Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
80GB USB 2.0
My External drive is the only device i cant read via USB
    Scholar:
  • 46 Answers
Hi
If all other usb devices work then there's either a problem with the drive or its drivers. Try plugging it into another computer. If that works you can go to Control Panel>>>System>>>Hardware>>>Device Manager and uninstall all universal serial bus controllers, unless you can locate the one that is for your hard drive. Note: If you have a usb mouse/keyboard this will stop them working untill you select 'scan for hardware changes' at the top, or alternatively unplug then replug them.
Once they are all uninstalled plug the hard drive back in and let it go through the process of 'found new hardware' etc. This will re-install the drivers.
If the drive still doesn't work on either computer then it could mean that it has become corrupted. Right click on my computer then go to 'manage.' On the left under 'storage' select 'removable media' and locate your drive. There should be an option to format it, BUT THIS WILL WIPE YOUR HARD DRIVE! So if you value the data on it then obviously this is not the best way forward.
You could try using a program like pc tools' File Recover to get your files back, though file recovery is a complex process and doesn't always work.
Hard drives do fail - I had to claim on the warranty for my external hard drive a short while ago. It's annoying that the very thing you use to backup breaks!
You have to be very careful if you do choose to format the drive - make sure you format the external and not your internal C drive!
Hope this is of some help
Philip
Posted on Jul 16, 2008
    Novelist:
  • 167 Answers
I've had this problem before.
I tried a different cord and it started working again. Additionally i've had this work for me (see below)
Try This:
  1. Unplug all USB devices
  2. Turn off Ext Hard drive
  3. Shut down computer
  4. Power on ext hard drive (then wait like 1 min)
  5. Turn on computer
  6. Wait for windows to finish loading
  7. Plug in the USB cord from the ext hard drive to your computer (may take up to a minute for computer to recognize it)
  8. If it doesn't recognize it then keep trying it in different USB ports
If it still won't recognize get all the latest windows update and reboot. If that doesn't solve your issue try your external hard drive on some other computers, check to see if drive needs special drivers installed (which most don't).
If all that fails you need to RMA (Return to Manufacturer) your external hard drive. Most hard drives have a pretty decent warranty on them.
  • Steve Stonebraker
    Steve Stonebraker Jul 16, 2008
    From SimpleTech's website: "1) I have the drive plugged in but I cannot find the drive in "My Computer", why?
    The most likely cause would be not enough power provided by a single USB port on your computer. Unplug the portable drive from the cable and unplug the cable from the computer. Now, plug the cable into 2 USB ports directly on your computer. (If you have a desktop, you should plug the USB cable directly into the USB ports on the back of the computer. If this is a laptop, you should plug directly into a USB ports on the computer. Do not plug into a USB hub or docking station). Then plug the drive into the cable. In a few seconds you should see the drive listed in the "My Computer" window as a SimpleDrivePS."
    If all that fails you need to RMA (Return to Manufacturer) your external hard drive. Most hard drives have a pretty decent warranty on them. Your simpletech 80GB has a 1 year warranty on it. Info on the warranty can be found at http://www.simpletech.com/support/warran.... If you want to RMA it, click the "Technical Support / RMA Request" on the left hand side of that page.
Laptop wont read external hard drive
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Jul 10, 2012 | Philips HDD external 2.5, 80GB, USB 2.0...
How can I get this device to read on an xbox 360?
Step 1: Connect your hard drive to your PC.
Step 2: Create a FAT32 partition on your hard drive. If you’re using less than 32 GB, you can use Windows via “Control panel > Administrative tools > Computer Management”. If you’re using more than 32 GB, you’ll have to use an external program, e.g. Partition Magic.
Step 3: Load all the content you want from your PC onto the external drive. This should consist of files that can be read on the Xbox hard drive.
Step 4: Remove the external hard drive from your PC. Plug it into your Xbox 360 console through the USB port.
Step 5: Go to the Media menu on your Xbox screen. Select "Portable Device" from the menu. All the readable files saved on the external drive should be available to read on your Xbox 360.
N.B. Xbox's connection with an external drive is read-only. You can only read files that are already on the drive after connecting. You can't save game files or anything else on the Xbox main drive onto the external hard drive. Also, USB storage devices cannot be used for Xbox live marketplace content.
Apr 12, 2010 | IO Magic Corporation GigaBank (I250HD35)...
I have lost the cd which came with my freecom classic hd 80gb and I had to wipe my computer. Now my computer will not read the files on my freecom harddrive
You don't need any software to use this device. If your hdd is external, you just plug it in to any computer via the USB port. If it is an internal hdd same thing again. You can read your files after restoring your computer. But of course it must be your secondary hdd.
Oct 27, 2009 | Computers & Internet
Connect external hard disk IBM travel star 80GB USB port 2
Unless it's windows 98 you don't need a driver. If your computer can't see it, it's probably broken. Try plugging it in to another computer and see if it can see it
Oct 01, 2009 | IBM TravelStar 40GN 40 GB Hard Drive
Samsung Pleomax SAM MD-205 driver?
It took me a lot of digging to try and find a driver download. You can try the UHD25-80GB driver (this is for Windows 98, but you can try to see if it fixes the problem): http://www.samsungpleomax.com/sup_03_01.asp?page=2&fcate=Driver+download&scate=Storage+Media&tcate=HDD&scateg=Storage%20Media&tcateg=HDD. Direct link to zip file: http://www.samsungpleomax.com/sup/cs/HDD-driver-2500-80GB%20DRIVER.zip
Also, specs indicate that you need USB 2.0 or 1.1. I had problems connecting via a 4-port hub (that was supposed to support USB 2.0) so ended up connecting directly via my computer USB ("Enhanced" = 2.0) slot, which seemed to work fine.
Apr 04, 2009 | Samsung Zirex Pleomax 80GB Portable Hard...
I cant detect my USB external HD for more than a minute.
There is probably a fault within the hard drive, the circuitry of the housing or perhaps the usb lead.
It would be as well to check the power supply first as some of them are less than reliable and are apt to provide too much voltage.
Jun 01, 2017 | Seagate 80GB USB 2.0 External Hard Drive...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
Hitachi 80GB hardrive - error 6
Install your previous hardrive as a slave, secondary drive to your new one, or easier still, buy an external enclosure for it and connect to it via usb
May 16, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Simpletech 500 gig usb plug in hard drive
Is the drive running when connecto to power ans PC?
Try it on another PC.
Check the power supply if it is operated from an external power supply.
It it is self powered via the USB then this is a possible problem- the PC power supply cannot cope - Removing other USB devices may help here
Feb 13, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
How to correctly disconnect maxtor 500 gigabyte external hd
Hi, Normally the steps would be: 1. In your PC, in the System Tray, click on the "Safely Remove Hardware" and then on the "Safely Remove USB Mass Storage Device-Drive(?); 2. Unplug USB cable; 3. Power down external device. Hope this be of some help/idea. Good luck and kind regards.
Sep 17, 2007 | Maxtor OneTouch II external hard drive...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
129 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
