Question about Panasonic Microwave Ovens
It is a Dimension4 the Genius NN-C2000W Inverter Microwave. When we use the microwave function it automatically cuts out the microwave and power fuse. however, we can use the convection and griller function that works ok. I replaced the magnetron (2M236-M1G) and fuse. when we tried to use the microwave function after I replaced these components, it still shorted out the power and would not work. what else could causing this problem? Please help!
  • 100 Answers
You most likely a shorted capacitor which is causing the fuse to blow. This is part of the microwave HV system and isn't in use during convection cycles.
Posted on Jul 17, 2008
Panasonic invertor Dimension 4 Genius NN-CD997S. Comes on for about 2sec then switch automatically to cool...happens with all the functions
Inverter or Mag $ !!!! Probably time for a new unit. If Possible, Stay away from those Horrible Inverters!!!
Jun 05, 2017 | Panasonic Microwave Ovens
Trouble code H98
H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
R
Oct 03, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
Model: NN-SD277W.     serial number: 6A88040672 A.
There is a dead short in the microwave oven that can be any number of things, yes you will need a pro to fix this and I suggest an estimate first.
Mar 12, 2012 | Panasonic Microwave Ovens
My Panasonic microwave, Dimension4, The Genius, will not keep running after start button is pushed. It runs for only two or three seconds.
There is a thermal fuse that monitors heat from the magnetron, sometimes becomes defective, the magnetron "heats food" filiment will open on occassion, if the exhaust fan is not running microwave will shutdown.
Mar 09, 2012 | Panasonic Microwave Ovens
Panasonic nn-c2000w microwave oven no longer heats anything up and turns off after less than 30 seconds
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 20, 2011 | Panasonic Microwave Ovens
Where can I find manual for Genius Sensor 1300w
http://service.us.panasonic.com/OPERMANPDF/NNSN657S.PDF
Feb 07, 2011 | Panasonic NN-SN657SMicrowave Oven
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
Panasonic dimension4 microwave
check the damper motor is opening and closeing
Jan 17, 2010 | Panasonic NN-T888S Convection/Microwave...
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Microwave Ovens Logo
240 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
