Question about Panasonic Microwave Ovens
No power going to microwave. - Panasonic Microwave Ovens
  • Panasonic Master
  • 9,086 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
Why doesn't it turn on?
The internal fuse may have opened.
Sep 25, 2015 | Microwave Ovens
No power to microwave
Your microwave will have to be removed and opened up to replace the fuse, if that is what is at fault. It ranks right up there on the pain scale.
Mar 11, 2014 | Panasonic NNSD277SR Microwave Oven
Microwave has power but doesn't cook
There could be significant problems that would merit returning your microwave oven to the store.
Jul 13, 2017 | Oster Microwave Ovens
Samsung microwave malfunction
I too have this problem with my KitchenAid KHHS179LSS-5 model. Based on the owner's manual I located behind the grill which pulled off, the F7 Error code indicates that power to the magnetron was interrupted. You will want to make the following checks: 1. Unplug microwave oven or disconnect power. 2. After 40 seconds, check to see whether this solves the problem. 3. Unplug microwave oven or disconnect power. 4. Check resistance of the magnetron thermostat. 5. Check the magnetron. 6. Check wiring to the 1100W inverter and control system. See "Checking Inverters." 7. Plug in microwave oven or reconnect power. 8. Check operation of all interlock switches. Check door, hinge and cavity front alignment. Adjust as needed. 9. Unplug microwave oven or disconnect power. 10. If switches operate correctly, replace 1100W inverter. 11. If problem persists, replace electronic control. 12. Plug in microwave oven or reconnect power.
After removing the control display, there is a virtual zoo of connectors. So unless you repair microwaves on a regular basis, it may be difficult to ascertain which ones go to the magnetron thermostat. I will probably resport to shelling out the dough to get someone to fix it. Sorry I couldn't be more helpful.
Jun 27, 2013 | Microwave Ovens
Microwave will heat but not very hot 'even on 10 power
not something most average people are going to be able to fix, maybe the Magnetron.
Dec 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
I have power going to microwave from electrical receptical, but the microwave has no power, will not show nothing tme, etc
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 28, 2010 | Kenmore Microwave Ovens
2 difrent microwave problems
is the motor with the fan on it working,thats most licklely the problem
Jul 06, 2010 | Sanyo EM-C1800 Microwave Oven
Kenmore microwave 80404400 no power
This is typical of the 20 amp fuse blown. It can blow due to slamming the door or even opening the door to quickly while it is running. It could also blow if there is a failure of one of the door interlock switches. This fuse is ceramic and looks similar to a cylinder automotive fuse and is located behind the control panel on this model.
Apr 20, 2010 | Kenmore 80412 Microwave Oven
We had an power outage and lost power for a few hours everything came back on but the microwave. I checked the outlet and checked the fuse still nothing. Is there anything that can be fixed?
Hello if you have no power at the outlet, you may have saved your microwave. If the outlet is dead go to your house electrical panel and reset the breaker or replace the fuse. if the outlet is live and the microwave still won't power on you will have to choose between repair and replacement. Definitely get an estimate before agreeing to a repair as microwaves are very inexpensive today compared to even a couple of years ago.
Nov 23, 2009 | Emerson MW8108P Microwave Oven
No power on microwave
CHECK THE FUSE AND THE PRIMARY WINDING OF THE TRANSFORMER.
Apr 07, 2008 | Microwave Ovens
Microwave Ovens Logo
79 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
