Question about Brother Office Equipment & Supplies
Mfc 8460n dr mode in use - Brother Office Equipment & Supplies
  • edwin1964 Dec 14, 2008
    i have the same problem, dr mode in use
  • maxinemonroe Dec 16, 2008
    I am trying to use the fax and set up the 'mode' I want to use - Ie FAX Only but the message  'DR mode in use' appears on the LCD  and I cannot use the fax at all.
The message DR mode in use or BT Call Sign On will appear on the display of the Brother machine if you attempt to change the receive mode from Manual to another mode when the Distinctive Ring feature (BT Call Sign) is turned ON. If you want to change the Receive Mode, set the Distinctive Ring feature (BT Call Sign) OFF.
  1. Press Menu or Menu/Set.
  2. Select Fax => Miscellaneous or Tel Service => Distinctive or BT Call Sign.
  3. Press the Up or Down Arrow key to select off. Press OK or Menu/Set.
  4. Press Stop/Exit.
Posted on Apr 02, 2009
  • ctsindc Jan 12, 2011
    THANK YOU SO MUCH FOR THIS! Forgot I had that setting on - You are awesome!!!!!
My printer need repair, here is the problem: No paper Reload paper in tray 1
Posted on Oct 10, 2008
SOURCE: document jam brother mfc 8460n
if the message refers to the scanner, open the cover of the feeding unit on top of the printer and clean it with compressed air. Most probably an insect got stuck somewhere
Posted on Nov 07, 2008
jtuminaro
  • 56 Answers
SOURCE: Need to reset 'Drum near end' warning on Brother MFC-8460N.
Open the front door
Press clear
then press 1
Posted on Jan 15, 2009
  • 320 Answers
SOURCE: hi , My 4 in
hello! i need to know where the jam is so that i may help you. brother tech
Posted on Jan 26, 2009
komguy
  • 2306 Answers
SOURCE: MFC 465 CN - says FAX in DR Mode...What is that?
DR mode is distinctive ring, you have to go into fax setup and step through the options. If you go to print reports and select user settings the report will tell you what it's set for and the options are found in the same order they are printed.
Posted on Jun 24, 2009
Jimsta01
  • 405 Answers
SOURCE: how to connect my brother mfc-8460N scanner can't
You will need to use a cable to use the scanner.
Either a USB cable to connect directly to computer or an ethernet cable directly to router, then you will need to install the driver software.
Posted on Mar 30, 2010
How to reset pf kit mp of brother mfc-8460n?
Hello ,
First you have to enter in service mode , then to go to reset menu , and reset pf kit mp an then to live service mode
1. Service mode : menu*2864 , you have to make it fast until the lcd is on : maintenance mode
2. reset menu 88 , now you have to go to pf kit mp and reset
3. Live service menu with 99 or shut down the mfp and after 10 sec restart
Mar 03, 2016 | Brother MFC-8460N All-In-One Printer
I replaced my drum and the output quality is poor and light in areas
did you clear the required counters and run required procedures? If not the machine still thinks it has a old drum because counter was not cleared only way copier will know it has a new drum
Mar 23, 2012 | Brother DCP 8060, 8065DN, HL 5240, 5250DN,...
I need a manual
HI,you can download the manual from the below link..
http://www.manualowl.com/p/Brother%20International/MFC-8460n/Manual/42499
Click on the user's manual and download...
Jun 27, 2011 | Brother MFC-8460N All-In-One Printer
I cannot set my MFC 8460n to receive faxes - it says it is in DR mode
The machine is set to Distinctive Ring mode.
Turning off Distinctive Ring
Press Menu, 2, 0, 2
Press a or b to select Off. Press OK
Press Stop/Exit.
Mar 05, 2011 | Brother MFC-8460N All-In-One Printer
How to connect my brother mfc-8460N scanner can't
Nov 12, 2009 | Brother MFC-8460N All-In-One Printer
What does the drum look like.
Here is what the drum look like for the Brother MFC-8460n courtesy of Super Media Superstore:
http://www.supermediastore.com/toner-dr-520-drum-unit-brother-mfc-8470-8660-8670-8860-8870-comp.html?utm_source=googleBase&utm_medium=pcsite&utm_term=TO-001-2618-datafeed01&utm_content=datafeed01&utm_campaign=googleBase%20-%20TO
Aug 19, 2009 | Brother MFC-8460N All-In-One Printer
Jun 24, 2009 | Brother MFC-465CN InkJet Printer
Can send but can't receive faxes on MFC-8460N
Fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines.
Feb 09, 2009 | Brother MFC-8460N All-In-One Printer
Hi , My 4 in one printer get message Paper jam. MFC-8460N MFC-8460N
Jan 21, 2009 | Brother MFC-8460N All-In-One Printer
Machine Error 8460N Laser Printer
To get the machine error code
Get into maint mode
Within 2 seconds hit:
menu,*,2,8,6,4
This will put you in maint mode.
Press 82
This will give you the machine error code.
Press stop/exit
press 99 to exit maint mode.
Let us know what the machine error is.
Jan 16, 2009 | Brother MFC-8460N Laser Printer
348 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
