Question about Epson Stylus C66 Photo InkJet Printer
Epsom printer d68
Message says parts in printer are coming to end of service life
  • Anonymous Aug 22, 2008
    parts are coming to end of service life
  • Sirrobin May 11, 2010
    How can I reset the counter in the Epson C66 printer?
  • Epson Master
  • 691 Answers
The message means the waste ink pads are full and the internal counter in the printer needs to be reset.
you can take the machine to an Epson Express center who should be able to reset the counter in about 30 seconds. Changing the pads is a bigger job, but if this is the first time the machine has been reset you can probably skip the pad change and just go for the reset.
You could make a modification to the printer to use an external waste tank instead of the pads. Then whenever it reaches the limit again, you can just reset it.
Please rate this post as fixya.
Posted on Jul 16, 2008
I am getting an end of service life message. what
The printer is telling you that some parts are worn-out -- "end of life" -- and your printer either needs to have some parts replaced. Or, replace the entire printer, after comparing the cost with an estimate of parts/labour to fix the old printer.
Jan 14, 2010 | Office Equipment & Supplies
It's is asking service required,
parts inside your printer are near the end of their service life. This is message is coming, how can i do this problem, please tell me
Sep 06, 2009 | Epson STYLUS R230 InkJet Photo Printer
How to reset manualy the counter on epson d68
Manual instruction Resetter Printer Epson D68
  1. Switch on printer
  2. Open auto.bat to set the date to 19 June 2006
  3. Run adjprog.exe from the extracted folder
  4. Click accept
  5. Click particular adjustment mode
  6. Go to maintenance then Select waste ink pad counter then click ok
  7. Click on “check button till its done then click on initialization button then click on finish button
  8. witch off printer for 5 secs then switch on again
  9. After you reset succesfully, you can change the date back to normal.
Please rate my solution after reading. Thank you
Mar 05, 2009 | Epson RX620 All-In-One InkJet Photo...
Parts inside your printer are at the end of their service life. See your printer documentation Parts inside your printer are at the end of their service life. See your printer's documentation for details
when i swich on my Printer C43, both the indicator lamp is blinking, and tehn appear the message:
"Parts inside your printer are at the end of their service life"
Feb 26, 2009 | Office Equipment & Supplies
Service required error
Ok.. aside from the fact that you've posted under the R300 Epson model thread you're still in luck.
The CX6600 has been documented (by me admittedly) with a complete guide to fitting an external tank and resetting the waste ink counter in the printer.
Just to note: This is a commercial site but the information provided is generic and will help you fix the problem.
Feb 15, 2009 | Epson Stylus Photo R300 InkJet Printer
Epsom C62
Try putting your question in the correct section: Epson C62. This section is for the CX6600 and is not appropriate for your machine.
Jul 02, 2008 | Epson Stylus CX6600 All-In-One InkJet...
plz go to printer setting & clean durme
Mar 03, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Possible that the waste ink collector is full. (When you clean the cartridges, some ink is used, and that ink has to go somewhere!)
Might be worth having a look at
(at your own risk, of course :) )
Jan 02, 2008 | Epson Stylus C48 InkJet Printer
try replacing the cart. again with factory ink cart.
Dec 06, 2007 | Epson Stylus Photo RX700 All-In-One InkJet...
Error message "Parts have reached their life end"
Thanks for the suggestion. The problem has been solved by pressing the 'power', 'stop' and 'maintenance' buttons simultaneously for about ten seconds. It makes a terrible noise for a couple of seconds (like gears grinding) but it resets the printer. Apparently this is a ploy by Epson when genuine Epson inks aren't used, to encourage you to get your printer serviced!! At a cost of course.
Nov 12, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus C66 Photo InkJet Printer Logo
245 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
