Question about Traulsen Refrigerators
Traulsen 30 x 80 two door refridge- runs loud
It is seven years old and was just moved (on its side) to my place this evening. When I plugged it in it was incredibly loud. The past owner told me to unplug ity and let it stand for 2-8 hours but that hasn't helped at all.  I am in NYC. Please help. thanks in advance
  • 41 Answers
This is bad. you have one of 2 things going on if the noise is a rattleing in the compressor that is like viborating it,s probably a broken or unhooked support spring no fix could be also the oil left when it was on its side fi thats the case its still in the system run it and hope it comes back befor the compressor sets up one last thing did you check to see if its just a fan blade hitting somethig? dan
Posted on Jul 16, 2008
Why does the condenser keep getting ice build up on it. I have cleaned the ice off two times now. My refrigertor is a 4 door glass Traulsen that is 24 years old. The drain tube on it is clear of ice its...
does it have a defrosting element and if it have does it work and in what conditions are the door rubbers. and does the fridge switch on and off
Jul 19, 2014 | Traulsen Refrigerators
Ice build up in the freezer
Sounds like your door seals are not seating causing moisture to migrate past the seal and condense and freeze. Check to see if this is true will small strips of paper. If you place the strip in the door and pull, you should have some resistance. If you pull and it moves freely, your door seal needs to be realigned or replaced
Jan 13, 2018 | Amana ARB1905C Bottom Freezer Refrigerator
My refridge isnt cold enough but my freezer isthe fan sounds like its running and the condenser is on. also the fan/condenser are never turning off by them self
This has happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side continued to climb. (The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall, so if no air is moving in the freezer compartment, temps in the fresh food compartment climb.)
I replaced the temp sensor in the fresh food side and solved the problem for a while. About six months later I had the same problem again, so I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites ( and may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Jul 28, 2009 | GE Refrigerators
Refridge door does not close evenly on my side by
Top hinges can swing right to left slightly when all 3 screws are loosened under removable cover. Use a 5/16 nut driver. Hinge cover may be phillips, 1/4" or 5/16".However, fridge case must be level left and right first. Level fridge with adjusters behind toe kick cover. Once level, you can adjust gap between doors with top hinge movement. Keep in mind that this is a man-made product and you may not get the doors exactly straight due to lose manufacturing tolerances.
Jul 24, 2009 | Refrigerators
Traulsen 30" two door frodge 7 years old (just moved today)
Compressors don't like to be laid down, the rotor swims in lube that is disturbed when horizontal.
If the compressor isn't ruined, the noise could emanate from the fan that most units have, sometimes two; one to circulate air around the fins, another to stir air inside.
Pull the plug on the fridge while it is running and try to listen to the character of the noise before it stops.
If it is very rapid; I suspect the compressor is history.
If it makes kind of a singing noise while coming to a stop, it could be fan blades hitting something.
Jul 16, 2008 | Traulsen G10010 Refrigerator
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Traulsen 2 door freezer
Traulsen Freezer Compressor Change Out Video
Dec 05, 2007 | Freezers
Refrigerators Logo
242 people viewed this question
Top Traulsen Refrigerators Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
John Tripp
John Tripp
Are you a Traulsen Refrigerator Expert? Answer questions, earn points and help others
