I have a Becker Silverstone 2662 6 disc changer for a Mercedes C Class. The cartridege would not eject. I have managed to take unit apart and free the cartridge but It wont stay in when I push it back in. Powere is still there and the movement inside seems to want to pick the discs but the cartridge wont lock in.
  • 2,071 Answers
You must clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. DVD chassis, you can plug in the unit and check if this helped the player to "see" again. Most of the time you can check as is, though on the combo units you're going to have to slide the chassis assembly all the way back into the cabinet to get it to work because the cables are often too short. If this didn’t fix the problem, please read on.
Other things to check
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc.
f the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit.
Also, in a DVD/CD player there are many complaints where the disc gets stuck inside of the unit. This could be as described earlier, but there’s also what’s called a drawer/disc tray opener and closer mechanism to contend with. On many models, old and new alike, there’s a small belt that goes bad and wont let the tray open. You can usually put your ear very close to the front of the unit and, if this is happening, hear the motor spinning when you press the eject button. Another cause is the nylon gears, which can get jammed up with dirt and dust. Also, in other cases, you could have a motor problem, or the driver IC could be at fault. If you suspect that the motor is at fault, simply measure the voltage on the tray motor while pressing on the eject button. If the voltage comes up between 6 to 12 volts, depending on the manufacturer, then the motor needs to be replaced.
Alignments
If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Posted on Jul 16, 2008
Becker radio displays WAIT
to get it working again when the "WAIT" comes on it may take 10/15 minutes before the "WAIT" to go off and then i turned the volume control to the first code number, then push am/fm button to lock it in. repeat until all the code numbers are in and the radio will start normal operation. There is a code number card that comes with the radio, if you do not have it, go to the mb dealer with your vin number and they will give you the code number.
Jul 22, 2014 | OEM 1993 Mercedes 300D Radio / CD Player...
I have a Becker silverstone 2660. I search the box to load the 6 CD. Where can I find this part?
i dont a solution but i have identic problem:
grazie e ciao
marco
m11m@email.it
May 13, 2010 | Car Audio & Video
I want to buy a Becker 2630 CD Magazine
Becker 2630 CD multichanger with 10 cd magazine 100 euro: messenger id: mojo_bf or tel: 40723730633
Mar 24, 2010 | Becker Silverstone 7860 6-Disc CD Changer
How do I eject cds from the 6 disc changer in my 2006 Mercedes E350?
you slide the cover open and then hit the eject button next to the cartriage, the cartriage pops up and then you remove and install the cds you want the unit is in the trunk.
Feb 11, 2010 | 2006 Mercedes-Benz E-Class
Becker Car 10 CD Changer wont eject and hear a cycling sound
cyclying sound may be laser "trying" to read the disc, try a new store bought disc and see then , if it plays ,lasers on the way out , if u get the same sound try to obtain the service manual for the unit , most repair shops will not look at it if they dont already have a service manual . see owners manual for what discs it will paly , rw "burned " mp3 ect . its not ejecting because of possibly different issue .if error is displayed contact grand prix electronics (they made the unit) and see if they can revise solution
Nov 30, 2009 | Car Audio & Video
2003 c240 cd changer is stuck
Usually if you disconect the battery leave for few minuets and then reconect it it usually spits the cd out as the unit resets itself saves a few 100$ hope yhis works if notbthe mechanisem in the unit has gone you will have to strip the cd player down to get your cd back
Sep 27, 2017 | 2003 Mercedes-Benz C-Class
Hi we have Becker Tape deck and Radio, we had to chenge the battery and as such now it's asking for a pin (we no longer have this). Where or whom can we contact to have the pin given to us again.
The radio will have to be removed from the car dashboard .
Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Required are the model number BE* * * *  and the SERIAL NUMBER
Sep 07, 2009 | Becker Silverstone 7860 6-Disc CD Changer
397 people viewed this question
 Grubhead
Grubhead
