Hi, i have this acer 1912 19" lcd monitor, it won't turn on (actually it will turn on if i wait for a few hours). if i unplug the vga cable and press the power button, it will display "acer "and then "no signal" then goes to standby(orange light). but if the vga cable is plugged in and i turn it on then it will display "acer" and then nothing, and i have to wait for hours for it to be back to normal. any suggestions please
  • 1 more comment
  • Rayno Jul 20, 2008
    its not my video card, coz i tried it on another computer and its the same.
    i'll just buy another one, thanks for helping
  • Rayno Aug 16, 2008
    Hi, I still have the same problem, but i have found out something interesting tho, power is ok on the power board, i did not find any capacitors leaking or anything, however, i have found that if i heat up the MCU on the motherboard with a hair dryer or something, then monitor starts to work. when its on, it will stay on until it goes into sleep mode or something, but when its warm, like if i leave it on for hours with out the screen going black, then it can be switched on and off
  • 981 Answers
That's kind of interesting that it comes on after a few hours; what changes during that time, I wonder?  I also wonder what changed since it worked last, for example a power-manager utility on the computer side which isn't quite compatible with the videocard; it seems unlikely though.  So; please describe what happens over those hours: is there a profoundly blank display, or generally dark display with no backlight?  Does it just pop back to perfect operation, or is the backlight out (as if the monitor's sleeping, though the power LED indicates awake) and eventually coming on so you can see what's there?
  I suspect that the backlight is starting to go and the startup circuit (which takes the most stress) is cutting that section out of operation for a while; perhaps the monitor's microcontrollers or a circuit protection device resets.  if you want to open it up you can clear out the dust and look how the backlight and its power units are fitted, and maybe take some pictures for reference, thermocouple readings (temperatures!) on the backlight power sections and backlight itself, solder wires on the backlight so you can get voltage and current readings, and get the backlight make and model.  You can probably convince the same backlight to go for a while longer by cleaning up the supply circuit and replacing a component (FET or circuit protection VOM) that's too hot because of its own derating.
Posted on Jul 17, 2008
  • 36 Answers
Is power steady on it or is it being lost intermittently - if its the later, bring it to a repair shop
If its steady power, try it on another computer, some manufacturers are putting software on their lcd's now so they only work with the same respective pc.
If it works with another computer fine its Your video card on the one it doesnt work with.
Otherwise Your going to have to get the drivers for that monitor onto that pc with another screen
That is what I do not understand. Http://www.notebook-drivers.com/ to be here whether we can help bring to you
Can i upgrade my old monitor to a new acer 19" Acer Monitor
Hi Ricky,
In most situations you won't need any special connections, as most LCD screens have the same VGA interface sockets and cables as your older screen.
Let me know if I can be of any further assistance.
Best wishes,
Graemevm
Jan 24, 2012 | Acer Aspire T120 PC Desktop
My Acer X193w. My monitor comes on and says cable not connected but when I connect the VGA cable the screen goes black even though it is still on.
VGA is an analog connection, so you should connect it to your monitor BEFORE starting up the PC. Otherwise it won't show anything
May 04, 2011 | Acer X193W LCD Monitor
Dell 1503FP works, but won't start up again for a few hours
Hello there.
Seems like electronics pack up but try an old one. disconnect all the data cables from your monitor side(HDMI, DisplayPort, VGA, USB etc.) or computer side if the ones on display are built-in. Leave only the power cable. Unplug the monitor`s power cable. Press the POWER button on the front of the display and keep it pressed for 45 secs. Plug everything back and give it a try.
Good luck.
Jan 18, 2018 | Dell 1503FP 15" LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
ACER AL1715ebm LCD MONITOR BAD VGA CABLE
you are in a bad spot, the plug is sealed when molded. maybe ebay has a defective monitor and you could take the cable off it.
Monitors will usually snap apart with a butter knife.
Jan 27, 2009 | Acer AL1715 (Black, Silver) 17" LCD...
No sound from monitor speakers. Worked fine for 5 years. Can hear sounds when using headphones plugged into CPU. Hope you can help even if only to tell me I need a new monitor. Sincerely Dizzyme.
Hi...there,
First of all, check if your audio cable are still plugged into the monitor and pc output (light green) audio jack. If not just plugged it back in... Still still got no sound... Then turned off the monitor and pc. Unplugged all the cables from the monitor and pc, wait for 10 second till all the surged built up are cleared out. Then you can plugged all the cables back Monitor should have 3 cables, a audio cable, a VGA or DVI cables, and a power cord... OK! now you got all the cables plugged back in...
Turned on the monitor and PC....and a few seconds....you should hear window started. Still... had a problems....just get a external speakers. Have nice day!
Oct 08, 2008 | Hansol H550 15" LCD Monitor
Lcm-17v8 monitor
This is a problem with the cable that runs from your laptop to the monitor.
Or the VGA Output socket, on your laptop itself.
1:) Try using the monitor, on a different PC Or Laptop.
2:) Toggle The LCD/VGA Button on the laptop. ( This should change the display Mode )
Sometimes you Have A fn key, on the keyboard. Press fn And LCD/VGA.
3:) Check that there is no damage to the cable from laptop to Monitor.
If none of the above work, it,ll be the monitor itself. faulty panel or invertor board.
Mike @ Compurepair.
Sep 15, 2008 | Computers & Internet
Acer LCD Monitor only displays "acer" logo
You are correct, it could be a power surge that has caused it.
Try this..
Unplug the monitor from the wall.
Remove all the video connections at the monitor end.
Wait 10 minutes then plug the monitor back into the wall (do not connect the video leads)
Turn it on and see if it goes past the ACER logo now. If so, replace the video cables and try the computer.
If not, then one of these will apply and a tech will be required..
  1. The internal bios has been corrupted.
  2. The power supply inside the monitor may have issues preventing the video board from starting correctly. This could be as simple as a few failing capacitors.
Number 2 is the most likely cause with an Acer monitor though. Any local tech will be able to correct it fairly cheaply, but phone around for quotes..they can vary a lot.
Jun 03, 2008 | Acer X193W LCD Monitor
Sceptre X7G nagaVI problem
For most of the problems above you will find it is bad capacitors on the power board sending unstable power accross to the controller board.
For the last posted problem (Comment by Guest, posted on Jan 02, 2008) you have a dodgy inverter circuit that needs to be repaired.
Both faults should be fairly cheap to have taken care of at your local TV repair shop. You may need to call a few in your area not just for a quote, but also to see if they are willing to work on an LCD monitor.
Hope that helps you all =)
Dec 21, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
