Question about HP ProLiant ML370 G4 Server
Hp proliant ml370 g4 rebooting problem
Hi I have a ML370 g4. it keeps rebooting at the windows loading up screen. I replaced the motherbroad twice. the same problem still happens. The server works fine with 1 CPU in it, but when 1 put the 2nd in it keeps rebooting. I have tested each cpu on its own and it works fine. I have done all the packs updates and bios etcs. I have also tested the memory. This happans has well when i boot with smartstart.
Any ideas would be great
  • Philip Varghese May 11, 2010
    Would you please let me know which PSP/ Smartstart version you are using.
  • Andy Greshake May 11, 2010
    how much memory do you have on board? and what is the size of the power supply? sometimes a power supply is working at a bit less than its rating and as a result the addition of the 2nd cpu will bear this out,,,,,since the power supply has to be continuous and stable in the less than 3v tap there is much less room for error and the bios on either board would pick that up during its POST..please respond to this request....Thankyou
  • 61 Answers
Try to boot from smart start and do offlinr diagnostics.have you purchased second cpu seperately? Check the CPU compatibilities.
Posted on Oct 25, 2008
My hp ml370 g4 startup and the health led is green but when the dignostic utility appers on screen the health led become red and the keyboard not responding help plzzzzzzzzzzzzz
Open the case and turn on. There should be a corresponding led lit inside. That, or you could run Insight Manager. It will tell you exact details.
Feb 28, 2013 | HP ProLiant ML370 G4 Server
Compaq ProLiant ML370 G4 (374490421) Server - Windows xp issues
Servers need the Drivers for the Drive array card.
The server should have come with a smartStart CD that has the drivers for it.
You are NOT going to get another OS on this machine unless you load the drivers for the adapter.
... and why put XP on a Server? that's not the optimal OS for the hardware.
Dec 12, 2011 | Compaq ProLiant ML370 G4 (374490421)...
We recently had a HD failure on our HP Proliant ML370 G3 server. The failed drive is in a RAID 5 configuration, so we simply purchased a replacement drive, and installed it. The problem, is that it...
why not ask HP this, and not in chat rooms. (here)
raid recovery is fully documented at Hp.com
for sure, and even forum help...
you'll have to switch to the commercial, side,
https://h30434.www3.hp.com/
type this in there box.
May 13, 2017 | HP ProLiant ML370 G3 Server
Can the HP ML370 G3 be upgraded to windows server 2008
Unfortunately hp does not have drivers for ML370 G3 on windows 2008 this OS cannot be installed in this server, i attached the os matrix so that you can confirm.
OS Matrix
ML370 G3 OS
Oct 27, 2010 | HP Compaq ProLiant ML370 G3 Server
I have a HP Proliant ML370 G3 server which was replaced can it be rebuilt for 64Bit Windows 2008 operation?
generation 3 servers do not support windows server 2008 there are no drivers for this OS
i include the OS Matrix for you to confirm
Oct 04, 2010 | HP Compaq ProLiant ML370 G3 Server
HOW CAN I CANNECT HP ProLiant ML370 HARD DRIVER
The best way to connect is to use the Ethernet cable to connect each pc to each other or use a Ethernet hub to connect the two together.
Good Luck
C2S
May 27, 2010 | HP ProLiant ML370 G4 Server
Startup problem
Assuming all appears normal (LED's etc) I would suggest you could have a Processor or VRM issue. Drop the machine to a single processor /VRM and see if that helps. Another possibility is a system board issue
May 27, 2009 | HP ProLiant ML370 G4 Server
HP ProLiant ML370 G4 Server Logo
1,149 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
