Problem with nec NHD-3000PVR no display on TV, cannot get anything to display at all.
Check to see if the tv's format is compatible with the dvd player(e.g. NTSC/PAL)
Posted on Jul 17, 2008
URGENT: How can I connect my tv to my NEC VT695 projector?
Do you want to duplicate the image going from the source to the projector on your TV? If so, then if your TV has a VGA port, just use the monitor Out on the projector. If your TV doesn't have a VGA port, you'll need an appropriate converter. (Avoid a VGA to component video or VGA to composite cable.) If you add a comment with more information on the inputs for the TV (or the model of the TV), then I will try to point you to the correct converter.
If you want to get your TV signal to the projector, you would need a set-top box (cable, satellite, digital tuner) as the source. Most TVs do not have a video output. You can connect a computer or DVD player to the projector.
The manual and quick guide for the VT695 are available from NEC here: http://www.nec-display.com/dl/en/pj_manual/vt695_491.html . The direct link to the English language version of the manual is http://www.support.nec-display.com/dl_service/data/manual/english/vt695_491_manual_e.pdf .
I hope this helps.
May 25, 2014 | Office Equipment & Supplies
Is there anyway that i can connect a nec vt695 to my tv
Hello.
Connecting the nec to your tv, I think you mean you would like to get the TV's picture out from the NEC instead of the TV.
You need to connect your digital cable box or dvd player or vcr system, where the picture goes to the tv, to the projector instead to get it to display the tv picture.
Can't guarantee that it would work without knowing more about your equipment.
If that is not what you wanted to do then I do not know.
Sep 19, 2010 | NEC VT695 LCD Projector
Remote and manually not working ,batteries ok,power on ok ,no obstacles blocking remote,turned off power worked for short time, stopped again.nec high definition receiver,model nhd-2000
one of the batteries was not making proper contact and was loose,had to gently stretch spring contact out to make it stay in place .kept dislodging itself,so far so good.thanks
Dec 06, 2009 | One For All URC-5705 Remote Control
Hi, I have an NEC hi-def-receiver, model NHD-1000, just recently it has been turning itself off, power is still there, has 4 lines instead of time but it loses the signal. 4 symbols appear when it shuts...
I had the same problem and found it was caused by dry solder joints in the output pins of the power supply board. Solved it by resoldering the joints.
Nov 24, 2009 | Kitchen Appliances - Others
NEC NHD-2000 HD Receiver - no power
TEN TO A PENNY THE REGULATING IC WITHIN THE PRIMARY SUPPLY HAS BLOWN AND IF THAT IS SO THERE IS NO REPLACEMENT FOR IT. I AM TRYING TO FIND THE CIRCUIT FOR IT SO I CAN FIND ALTERNATIVE SO I CAN FIX MY OWN.
BUT OTHERWISE BUY A NEW ONE THE CHEAPEST YOU CAN FIND JUST AS GOOD AS THE EXPENSIVE ONES
Dec 28, 2008 | Televison & Video
Ariel
Its NOT a TV, its a display. It does not have its own TV tuner or RF converter. You have to runit from a VCR, A DIgibox or SKY TV.
Jul 27, 2008 | NEC PlasmaSync 42MP3 42 in. Television
Projectile motion
Dear Sir,
I have NEC 42vR5 HW Plasma monitor, this plasma goes off with in 1 Minute, pls. give solution
thanks
pramod
Feb 24, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
NEC LCD1980SX - displaying colored blocks not synchro
Have tried NEC technical Support? This looks like a circuit boatd problem
May 31, 2007 | NEC MultiSync LCD1980SX-BK 19" LCD Monitor
Televison & Video Logo
258 people viewed this question
Top Televison & Video Experts
