Question about Linare Desktop, AMD Sempron 2200,40 GB HDD & 128 MB RAM
Pc problem my pc won't boot. the screen is totally black, there is power but flopppy disk drive light is on which i think is not normal. i don't hear any beep sound. but seems to me it is booting normally but just that the screen is black. i check all the cables but the problem never really solve
  • 813 Answers
U have to do this remove your ram clean it & put it back
Posted on Jul 16, 2008
Pc won't boot up
pls check ram
fix it other slot
Dec 06, 2013 | Computers & Internet
In Need Of Wire Connection Diagram of Jumpers, Power Source, & SATA Cables/Cords
Ron ,you write the drive,i suppose you have one drive.C\drive.if you removed C\drive and replaced it with the new drive you have to have the WINDOWS INSTALLDISC.you can't change C\drive all windows files are on it.there of BOOTFAILURE.solution put back the old drive.if you want moore space you have to buy a new disc.windows install DVD.
May 12, 2013 | HP Pavilion a1230n (EG134AA) PC Desktop
Won't boot
Try the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 10, 2012 | Dell Studio 17 Laptop
GX620 Dell, will not boot, 3 green steady lights and power lite, usb light....when i power on, it looks at the hard drive, then stops. monitor has blinking cursor...no bios comes up, and cannot access...
Does anything ever post to the lcd screen when you press the power button to boot it? Does it every show you things like which key to hit to get into the Bios or System Setup?
I think you have a corrupt or missing boot file or system file. The blinking cursor is indicative of that. Try running the Check Disk Utility from your XP CD.
May 04, 2012 | Computers & Internet
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
PC HANGS ON BOOT
Try running the Check Disk Utility.
Feb 18, 2012 | Computers & Internet
My averatec will not turn on
Open it again and make sure you connect all the devices and such ..It seam to be like a clear case of a disconnected cable ..If the system boot up ..and seam to run ..try to see if the vga secondary monitor brings anything to a screen ..if it does it means you messed up with the monitor connections ..cause you changed the hard disk ..you don't have a operation system to boot into and try to make an idea..but its a start ..
Other things to check is the fan connections and cables ..
If the screen is totally blank I think is like I said just a bad connection to the monitor or a damaged cable in the process of opening it .In any other case you would have at least a warning on screen even without hard disk it should boot to BIOS ..
Dec 07, 2011 | Averatec Computers & Internet
I have a gateway tablet m285e. The problem is, it boots up to a black screen. F8 does nothing, trying to use a boot disk does nothing. I connected another monitor to it and still black screen. It does...
If you connect to external monitor and don`t work
Try:
1.- Remove the memory module and clean the gold connectors
reseat the memory.
If continue don`t show image
Disassembly the laptop
Remove the processor
and reseat again
If don`t work, is your Chipset video
Maybe you can try fix the chipset video
look solutions like
http://www.youtube.com/watch?v=BLNReuT67p8
apply heat to Chipset video.
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | Gateway M285-E Notebook
Windows 7 won't bootup, has error recovery. it loads files then nothing. screen is black.
Had that problem a few times myself.
Only way I could fix was to restore back to factory condition.
As you boot, watch bottom of screen closely.
depending on system, Should need to press F2, F10, possibly F12, might even be Del.
Most likely you didn't get restore disk, or have made one.
If you do, insert disk before boot up. System should boot to DvD.
Don't forget once restored to update.
Hope this helps
Don
Jun 22, 2011 | Computers & Internet
My GATEWAY COMPUTER WON'T JUST TURN ON. IT GOES ON AND IT JUST SHOWS A BLACK BLANK SCREEN. PLEASE HELP.I CANT FIND THE RECOVERY DISC. WHAT SHOLD I DO. I THINK IT HAS A VIRUS OR SOMETHING.
If the unit has a place to connect an RGB monitor, try that and see if that is working. If that monitor works, you probably lost the invertor that drives the CCF lamps that backlight the screen. This is normally not a DIY repair.
May 18, 2011 | Gateway 6520GZ Notebook
Computers & Internet Logo
49 people viewed this question
Top Linare Computers & Internet Experts
gautam jha
Level 1 Expert
Carlos L. Burgos
Carlos L. Burgos
Iqbal Husain
Iqbal Husain
Are you a Linare Computer and Internet Expert? Answer questions, earn points and help others
