Question about Absolute HM65 6 in. Car Monitor
The Picture shows but theere is no backlight
My friend recently gave me 2 Absolute HM65 headrest monitors and i tried testing them b4 installing them and i hooled up the red wire to my inline fuse holder that i have on the battery and the ground directly to the negative batter terminal, the unit turns on and it displays the picture but the back light of either two monitors wont turn on. Idk what it could be i was starting to think that maybe it wasnt getting enough power but i dont know... If anybody knows please help or point me into the right direction. thanks
LED TV - replaced power board but still no backlight? LED backlights do not seem to work.
yes the led backlight for whatever reason is not functioning and that is the root cause of your problem. Unfortunately to find a replacement led backlight is tough as the backlight is normally fixed with the lcd panel and has to match the voltage and all that stuff with motherboard. and if that doesn't match you might short the tv itself. this case is as good as getting a replacement lcd panel.
Feb 17, 2016 | Seiki SE50FY10 50-Inch 1080p 60Hz LED HDTV...
Headrest monitor says no video. I have 10 inch power connect headrest monitor/DVD player. One plays DVD and the other is a monitor. The DVD player headrest plays movies but the monitor screen is blue and...
Those cables can go bad easily. If you have a meter and know how to use it, try to test continuity on each pin. If that isnt the answer, then either the input of second monitor is faulty, or output of main screen.
Jan 05, 2015 | Car Audio & Video
Hooking up 2 additional monitors..
you can try to use a y splitter. the problem with that is the receiver will not give you enough "power" to power up the headrest. You will probably lose picture quality. There are amplifiers that can be purchased that will have extra outputs for video, this would be your best bet. It will give you great picture quality.
May 18, 2010 | Kenwood Excelon DDX-7015 Car DVD Player
I have a problem with a gift from my sister, she gave me a viewsonic n2750w that she gave up on once it started to turn on and shut off on its own, i took it to my place, turned it on, the screen turns on...
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will solved this problems.Tries Websites, to buy a refurbish LCD inverter backlight board for the replacement.The board is a long in shape.
Mar 22, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
I cant figure this out about my headrest lcds HELP
Let me guess, you have a pioneerr dvd headunit a video amplifier and 2 headrest correct.
Now connect from V/A in at the headunit to V/A out at the video amp. Connect V/A out put from #1 headrest to #1 V/A in put at the amp. And V/A out put from #2 headrest to #2 V/A in put at the amp.
Jan 07, 2010 | Car Audio & Video
HP notebook does not boot
Try plugging the external VGA adapter to an external monitor. If you see your desktop or post boot on the external then most likely the lcd screen is bad or you may get lucky and it just be the "backlight tude" Either way I would replace the lcd screen with a new one if the backlight is already shot. You can buy a new screen for around $99 and they are fairly easy to install. Again confirm you have picture to an external monitor b4 you buy a new screen.
Dec 29, 2009 | HP Pavilion dv6000z Notebook
How can I use a relative address in the @find function? It changes to a fixed address when I stop editing.
When you include addresses like A2, C10, F15 they are relative addresses .eg: If you have entries like:
in B4 you have saturday
in C6 you have the formula =FIND("a",B4) .....the answer is 2
B4 is a relative cell address, because if you copy the formula across the row, OR up/down the column, the formula changes and the answer changes
To make it an absolute address you have to type a $ in the cell address. If you type the cell address formula as $B4, it means wherever you move to or copy the formula the B will not change
If you type B$4 the row no 4 is ABSOLUTE or fixed.
$B$4, both column B and row 4 are fixed. If you move the formula anywhere the cell reference will not change.
Summary B4 is a relative cell address
$B4 is absolute address (B is fixed)
B$4 is absolute address (4 is fixed)
$B$4 is abso;lute address (Bis fixed, 4 is also fixed)
Hope this answers your question
Sep 05, 2009 | Corel WordPerfect Office X4 Home & Student...
Lcd monitor goes black
Try a different monitor (a friend's) on your computer, if it works OK the problem may be with your monitor. If it does the same as on your monitor, the computer video card may be defective.
Try your monitor on a different computer (a friend's) etc. You will figure if anything or what is defective. Then you can decide to repair or replace.
May 31, 2009 | Apple Multiple Scan 1705 Monitor
Installation of headrest dvd
yes the screen has to sandwich the material from the headrest to hold it in place.....
Oct 10, 2008 | 2006 Audi A8
10.4 inch headrest lcd monitors
Mar 18, 2008 | Car Audio & Video
Absolute HM65 6 in. Car Monitor Logo
Top Absolute Car Audio & Video Experts
xxxxxx xxx
Are you an Absolute Car Audio and Video Expert? Answer questions, earn points and help others
