plugged in
your rechargeable battery inside has a limited life and has to be replaced when this problem happens.
May 28, 2008 | Tomtom GO 510 GPS Receiver
Tomtom300 gps mains charging +
1= My battery is flat, but when i put it on charge in the house it doesnt charge and no green light comes on, on my sat nav why would this be?
Could be your house charger is bad or the power connector on the back of the Tomtom is bad.
2= But when i put it in car charge it works perfect 'Y'?
You are using the "power shoe" to charge the battery. For a test unplug the power cord from the power shoe and hook it to the back of the Tomtom. If this work then the house charger is bad. If this doesn't work then the Tomtom rear power connector is bad
3= If ever i have to change battery how is this done?
You will have to remove the faceplate and disassemble the Tomtom in order to get to the battery. Or you can find a shop that repairs small electronic. Find the battery on Ebay.
Jan 12, 2008 | Tomtom GO 300 GPS Receiver
Tomtom ONE GPS Receiver Logo
1,256 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
