Question about Microsoft Windows Vista Ultimate Edition
Hello hw to get the defualt aero theme in vista
Earlier I install the vista visual master in my laptop. but when i uninstall it. my default aero theme gone........hw could I get the aero theme in vista
    Novelist:
    Scholar:
  • 160 Answers
This page should have all the answers:
http://windowshelp.microsoft.com/Windows/en-US/Help/c33fe91a-9e6f-41f4-ae82-3ed2d5fa2fbf1033.mspx
Posted on Jul 16, 2008
The text on my pc keeps going blue, how can I stop it?
Windows allows you to change the themes of your computer. This includes the wallpaper, the screensaver when your computer is idle, any noises it makes, and even the color of the toolbars and windows. Sometimes, however, when you restart your computer, the theme will revert back to the Windows default theme, which is called Aero. This can be because you have not disabled Aero, because your performance settings are using too much energy, or because your screen resolution is too high or low for the theme you are using.
Screen Resolution b> The higher your screen resolution, the sharper the images and text will appear. Sometimes, however, the of the wallpaper for the theme is not the same as the screen resolution. This can cause your theme to revert back to the default. To fix this, click the "Start" button. Then click "Control Panel." In the "Control Panel" window click "Adjust Screen Resolution" under "Appearance and Personalization." Select the resolution that is the same as your wallpaper. b> Performance Settings b> If your computer is running on high performance settings, your computer's energy will be used quickly and Windows may automatically change the screen saver to keep the energy from running to low. To change your performance settings, open the "Control Panel" and click "System and Security." Then click "Change Battery Settings" under "Power Options" and select "Power Saver" or "Balance." b> Disable Aero b> Aero is the default theme setting for Windows Vista and Windows 7. If you try to change your theme and it reverts back to Aero, it is because Aero is still not disabled. To disable Aero, right-click on your desktop and click "Personalize." A window of all the themes on your computer will open. You will see "My Themes," which are any themes you have created, and "Aero Themes" under it. To disable Aero, click "Save Theme" under "My Themes" to make your current settings default, or select one of the themes under "My Themes." This will make that theme the default. b> Troubleshooter b> If you still cannot figure out why Windows changes the theme back to the default after restarting, you can use Windows's built-in troubleshooter. The troubleshooter will find the source of the problem and automatically fix it for you. To use the troubleshooter for your theme, open the "Control Panel" and click "System and Security." Then click "Troubleshoot Common Problems." Under "Action Center," select "Appearance and Personalization." The troubleshooter will run. When you restart after it completes its action, your theme should stay the same. Hope this helps.
b>
Dec 15, 2012 | Computers & Internet
Toshiba dvd player dosent work of my toshiba laptop says aero theme windows 7 standurd
I believe that's a requirement for that particular DVD software. There are 2 options that I know of.
a). Try a different DVD player package
b). Enable Windows Aero theme. You will need to make sure the "Theme Service" is running under services (You can access this by right clicking My Computer (or Computer) and going to "Manage". Then "Services and Applications" in the left pane... then Services. Make sure the "Themes" services is started, and is set to Automatic.)
Then ...right click on your desktop and go to "Personalize". Make sure you have one of the "Aero Themes" selected and save your settings...
Then after you confirm this... Right click Computer / My Computer again and choose Properties. Go to the Advanced Tab... click the "Settings" button under performance. Under the Visual Effects tab, make sure "Enable Aero Peek" is selected...as well as "Enable desktop composition" and
"Use visual styles on windows and buttons". Nothing else is really required...
That should meet the Aero Requirements.
Mar 02, 2011 | Toshiba Computers & Internet
I have installed Windows Vista Ultimate on my PC. Now the Aero theme is not working and the same is missing. Please help.
Hey, i've had the same problem. Did you try patching the aero theme? Cos i did the same and it corrupted! One thing you can try now is that you can copy this theme from any of your friends' PC which is running Vista Ultimate and copy it in yours'. You shd paste the file under "C:\Windows\Resources\Themes" (shd have Admin rights to do this). Then apply the theme as usual.
But if the above doesn't work and you are desperate in need of the Aero theme, then no other way other that re-installing the OS.
Hope this help. If so, rate me.. thanks - billa
Sep 05, 2009 | Microsoft Windows Vista Ultimate Edition
Guys this very URGENT!!, i changed my theme on my laptop, just to try it out, but suddenly when i decided to use my original theme which is windows vista, with the visual style aero, it doesn't show the...
There are many methods, but the secure and the easiest one is to use Windows System Restore.
It will be located in the Start Menu > All Programs > Accessories > System Tools > System Restore.
There you will select to restore at an earlier point, there will a calender in front of you, with few dates with BOLD format.
Select a date before this event occured.
And restore the system.
Note: You all settings will be restored to that day's settings.
If i was helpfull, Kindly Do Rate!
Jul 19, 2009 | HP Pavilion DV6700T Notebook
Vista aero crash
Ok, in that case , Try doing system restore using the following link and restore your system to the date on which it was working fine.
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
May 29, 2009 | Microsoft Windows Vista Ultimate Edition
Help!!! My Aero theme gone
Glad to hear it was settled.
In future, this link might prove helpful...click here
Apr 21, 2009 | Microsoft Windows? Vista Home Premium...
Bad resolution and aero glass theme not working
Sounds like you have Intel Ingregrated Video with less than 1 GB system ram.
The answer is the system does not have the hardware to Run Vist Aero Mode, and apparently has minimal ability to run Vista at all.
You may be able to get a better video driver than the default at Support.dell.com.
More than likely, you are looking at putting Windows XP back on the system
Apr 12, 2009 | Computers & Internet
Vista aero crash
Reinstall the display driver. That will solove your issue. Good day
If my solution proves useful kindly accept my solution
Regards
Arjun
Apr 04, 2009 | Microsoft Windows Vista Ultimate Edition
My pc dosn't run windows visual style theme
first go at desktop right click choose properties then choose theme and do it default
Apr 03, 2009 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
141 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
