Question about Brother Office Equipment & Supplies
I cannot get a print out on AX100. New ink cartridge (checked for removal of sealer) Paper just comes out blank without the print.
    Genius:
  • 2,985 Answers
What is an AX100?
Posted on Jul 17, 2008
PAPER FEEDS INTO PRINTER BUT COMES OUT BLANK
HP DeskJet f4280 Spitting Out Blank Paper. - HP Support ...
h30434.www3.hp.com > Printers & All-In-Ones > Print Issues
Solved: I can hear it printing, but the paper is blank when it's finished. ... Mark as New; Bookmark; Subscribe; Subscribe to RSS Feed · Highlight · Print · Report ... green checks say every thing is good to go, but the test print comes out blank,. ... Reinstall the cartridges into the product, and then gently close the cartridge door.
my printer is printing blank pages, and i just changed ink
Nov 18, 2015 | Office Equipment & Supplies
Epson R265 - prints blank (new inks & paper loaded)
Check the cartridges installations and make sure they're well installed.
Make sure the plastic tab around the new cartridges is completely removed.
Disconnect the printer completely and re-connect after a while.
Turn it off and on.
Problem solved?
Uninstall and install the printer again.
Hope this helps.Thanks!
Nov 10, 2011 | Office Equipment & Supplies
My printer is making the sounds that it is printing but the paper is coming out blank. we have not used the printer before however the ink cartridge looks fine..is there something obvious as to why the...
Hello
Sure the ink in the cartridge is clogged and needs to be cleaned. Follow the steps below
1. Open the cartridge access door on your right side of the printer.
2. Remove the cartridge from printer
3. Take a tissue paper with a little water
4. Wipe the nozzles of the cartridge gently
5. Wipe again with an dry tissue and you will find ink deposit on the dry tissue
6. Install back the cartridge in printer
7. Use cartridge cleaning option in the printer.
You are done.
Jul 21, 2011 | HP Photosmart A516 InkJet Printer
Just put 2 new ink cartridges in my printer - black and tricolor. the printer receives the message to print, sends the paper through and sounds like it is printing, but then the paper is blank with no ink...
Hi
Just remove the new 2 cartridges and rub the print head in a plain paper with isopropyl alcohol until ink flows, and then return the ink cartridges and run the print nozzle for 2-3 times. After that, try to print again.
Please let me know if you need more help.
Mar 05, 2011 | HP OfficeJet D135 All-In-One InkJet...
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
My printer is only printer blank pages? When it prints, it runs the paper through at a rate as if it was actually putting ink onto it but than the paper just comes out blank. Help!
Check the ink cartridges for ink level - it might just be empty. If you've replaced them with new cartridges already, clean the print heads with a "Q" tip and alcohol and run the "clean-cartridge" function in the printers properties.
Nov 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper blank
You should have to do a "paper alignment" or follow the "new cartridge" prompts.
Mar 08, 2010 | Dell Inkjet 720 Printer
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Prints everything blank
Check the print cartridge. Open the printers top cover and find release lever for the ink cartridge. Lift out the cartridge and check the jets (copper coloered foil with holes) for blockage. New cartridges have a piece of tape over the jets which must be removed before installing. If blocked with dried ink, dab gently with paper towel and rubbing alcohol. Dry by dabbing on paper towel. Other things to check are: Incorrect cartridge, empty cartridge, and cartridge not snapped in all the way. The cartridge that comes with the printer usually is only partly filled and runs out earlier than normal. You could always try a new cartridge which you will need eventually anyway.
Good luck,
Techjoel
May 23, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hi, I haven't used my Canon S330 printer for some months, and when I plugged it in just now, it wouldn't print. I replaced both cartridges, and still no printing. The cartridge moves fairly quickly back...
in the print head there are hundreds of minute holes from where the ink of the cartridge comes out when you remove the head check whether the ink is coming from the holes in the head .if the ink is not coming the head may be dry and if the very less ink is coming then some of the holes are blocked. the ink has to come out from that holes for printing.
thanks.
Sep 18, 2008 | Office Equipment & Supplies
53 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
