Question about Samsung TSL3293HF 32" TV
No picture on my samsung tv
I have had my 46in samsung tv for a few years now but recently the picture keeps going off but i still have sound i have to turn the tele off for a few minuates then turn it back on but this keeps happening
can you tell me whats wrong with it?
If you have a conventional set, it sounds like you might have cold solder joints around the Horiz Driver Transformer. It's not the large one--the small one.
Posted on Jul 17, 2008
Why does my Samsung LED TV now have a permanent blue hue to its picture?
The t con board digitizes your picture and is responsible for anything you see on the screen including any and all anomalies. I would go that route TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2017 | Samsung Televison & Video
My TV started to cycle off and on recently
Despite having caps that 'look good', the power supply could be failing.
Aug 16, 2016 | Samsung LN46D630M3FXZA - 46in Lcd Hdtv...
What could be wrong with my Samsung tv un46d6000sfxza
If I had a dime for every one of these type of questions I could retire without my pension. The problem with these sets today is that they no longer fall under the category of "durable goods" which include washers, dryers, water heaters, furnaces, etc. They now come under the electronics category. This means that you shouldn't really expect these devices to last much longer than their warranty period. The days of TV sets lasting 10-15 years are over. Three to five is the new norm. They are designed with obsolescence in mind. The manufacturers do not build any tolerances into the electronics so any small power surge or glitch can cause a cascading failure through the device, taking out multiple board with it. You replace one, it works a few minutes, and then it gets blown out by another one that was bad as well. By the time you get through replacing all the boards, if you are lucky enough to get it working again, you find that for a buck or two more you could have bought a new one that was larger and with more features. This is the manufacturer's plan. If TVs lasted 10 years, then they can't keep selling them at the rate they can build them now. If you want one of these to live a little longer than normal, invest the hundred bucks or so into an UPS to attach to it for power and surge suppression. Dollar store surge protectors won't do much to save these touchy devices.
Nov 22, 2015 | Samsung UN46D6000SFXZA 46in Led Hdtv 1080p...
Samsung HLS5087W picture keeps turning off. Sometimes it happens after a couple of hours and then every 10 minutes after that. recently changed both bulb and color wheel. Tv only 6 years old.
I would first check the lamp is properly seated and was it a Samsung or a generic brand? Also not indicated is does sound remain or not.
Dec 05, 2012 | Samsung HL-S5087W DLP TV
46in Vizio LCD HDTV distorted black picture when tv is turned on
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
You can get parts at www.interliquidparts.com
Nov 28, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
My HDTV keeps turning off and on.
Took it back to the store.
Nov 28, 2008 | Televison & Video
Samsung 46in.
This is a Plasma TV set, there is no convergence adjustments on this set. the convergence adjustments are for tube type projection TV sets. You could have a few problems with your TV. You could have a bad color whell assembly, a bad light engine assy. or a problem with the main board. This is not a set a that some who is not trained on plasma TV sets should attempt to troubleshoot and or repair. depending on how old this set is, it may still be under warranty. if it is not, call out only a Samsung authorized servicer, as they will have the boards and proper tools to service this TV. Good Luck
Mar 21, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung TSL3293HF 32" TV Logo
236 people viewed this question
Henry  Thomas
Henry Thomas
