Question about Traulsen G10010 Refrigerator
Traulsen 30" two door frodge 7 years old (just moved today)
Help my new fridge makes a racket. didn't make this noise before it was moved (on it's side). I plugged it in for an hour before learning it was suppose to stand for 8 hours before running again. I am in the lower NYC area. Who can I call here and is there anything I can try before calling someone?
  • 1 more comment
  • noisybox Jul 16, 2008
    this fridge is "new" to me- but is seven years old-
    It's a Traulsen 30" x 80" two door fridge only- no freezer (blue color).
    also the glass upper door is fogged - may need to be replaced - but not related to noise problem.
    thanks in advance for your reply
  • noisybox Jul 17, 2008
    Many thanks Freetek:
    I unplugged it and it just sort of stops -but there is not a rapid sound though.I was going to describe the noise as a whirring sound- tinny or bell-like - maybe that's the singing sound you describe (but not nice sounding- the whirring has some "depth" like a bell) but I hear this sound most of the time and not only when I unplug it- before there's silence.
    When the fridge reaches its temperature the sound shuts down for a while and then starts up with the tinny whirring again.
    Is the cleaning of the fan/s somethig I can do myself or do I need to call a service person? I called Traulsen today and they told me the compressor is $1,000.00 so that's out of the question.
    Thanks again for your help- I really appreciate it. Any more thoughts or suggestions are appreciated. My electrician told me to consider hari-cari but I'm tryig to keep calm.
    -Andrea
  • Traulsen Master
  • 5,568 Answers
Compressors don't like to be laid down, the rotor swims in lube that is disturbed when horizontal.
If the compressor isn't ruined, the noise could emanate from the fan that most units have, sometimes two; one to circulate air around the fins, another to stir air inside.
Pull the plug on the fridge while it is running and try to listen to the character of the noise before it stops.
If it is very rapid; I suspect the compressor is history.
If it makes kind of a singing noise while coming to a stop, it could be fan blades hitting something.
Posted on Jul 16, 2008
  • Steve Allison
    Steve Allison Jul 17, 2008
    I hope the $1K cost for the compressor is Singapore $ since the compressors typically cost $2-400 US and installation is about two hours max.
    The sound you describe could very well be a fan blade striking something.
    If the cooling coils are located under the box, the fan will be there too; not necessarily easy to reach, but many are installed in the rear and draw air through the front and over the coils.
    I'd look there first.
    If the cold air is circulated by a fan, that will entail removing some of the inner liner to reach since they are normally concealed with only their in-outlets visible.
    In most units, these are located topside and may require some careful examination to locate.
    If the sound is quite prominent, it is most likely the outside fan and these are not tough to replace (well, in most refrig., anyhow) and the cost should be well under $30 US.
    Keep lookng -
Why does the condenser keep getting ice build up on it. I have cleaned the ice off two times now. My refrigertor is a 4 door glass Traulsen that is 24 years old. The drain tube on it is clear of ice its...
does it have a defrosting element and if it have does it work and in what conditions are the door rubbers. and does the fridge switch on and off
Jul 19, 2014 | Traulsen Refrigerators
My 10 year old fridge is making a racket of a noise. I am defrosting it, what next?
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Jan 29, 2011 | Fisher and Paykel Refrigerators
Sounds like a squirrel inside water heater
The noise is inherent in electric hot water heaters. It is the noise that the water makes when it is being heated by electric heating elements. Mineral buildup on the elements can make it worse, so changing the elements can help...but will not totally elimenate the noise. When I install a new tank and turn it on all I have to do is listen to it to see if it is working or not...even brand new will make a sound...it is the sound of hot water... :-)
heatman101
Mar 25, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Mar 29, 2009 | Kenmore 44072 Front Load Washer
We have a relatively new Bosch fridge-freezer. It has started chuntering away like a motor-bike in the corner of the room. It flls silent if either door is opened. Sometimes it falls quiet and runs sweetly...
Hello mathsmike,
Welcome to fixya,
You said,We have a relatively new Bosch fridge-freezer. It has started chuntering away like a motor-bike in the corner of the room. It falls silent if either door is opened. Sometimes it falls quiet and runs sweetly for hours before starting this racket again. Any ideas?
What is the Complete model number and the date you bought the fridge!
It sounds like it may be a faulty fan or fan clutch from here, if it's not something else very simple!
Send me the info requested and do a repair search for you !
Waiting for your response!
Huuum
Here are some common noise problems till I look your unit up
1.Check that the fridge is level, using a spirit level!
2. Appliance is touching some other unit or appliances, or counter or wall.
3. Drawers, baskets,or storage ares are loose, or sticking!
4.Receptacles or bottles are touching. Move them away from each other,
ESPECIALLY ON THE DOOR,because it's quiet when the doors are open!
Oct 21, 2008 | Bosch Refrigerators
Ticking noise getting louder, 30-year-old Whirlpool SbS Refrigerator
Hello strebig
Welcome
You said, you have a ticking noise in your 30 year old refrigerator?
Before we get started here.
Do you know thee efficiency difference between your fridge and any new one?
My fatherly advice is do not put another nickle in to your fridge.
You are putting good money in to bad!
Unfortunately you all ready spent the cost of a new one in the past ten years on electricity.
Today's new refrigerators will pay for them self in a few years and then be a hell of a lot less on your electric bill.
The change from a 30 year old fridge to today's models WILL show up on your electric bill!!!!!
I just read this article that you may find interesting.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Please remember to enter a rating before you sign off!
God Bless, Thank You, HUUUM
Oct 05, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Traulsen 30 x 80 two door refridge- runs loud
this is bad. you have one of 2 things going on if the noise is a rattleing in the compressor that is like viborating it,s probably a broken or unhooked support spring no fix could be also the oil left when it was on its side fi thats the case its still in the system run it and hope it comes back befor the compressor sets up one last thing did you check to see if its just a fan blade hitting somethig? dan
Jul 16, 2008 | Traulsen Refrigerators
Traulsen G10010 Refrigerator Logo
172 people viewed this question
Top Traulsen Refrigerators Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
John Tripp
John Tripp
Are you a Traulsen Refrigerator Expert? Answer questions, earn points and help others
